upload files with dropdown menu
trienka
I hope anyone can help me with my problem.
I created a file with a drop-down menu in it. When I try to upload it, the file is going to the server, is available on the internet, but the drop down menu does not work.
I rename the file, upload it again and everything works.
This works sometimes and sometimes it doesn't work.
The transfer is automatic, but I also tried binary.
I tried to upload the file from another adres through FTP, then it works ok.
What can be the problem? Why does it work sometimes but also sometimes not with the same file?
I hope someone can help me.
Re: upload files with dropdown menu
I have no idea where is the problem. Have you tried to delete the existing file on server and upload it then again (as new one)?
