Run WINSCP in script while not logged in
rvoyek
I would like to run a WINSCP script as a scheduled task on a machine that is not logged in. How can this be done?
rvoyek
Works while signed into server, but not when signed out
I have the process working while I am logged into the server. When it runs it opens a DOS box to run in. However I need this to run on the server when no one is logged it. The taks runs but no files are copied.
Re: Works while signed into server, but not when signed out
Please post a log file for both cases?
