error code 1 even though it transfers files
File_Rookie
OK I have a SSIS pkg that transfer files from server to server. It usually transfers more then one file (does a get). Recently very recently the SSIS pkg is receiving an error code 1 even though the transfers complete.
I can transfer the files one by one by if I try to to them all (like 7 which 2 of them being very big files about 200mb and other is about 100mb). I have the timeout set to 0 within SSIS which means go until done. Th eodd thing is that it does copy the files down but SSIS gets the error code of 1 instead of 0. I look thru the error log and nothing stands out...
Any Help?
Re: error code 1 even though it transfers files
