SSL_connect: error in SSLv3 read server hello B
zombix
connection works with 4.2.9 but after upgrade I cant connect, here is the log:
. 2010-11-11 20:30:00.933 --------------------------------------------------------------------------
. 2010-11-11 20:30:00.933 WinSCP Version 4.3.0 (Build 1029) (OS 5.1.2600 Service Pack 3)
. 2010-11-11 20:30:00.933 Login time: 11. 11. 2010 20:30:00
. 2010-11-11 20:30:00.933 Session name: -- mysite.com
. 2010-11-11 20:30:00.934 Host name: ftp.mysite.com (Port: 21)
. 2010-11-11 20:30:00.934 User name: myuser (Password: Yes, Key file: No)
. 2010-11-11 20:30:00.934 Tunnel: No
. 2010-11-11 20:30:00.934 Transfer Protocol: FTP
. 2010-11-11 20:30:00.934 Ping type: C, Ping interval: 15 sec; Timeout: 20 sec
. 2010-11-11 20:30:00.934 Proxy: none
. 2010-11-11 20:30:00.934 FTP: FTPS: Explicit TLS; Passive: Yes [Force IP: No]
. 2010-11-11 20:30:00.934 Local directory: D:\, Remote directory: /public_html/, Update: Yes, Cache: Yes
. 2010-11-11 20:30:00.934 Cache directory changes: Yes, Permanent: Yes
. 2010-11-11 20:30:00.935 DST mode: 1
. 2010-11-11 20:30:00.935 --------------------------------------------------------------------------
. 2010-11-11 20:30:00.984 Connecting to ftp.mysite.com ...
. 2010-11-11 20:30:00.984 m_pSslLayer changed state from 0 to 1
. 2010-11-11 20:30:00.984 m_pSslLayer changed state from 1 to 2
. 2010-11-11 20:30:00.984 m_pSslLayer changed state from 2 to 4
. 2010-11-11 20:30:00.989 Connected with ftp.mysite.com, negotiating SSL connection...
< 2010-11-11 20:30:01.288 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
< 2010-11-11 20:30:01.288 220-You are user number 6 of 50 allowed.
< 2010-11-11 20:30:01.288 220-Local time is now 14:30. Server port: 21.
< 2010-11-11 20:30:01.289 220-IPv6 connections are also welcome on this server.
< 2010-11-11 20:30:01.289 220 You will be disconnected after 15 minutes of inactivity.
> 2010-11-11 20:30:01.289 AUTH TLS
< 2010-11-11 20:30:01.456 234 AUTH TLS OK.
. 2010-11-11 20:30:03.091 SSL_connect: error in SSLv3 read server hello B
. 2010-11-11 20:30:03.091 Can't establish SSL connection
. 2010-11-11 20:30:03.091 Disconnected from server
. 2010-11-11 20:30:03.091 Connection failed.
. 2010-11-11 20:30:03.091 Got reply 1004 to the command 1
* 2010-11-11 20:30:03.098 (ESshFatal) Connection failed.
* 2010-11-11 20:30:03.098 SSL_connect: error in SSLv3 read server hello B
* 2010-11-11 20:30:03.098 Can't establish SSL connection
* 2010-11-11 20:30:03.098 Disconnected from server
* 2010-11-11 20:30:03.098 Connection failed.
* 2010-11-11 20:30:03.098 AUTH TLS OK.
zombix
Re: SSL_connect: error in SSLv3 read server hello B
. 2010-11-15 16:37:02.677 --------------------------------------------------------------------------
. 2010-11-15 16:37:02.693 WinSCP Version 4.2.9 (Build 938) (OS 5.1.2600 Service Pack 3)
. 2010-11-15 16:37:02.693 Login time: 15. 11. 2010 16:37:02
. 2010-11-15 16:37:02.693 --------------------------------------------------------------------------
. 2010-11-15 16:37:02.693 Session name: -- mysite.com
. 2010-11-15 16:37:02.693 Host name: ftp.mysite.com (Port: 21)
. 2010-11-15 16:37:02.693 User name: myuser (Password: Yes, Key file: No)
. 2010-11-15 16:37:02.693 Tunnel: No
. 2010-11-15 16:37:02.693 Transfer Protocol: FTP
. 2010-11-15 16:37:02.693 Ping type: C, Ping interval: 15 sec; Timeout: 20 sec
. 2010-11-15 16:37:02.693 Proxy: none
. 2010-11-15 16:37:02.693 FTP: FTPS: Explicit TLS; Passive: Yes [Force IP: No]
. 2010-11-15 16:37:02.693 Local directory: D:\, Remote directory: /public_html, Update: Yes, Cache: Yes
. 2010-11-15 16:37:02.693 Cache directory changes: Yes, Permanent: Yes
. 2010-11-15 16:37:02.693 DST mode: 1
. 2010-11-15 16:37:02.740 Connecting to ftp.mysite.com ...
