Auto refresh directories when using background transfer
featurerequest1
I use background transfer function by default so I can work with directories while transferring files. But sometimes I don't need to and I stay in the same directory. After the operation finishes I have to refresh this directory manually, because WinSCP doesn't do it (even if "automatically refresh directory after operation" is enabled).
Is this intentional or is it a bug? If it is intentional I think that it should be improved in a way that auto refresh occurs if user stays in the same directory (for cases like mine).
Oh, and keep up the good work! ;)
Re: Auto refresh directories when using background transfer
Currently, you need to have directory cache enabled for refresh to work. Have you?
