Error while downloading the file..
wahanand
south africa
I am facing below issue while downloading the file from remote location.Please help.
Copying files from remote side failed.Error message : Received incomplete data packet before end of file.
Re: Error while downloading the file..
wahanand
south africa
Hi
Thanks a lot for the response.your help will be highly appreciating.One more thing i would like to highlight here is that i am able to upload a text file on the server from my local directory however I am having problem when i am trying to upload the file on to the server.below is the log.
. 2010-10-06 10:14:58.177 --------------------------------------------------------------------------
. 2010-10-06 10:14:58.177 WinSCP Version 4.2.8 (Build 818) (OS 5.2.3790 Service Pack 2)
. 2010-10-06 10:14:58.177 Login time: 06 October 2010 10:14:58 AM
. 2010-10-06 10:14:58.177 Session name: sensitive information removed
. 2010-10-06 10:14:58.177 Host name: sensitive information removed (Port: 22)
. 2010-10-06 10:14:58.177 User name: sensitive information removed (Password: No, Key file: Yes)
. 2010-10-06 10:14:58.177 Tunnel: No
. 2010-10-06 10:14:58.177 Transfer Protocol: SFTP
. 2010-10-06 10:14:58.177 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-10-06 10:14:58.177 Proxy: none
. 2010-10-06 10:14:58.177 SSH protocol version: 2; Compression: No
. 2010-10-06 10:14:58.177 Bypass authentication: No
. 2010-10-06 10:14:58.177 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-10-06 10:14:58.177 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-10-06 10:14:58.177 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-10-06 10:14:58.177 SFTP Bugs: -,-
. 2010-10-06 10:14:58.177 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-10-06 10:14:58.177 Shell: default
. 2010-10-06 10:14:58.177 EOL: 0, UTF: 2
. 2010-10-06 10:14:58.177 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-10-06 10:14:58.177 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-10-06 10:14:58.177 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-10-06 10:14:58.177 Cache directory changes: Yes, Permanent: Yes
. 2010-10-06 10:14:58.177 DST mode: 1
. 2010-10-06 10:14:58.192 Looking up host "sensitive information removed"
. 2010-10-06 10:14:58.192 Connecting to 192.168.21.35 port 22
. 2010-10-06 10:14:58.208 Server version: SSH-2.0-6.0.0.362 SSH Tectia Server
. 2010-10-06 10:14:58.208 We believe remote version has SSH-2 ignore bug
. 2010-10-06 10:14:58.208 Using SSH protocol version 2
. 2010-10-06 10:14:58.208 We claim version: SSH-2.0-WinSCP_release_4.2.8
. 2010-10-06 10:14:58.208 Using Diffie-Hellman with standard group "group1"
. 2010-10-06 10:14:58.208 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-10-06 10:14:58.474 Host key fingerprint is:
. 2010-10-06 10:14:58.474 ssh-rsa 1536 a9:20:49:09:83:70:19:1b:58:9a:35:83:19:f2:0a:fa
. 2010-10-06 10:14:58.474 Initialised AES-256 CBC client->server encryption
. 2010-10-06 10:14:58.474 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-10-06 10:14:58.474 Initialised AES-256 CBC server->client encryption
. 2010-10-06 10:14:58.474 Initialised HMAC-SHA1 server->client MAC algorithm
. 2010-10-06 10:14:58.599 Reading private key file "C:\PuttyKeyGenerator\PrivateKey_Alldevdb.ppk"
! 2010-10-06 10:14:58.599 Using username "sensitive information removed".
. 2010-10-06 10:14:58.646 Offered public key
. 2010-10-06 10:14:58.677 Offer of public key accepted
! 2010-10-06 10:14:58.677 Authenticating with public key "rsa-key-20100908"
. 2010-10-06 10:14:58.786 Access granted
. 2010-10-06 10:14:58.786 Opened channel for session
. 2010-10-06 10:14:58.817 Started a shell/command
. 2010-10-06 10:14:58.817 --------------------------------------------------------------------------
. 2010-10-06 10:14:58.817 Using SFTP protocol.
. 2010-10-06 10:14:58.817 Doing startup conversation with host.
> 2010-10-06 10:14:58.817 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2010-10-06 10:14:58.880 Type: SSH_FXP_VERSION, Size: 34, Number: -1
. 2010-10-06 10:14:58.880 SFTP version 3 negotiated.
. 2010-10-06 10:14:58.880 Unknown server extension newline@vandyke.com="\r\n"
. 2010-10-06 10:14:58.880 We believe the server has signed timestamps bug
. 2010-10-06 10:14:58.880 We will use UTF-8 strings for status messages only
. 2010-10-06 10:14:58.880 Getting current directory name.
