Error due to Load Balancer IP
nonotford
WinSCP v4.2.7 (GUI mode on win2k3 sp2) is sending an error when we use FTPS with a load balancer. The client shows the following error:
Using host address <load balancer ip> instead of the one suggested by the server: <server ip>
Can't establish SSL connection
Copying files from remote side failed.
File receive OK.
We would like WinSCP to move on without an error (which requires user interaction). This IP discrepancy should be normal expected behavior, and not treated as an error.
Re: Error due to Load Balancer IP
zhillma
South Glos
Hi, I know this is a very old topic but it is still relvant to me.
I am using WinSCP 4.3.7 with a command line script file and am experiencing the same issue. The connection is via FTP with TLS (Explicit).
The script uses the following block of code (last 2 lines repeated many times)
open 'profile'
option batch continue
cd /folder
get -delete *Report.txt
Every now and then the transfer fails with the error mentioned, an empty files is created but the real file is left on the server. The job itself completes with no error (I guess due to the 'continue' option)
The log shows these lines
. 2015-05-28 09:51:20.840 File: "/CMUM1/XXX_Risk_Report/XXX_CMUM1_20150526_RiskReport.txt"
. 2015-05-28 09:51:20.842 Copying "/CMUM1/XXX_Risk_Report/XXX_CMUM1_20150526_RiskReport.txt" to local directory started.
. 2015-05-28 09:51:20.843 Ascii transfer mode selected.
. 2015-05-28 09:51:20.845 Starting download of /CMUM1/XXX_Risk_Report/XXX_CMUM1_20150526_RiskReport.txt
> 2015-05-28 09:51:20.847 TYPE A
< 2015-05-28 09:51:20.876 200 Type set to A.
> 2015-05-28 09:51:20.878 PASV
< 2015-05-28 09:51:20.904 227 Entering Passive Mode (XXX,YYY,ZZZ,210,213,16).
. 2015-05-28 09:51:20.910 Using host address AAA.BBB.CCC.147 instead of the one suggested by the server: XXX.YYY.ZZZ.210
> 2015-05-28 09:51:20.912 RETR XXX_CMUM1_20150526_RiskReport.txt
< 2015-05-28 09:51:20.984 150 Opening ASCII mode data connection.
. 2015-05-28 09:51:21.698 SSL connection established
. 2015-05-28 09:51:21.700 Copying files from remote side failed.
. 2015-05-28 09:51:21.701 Got reply 4 to the command 4
< 2015-05-28 09:51:21.701 226 Transfer complete.
* 2015-05-28 09:51:21.704 (ExtException) Using host address AAA.BBB.CCC.147 instead of the one suggested by the server: XXX.YYY.ZZZ.210
* 2015-05-28 09:51:21.704 Copying files from remote side failed.
* 2015-05-28 09:51:21.705 Transfer complete.
. 2015-05-28 09:51:21.706 Asking user:
. 2015-05-28 09:51:21.707 Error transferring file '/CMUM1/XXX_Risk_Report/XXX_CMUM1_20150526_RiskReport.txt'. ("Using host address AAA.BBB.CCC.147 instead of the one suggested by the server: XXX.YYY.ZZZ.210","Copying files from remote side failed.","Transfer complete.")
* 2015-05-28 09:51:21.708 (EScpSkipFile) Error transferring file '/CMUM1/XXX_Risk_Report/XXX_CMUM1_20150526_RiskReport.txt'.
* 2015-05-28 09:51:21.709 Using host address AAA.BBB.CCC.147 instead of the one suggested by the server: XXX.YYY.ZZZ.210
* 2015-05-28 09:51:21.710 Copying files from remote side failed.
* 2015-05-28 09:51:21.710 Transfer complete.
Is there anything that can be done to handle the different IP address better, or get the transfer to retry?
Please attach a full log file showing the problem using the latest version of WinSCP.
