Only one shot at entering Passphrase in script-mode
PoulJ
When running in script-mode and you are prompted to enter Passphrase you only get one try. If you mistype the Passphrase the script continues without authensication and therefore fails.
Is it possible to get multiple tries at entering Passphrase ?
Cheers,
/Poul
Re: Only one shot at entering Passphrase in script-mode
I wasn't able to reproduce your problem.
