Cannot log on to WinSCP
Darlene White
I have installed Winscp 4.2.9 and when I try to log on I get the following error message.
Connection failed. Timeout detected. Connection failed. Please specify the password.
I am using Windows Vista and the transfer protocol is FTP.
Thanks,
Darlene
