error when use FTP and error when cahnge text inner a file
robs
1st question
if I am connect how SCP or SFTP, when change the code inner a .php file or text inner a .txt file, winscp ask me to reprompt password for to save the file; want a reconnection;
I am not sur but in past if I was connect how SCP there wasnt this ask ;
is so? only with a FTP connection isn't necessary reinsert the pw?
2nd question
when i make FTP connection have this error:
Connection failed
Timeout detected
SSH-2.0-OpenSSH_3.9p1
while
SCP and SFTP connection work;
is this a winscp problem (to do some settings )?
Re: error when use FTP and error when cahnge text inner a file
Make sure you have Remember password of main session for background transfers enabled.
https://winscp.net/eng/docs/ui_pref_background
Connection failed
Timeout detected
You are obviously connecting to SSH port (22) instead of FTP port (21).
