Preserve line ending (LF vs. CR/LF) when editing
dandvd
Silicon Valley
I'm not sure how this bug hasn't been observed yet:
When the user saves a file they are editing in WinSCP, the line ending type is forced to CR/LF. Since the vast majority of files on Linux systems use LF only, this leads to all sorts of errors.
WinSCP should either detect and preserve the line ending type (best option), or (easy) force it to line feed only, which is supported on Windows by most applications, except toy ones like Notepad.
dandvd
Line endings are forced to CRLF on the Windows (local) host
I forgot to mention: the file I was editing is on the local (Windows) machine. When editing remote files, LF is preserved.
I checked Environment -> "End-of-line characters (if not indicated by server)" and the setting was "LF".
Re: Line endings are forced to CRLF on the Windows (local) host
OK then. The internal editor of WinSCP does not preserve line endings. You can use any external editor you like instead.
dandvd
Silicon Valley
It would be really nice if the internal editor preserved line endings, or at least if it warned that it doesn't. Right now, users who assume that it does, might have odd surprises when they upload the file and line endings are corrupted.
Brian_nairB
Hello, I am using an editor that doesn't convert the line endings, and I'm still having a similar issue. I have a file in UNIX that originated in Windows, so we expect each line to end with CRLF. However, we have found in some cases, the data contains a CR, so the end of the line actually looks like CRCRLF. With my transfer mode set to Binary, when I download the file, it preserves the CRCRLF, and that's what I see in my editor. Then if I change something in the file, and save it, the end of line in UNIX after upload is just CRLF. I verified in the temp\scp### directory, the updated file still has the CRCRLF, so my editor is not changing the end of line. Is it possible that only the download is in binary mode, but the upload is occurring in ASCII mode?
Description: this is a UTF-8 file that ends with CRCRLF. Depending on how you view it, it might appears as two lines.
It shouldn't be the case. But please post a full session log file to verify.
clfischer123@...
CRLF - remove carriage return alias
If CRLF is still an issue after transferring, there are several UNIX commands to remove the carriage returns on the UNIX side - especially in KSH scripts.
Add this alias to your .profile:
alias remove_cr="perl -p -i -e 's/\r\n$/\n/g'"
### remove any carriage control at end of lines ###
then at a prompt > remove_cr bld_score.ksh
to remove cr's.
To verify, check the size before and after.
Curt
Nobilis
Regarding the text/binary mode conversion
This a little old I know but I've been going through a similar problem editing Unix files in notepad++ through WinSCP without those being converted to a Windows EOL format.
Every time I opened I a file from WinSCP with Np++ (not transferring it but opening it directly) I found that it had silently added CRs even though I absolutely did not want this. However the transfer was working fine.
The key is to un-tick an option in the Editors tab that reads 'Force text file mode for files edited in external editor' which can be found when you click 'Edit' on your external text editor. Hope it helps others :)
Re: Regarding the text/binary mode conversion
What protocol are you using?
sameer
Newline added even with transfer mode binary
I have a text file in windows that I am transferring to Linux using batch script. I have transfer option binary set but still a empty newline is added at the end of the file. Not sure how to deal with this?
Re: Newline added even with transfer mode binary
So is the uploaded file on the server larger than the source file? Do you have the same problem in GUI? Did you try other FTP client (even GUI one)?
TeejMonster
Just chiming in to say that this solved my issue. I used to have trouble with files opened from WinSCP in an external editor (notepad2, sublimetext3) having the line endings double-up. Never would have checked this setting.
now happy!!!!!!
Another to say this solved extra blank lines with notepad++
Yes!!!!! this solves the problem - was causing havoc with files esp. php
Perhaps the default should be un-checked - this setting is very hard to find!!
BackuPs
Hi
i installed 5.6.3 and i am still having the issue. even if i uncheck the option in the Editors tab that reads 'Force text file mode for files edited in external editor'
When notepad++ opens the file all lf are crlf
I have to select binary transfer mode in order to get this right.
The moment i transfer text mode i have the crlf again.
How to do a textmode transfer but not have the conversion?
Thnx
Re: Preserve line ending (LF vs. CR/LF) when editing
The purpose of the text mode transfer is to have files converted. If you do not want to have it converted, use binary mode.
DevarB
Why not make this a simple option in the config?
[ ] Convert line endings for target system
As it is now, it's very different from the norm and was a huge surprise when I discovered it.
Can you show me an example of software that uses this "norm"? Any FTP software I know has a text/binary switch.
