WinSCP show documents
Andries
Hi
I have extensively searched on google,this site and asked advanced users for assistance without any luck. Can you please assist?
I log into a UNIX box with SFTP. After successful login when I open document(pdf or docx) which resides locally [on my machine; left panel] in the winSCP commander, the file is corrupted. (Corrupt: Meaning garbage charaters is given.) Opening the file *not* using WinSCP it is not corrupted. Hence, when I transfer the file to the server it is also corrupted. Details:
- win7 32bit
- WinSCP 4.2.9 (build 938)
I have used winSCP before earlier in 2009&2010 without this issue.
Regards
Re: WinSCP show documents
What do you mean by opening file in WinSCP? Do you open it in WinSCP internal editor? Or do youy open in in an external application?
