WinSCP PuTTY error: "Unable to Open...Host does not exist"
FrischInBigD
I continue to receive the following error even after upgrading to the latest WinSCP version. Strange thing is, I have other stored sessions in WinSCP that do not have this issue.
PROBLEM:
I receive the following error message (in WinSCP) when trying to open a PuTTY session:
"Unable to open connection to (IP Address. Host does not exist."
I have checked all settings and permissions of the problem-session vs. the other one that does not have an issue. All same.
Help! Thanks in advance.
FrischInBigD
Re: WinSCP PuTTY error: "Unable to Open...Host does not exist"
What protocol does your WinSCP session use? What protocol do you want WinSCP to use with PuTTY?
FrischInBigD
Dallas
:D
Problem fixed. Not sure why, but deleted the Session and recreated it, and it worked fine. Had done that 2-3 times previously to no avail, but for some reason it now works.
Thanks!