. 2010-11-15 16:37:02.864 m_pSslLayer changed state from 0 to 1
. 2010-11-15 16:37:02.864 m_pSslLayer changed state from 1 to 2
. 2010-11-15 16:37:02.864 m_pSslLayer changed state from 2 to 4
. 2010-11-15 16:37:02.880 Connected with ftp.mysite.com, negotiating SSL connection...
< 2010-11-15 16:37:03.239 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
< 2010-11-15 16:37:03.239 220-You are user number 6 of 50 allowed.
< 2010-11-15 16:37:03.239 220-Local time is now 10:37. Server port: 21.
< 2010-11-15 16:37:03.239 220-IPv6 connections are also welcome on this server.
< 2010-11-15 16:37:03.239 220 You will be disconnected after 15 minutes of inactivity.
> 2010-11-15 16:37:03.239 AUTH TLS
< 2010-11-15 16:37:03.410 234 AUTH TLS OK.
. 2010-11-15 16:37:04.705 SSL_connect: SSLv3 read server hello A
. 2010-11-15 16:37:04.705 SSL_connect: SSLv3 read server certificate A
. 2010-11-15 16:37:04.981 SSL_connect: SSLv3 read server key exchange A
. 2010-11-15 16:37:04.981 SSL_connect: SSLv3 read server done A
. 2010-11-15 16:37:04.981 SSL_connect: SSLv3 write client key exchange A
. 2010-11-15 16:37:04.981 SSL_connect: SSLv3 write change cipher spec A
. 2010-11-15 16:37:04.981 SSL_connect: SSLv3 write finished A
. 2010-11-15 16:37:04.981 SSL_connect: SSLv3 flush data
. 2010-11-15 16:37:05.158 SSL_connect: SSLv3 read finished A
. 2010-11-15 16:37:05.163 Using TLSv1, cipher TLSv1/SSLv3: DHE-RSA-AES256-SHA, 1024 bit RSA
. 2010-11-15 16:37:05.166 SSL connection established. Waiting for welcome message...
> 2010-11-15 16:37:05.166 USER myuser
< 2010-11-15 16:37:05.341 331 User myuser OK. Password required
> 2010-11-15 16:37:05.341 PASS ************
< 2010-11-15 16:37:05.601 230-User myuser has group access to: myuser
< 2010-11-15 16:37:05.808 230 OK. Current restricted directory is /
> 2010-11-15 16:37:05.808 SYST
< 2010-11-15 16:37:05.974 215 UNIX Type: L8
> 2010-11-15 16:37:05.974 FEAT
< 2010-11-15 16:37:06.162 211-Extensions supported:
< 2010-11-15 16:37:06.162 EPRT
< 2010-11-15 16:37:06.162 IDLE
< 2010-11-15 16:37:06.162 MDTM
< 2010-11-15 16:37:06.162 SIZE
< 2010-11-15 16:37:06.162 REST STREAM
< 2010-11-15 16:37:06.162 MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
< 2010-11-15 16:37:06.162 MLSD
< 2010-11-15 16:37:06.162 AUTH TLS
< 2010-11-15 16:37:06.162 PBSZ
< 2010-11-15 16:37:06.162 PROT
< 2010-11-15 16:37:06.162 ESTA
< 2010-11-15 16:37:06.162 PASV
< 2010-11-15 16:37:06.162 EPSV
< 2010-11-15 16:37:06.162 SPSV
< 2010-11-15 16:37:06.162 ESTP
< 2010-11-15 16:37:06.364 211 End.
> 2010-11-15 16:37:06.364 PBSZ 0
< 2010-11-15 16:37:06.520 200 PBSZ=0
> 2010-11-15 16:37:06.520 PROT P
< 2010-11-15 16:37:06.723 200 Data protection level set to "private"
. 2010-11-15 16:37:06.739 Connected
. 2010-11-15 16:37:06.739 Got reply 1 to the command 1
. 2010-11-15 16:37:06.739 --------------------------------------------------------------------------
. 2010-11-15 16:37:06.739 Using FTP protocol.
