Hidden Directories with console scripting
I have a problem currently that when I log into my FTP ssl connection the files are not showing in the directory. In the GUI if I set the "Support for listing of hidden files" to "Off" the file listing is returned correctly. (on this page: https://winscp.net/eng/docs/ui_login_ftp) My question is how do I do this in console mode via scripting? As right now I am only getting a blank file listing returned. So I think I need a command line switch or something to disable showing hidden files through console mode. Any help is appreciated!
Thank you!
Bennett
Thank you!
Bennett
