Timeout waiting for external command to complete the command
Pushkar_K
Thanks for providing us such a nice program.
I am using WinSCP to transfer files from my Windows machine to remote linux machine.
I get "Timeout waiting for ..." error when I try to transfer some large file for. e.g. 10 GB file.
I am using WinSCP.com with SFTP (and WinSCP 4.1)with automatically generated scripts.
Script works fine for files of sizes upto few 100 MBs.
I searched into forums about this problem ,but none of the posts are relevant to the problem I am facing.
Can you tell me where the problem is ?
Thanks in advance.
Pushkar_K
Yes, the same error.
But I am not redirecting output of WinSCP.com or WinSCP.exe.
What I am doing is running a bat file from command prompt that calls WinSCP.com /script=myScript.tmp and this WinSCP.com copies the files.
Will using keepalive option help ?
I did not use keepalive because while copying we are sending data continuosly , so server should not timeout.
Thanks for your timely response.
No keepalive won't help.
JoseETX wrote:
I have the same problem.
What version of WinSCP? What are you doing actually? Have you read the article linked above?
I am using WinSCP to transfer files from Windows Server to Windows Server.
I get "Timeout waiting for ..." error when I try to transfer some large file for. e.g. 18 GB file.
I am using WinSCP.com with SFTP (and WinSCP 4.2.9)with automatically generated scripts.
Script works fine before with a file of 10GB.
Thanks in advance.
Irfan_s
I am using winscp and experiencing the same time issue mentioned above....first day it ran successfully without errors but second day onwards it started giving me a timeout error. I am using winscp version 4. Please help
Re: Timeout waiting for external command to complete the command
Did you read the article linked in my first post?