. 2010-11-15 16:37:06.739 Doing startup conversation with host.
> 2010-11-15 16:37:06.739 PWD
< 2010-11-15 16:37:06.926 257 "/" is your current location
. 2010-11-15 16:37:06.926 Got reply 1 to the command 16
. 2010-11-15 16:37:06.926 Changing directory to "/public_html/myfolder".
jhnm
Hi.
I'm having the same problem. For testing purposes i'm running an isolated LAN with no Firewall/antivirus/anti.. etc.(same result as wan)
I'm using WINSCP Portable to connect to a filezilla server.
WINSCP Portable Log:--------------------------------------------------------------
. 2010-11-18 19:10:28.558 WinSCP Version 4.3.0 (Build 1029) (OS 6.1.7600)
. 2010-11-18 19:10:28.558 Login time: Thursday, 18 de November de 2010 19:10:28
. 2010-11-18 19:10:28.558 --------------------------------------------------------------------------
. 2010-11-18 19:10:28.558 Session name: session
. 2010-11-18 19:10:28.558 Host name: 192.168.2.20 (Port: 21)
. 2010-11-18 19:10:28.558 User name: admin (Password: Yes, Key file: No)
. 2010-11-18 19:10:28.558 Tunnel: No
. 2010-11-18 19:10:28.558 Transfer Protocol: FTP
. 2010-11-18 19:10:28.558 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2010-11-18 19:10:28.558 Proxy: none
. 2010-11-18 19:10:28.558 FTP: FTPS: Explicit TLS; Passive: Yes [Force IP: No]
. 2010-11-18 19:10:28.558 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-11-18 19:10:28.558 Cache directory changes: Yes, Permanent: Yes
. 2010-11-18 19:10:28.558 DST mode: 1
. 2010-11-18 19:10:28.621 Connecting to 192.168.2.20 ...
. 2010-11-18 19:10:28.636 Connected with 192.168.2.20, negotiating SSL connection...
< 2010-11-18 19:10:28.636 220 Banner ->ok
> 2010-11-18 19:10:28.636 AUTH TLS
< 2010-11-18 19:10:28.979 234 Using authentication type TLS
. 2010-11-18 19:10:28.979 SSL_connect: error in SSLv3 read server hello B
. 2010-11-18 19:10:28.979 Can't establish SSL connection
. 2010-11-18 19:10:28.979 Disconnected from server
. 2010-11-18 19:10:28.979 Connection failed.
* 2010-11-18 19:10:28.995 (ESshFatal) Connection failed.
* 2010-11-18 19:10:28.995 SSL_connect: error in SSLv3 read server hello B
* 2010-11-18 19:10:28.995 Can't establish SSL connection
* 2010-11-18 19:10:28.995 Disconnected from server
* 2010-11-18 19:10:28.995 Connection failed.
* 2010-11-18 19:10:28.995 Using authentication type TLS
Filezilla Server Log:
(000034) 18-11-2010 19:10:28 - (not logged in) (192.168.2.20)> Connected, sending welcome message...
(000034) 18-11-2010 19:10:28 - (not logged in) (192.168.2.20)> AUTH TLS
(000034) 18-11-2010 19:10:28 - (not logged in) (192.168.2.20)> 234 Using authentication type TLS
(000034) 18-11-2010 19:10:39 - (not logged in) (192.168.2.20)> disconnected.
I have sent an email to zombix while ago. No response so far. Can others facing the problem contact me?
UmageFan wrote:
I have exactly the same problem with the 31 version.
FTP with explicite TLS is broken now.
Same problem here with 4.3.1 beta. Here's the message:
Connection failed.
Proceed with negotiation.
The same answer:
Tls Explicite wrote:
I send three emails already. never got any debug version :-)
What were subjects of your emails?
TLS Explicite
I sent you an email with ip, user and pw to reproduce the issue.
Subject of the email : Re: tls ftp problem winscp
TLS Explicite wrote:
PLease let me know when I can shutdown the test server. Thanks :-)
Will do. Unfortunately I won't have time to test for several days.
tls explicite
how long?
any plans to login to my server? It shouldn't take to much of your time. I have to re-image my vps soon.
Re: how long?
I would like to do it this weekend. If it is not too late.
