OK....
Here's the solution. All I wanted to do was traverse a directory and subdirectories, find files that had changed (via Windows's archive bit) but not been uploaded, upload those files and turn the archive bit off.
Using synchronize is out. It took WinSCP over an hour to simply compare the two directory structures, much less upload any files. Same with modify the .ini file, using a
put
command, only moving new or updated files and setting the archive bit. (if anyone is interested, the two .ini file settings are
NewerOnly=1
and
ClearArchive=1
). This took way too long, too and was generally unreliable anyway.
So, here's what I did. I wrote a simple .vbs script that transversed the directory. Every time it found a file with the archive bit set (the file was new or changed), it queued that file in a WinSCP session. I then used the resulting .xml log file to figure out if the file was successfully transferred, and if so, I turned the archive bit off.
Here's the code in .vbs format:
set shell = WScript.CreateObject("WScript.Shell")
set exec = shell.Exec("winscp.com /log=c:\bin\transfer.xml")
' set up our session
exec.StdIn.Write("option batch continue" + vbCRLF & _
"option confirm off" + vbCRLF & _
"option transfer binary" + vbCRLF & _
"option reconnecttime 300" + vbCRLF& _
"open myuser@myserver.xxx" + vbCRLF)
'set up a file system object that will traverse the directory we're checking
Set fso = CreateObject("Scripting.FileSystemObject")
If WScript.Arguments.Unnamed.Count >= 1 Then
If fso.FolderExists(WScript.Arguments.Unnamed(0)) Then
strSourceDir = WScript.Arguments.Unnamed(0)
strTargetDir = WScript.Arguments.Unnamed(1)
Recurse fso.GetFolder(WScript.Arguments.Unnamed(0))
Else
WScript.Echo "Folder not found."
End If
Else
WScript.Echo "Please give folder name as argument 1."
End If
Sub Recurse(f)
For Each sf In f.SubFolders
Recurse sf
Next
For Each sf In f.Files
If sf.attributes And 32 Then 'archive attribute is set so lets upload that file
putfile = replace(sf, strSourceDir, strTargetDir, 1, -1, 1)
putfile = replace(putfile, "\", "/")
exec.StdIn.Write("put """ + sf + """ """ + putfile + """" + vbCRLF)
Wscript.Echo "put """ + sf + """ """ + putfile + """" + vbCRLF
End If
Next
End Sub
WScript.Echo "done looking..."
exec.StdIn.Write("exit" + vbCRLF) 'we've finished evaluating all the files. Our winscp session may still be going on, however...
sInput = exec.StdOut.ReadAll() 'this allows the session to complete. The script will pause here until it can "readall" the output
'lets look at the xml log file that winscp wrote
Set doc = CreateObject("MSXML2.DOMDocument")
doc.async = False
doc.load("c:\bin\transfer.xml")
' look for uploaded files
Set NodeList = doc.documentElement.selectNodes("//upload")
WScript.Echo("There are " & nodelist.length & " files")
'traverse all the uploaded files and look for those that were sucessfully uploaded so we can remove the archive bit
For i = 0 To NodeList.length - 1
filename = nodelist(i).selectSingleNode("filename/@value").value
If nodelist(i).selectSingleNode("result/@success").value="true" Then 'if the file was successfully transferred...
fso.getfile(filename).attributes = fso.getfile(filename).attributes -32 'remove the archive attribute
End If
Next