. 2010-10-06 10:14:58.880 Getting real path for '.'
> 2010-10-06 10:14:58.880 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2010-10-06 10:14:58.880 Type: SSH_FXP_NAME, Size: 49, Number: 16
. 2010-10-06 10:14:58.880 Real path is '/C:\'
. 2010-10-06 10:14:58.880 Listing directory "/C:\".
> 2010-10-06 10:14:58.880 Type: SSH_FXP_OPENDIR, Size: 13, Number: 267
< 2010-10-06 10:14:58.896 Type: SSH_FXP_HANDLE, Size: 17, Number: 267
> 2010-10-06 10:14:58.896 Type: SSH_FXP_READDIR, Size: 17, Number: 524
< 2010-10-06 10:14:58.896 Type: SSH_FXP_NAME, Size: 1772, Number: 524
> 2010-10-06 10:14:58.896 Type: SSH_FXP_READDIR, Size: 17, Number: 780
< 2010-10-06 10:14:58.911 Type: SSH_FXP_STATUS, Size: 22, Number: 780
< 2010-10-06 10:14:58.911 Status code: 1
> 2010-10-06 10:14:58.911 Type: SSH_FXP_CLOSE, Size: 17, Number: 1028
. 2010-10-06 10:14:58.911 Startup conversation with host finished.
. 2010-10-06 10:15:45.584 File: "/C:\/AnandTest2.txt"
. 2010-10-06 10:15:45.584 Copying "/C:\/AnandTest2.txt" to local directory started.
. 2010-10-06 10:15:45.584 Ascii transfer mode selected.
. 2010-10-06 10:15:45.584 Opening remote file.
> 2010-10-06 10:15:45.584 Type: SSH_FXP_OPEN, Size: 36, Number: 1283
< 2010-10-06 10:15:45.584 Type: SSH_FXP_STATUS, Size: 21, Number: 1028
. 2010-10-06 10:15:45.584 Discarding reserved response
< 2010-10-06 10:15:45.600 Type: SSH_FXP_HANDLE, Size: 17, Number: 1283
> 2010-10-06 10:15:45.600 Type: SSH_FXP_FSTAT, Size: 17, Number: 1544
> 2010-10-06 10:15:45.600 Type: SSH_FXP_READ, Size: 29, Number: 1797
. 2010-10-06 10:15:45.615 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2010-10-06 10:15:45.615 Type: SSH_FXP_ATTRS, Size: 29, Number: 1544
. 2010-10-06 10:15:45.615 Storing reserved response
. 2010-10-06 10:15:45.678 Received incomplete data packet before end of file, offset: 16877, size: 545, requested: 4083
. 2010-10-06 10:15:45.693 16 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-10-06 10:15:45.693 Type: SSH_FXP_CLOSE, Size: 17, Number: 4356
* 2010-10-06 10:15:45.693 (ECommand) Copying files from remote side failed.
* 2010-10-06 10:15:45.693 Received incomplete data packet before end of file.
wahanand
south africa
Hi Below is the Debug-2 Log File.
. 2010-10-11 12:00:11.812 --------------------------------------------------------------------------
. 2010-10-11 12:00:11.812 WinSCP Version 4.2.9 (Build 938) (OS 5.2.3790 Service Pack 2)
. 2010-10-11 12:00:11.812 Login time: 11 October 2010 12:00:11 PM
. 2010-10-11 12:00:11.812 Session name:
. 2010-10-11 12:00:11.812 Host name: (Port: 22)
. 2010-10-11 12:00:11.812 User name: islifaiam (Password: No, Key file: Yes)
. 2010-10-11 12:00:11.812 Tunnel: No
. 2010-10-11 12:00:11.812 Transfer Protocol: SFTP
. 2010-10-11 12:00:11.812 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-10-11 12:00:11.812 Proxy: none
. 2010-10-11 12:00:11.812 SSH protocol version: 2; Compression: No
. 2010-10-11 12:00:11.812 Bypass authentication: No
. 2010-10-11 12:00:11.812 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-10-11 12:00:11.812 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-10-11 12:00:11.812 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-10-11 12:00:11.812 SFTP Bugs: -,-
. 2010-10-11 12:00:11.812 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-10-11 12:00:11.812 Shell: default
. 2010-10-11 12:00:11.812 EOL: 0, UTF: 2
. 2010-10-11 12:00:11.812 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-10-11 12:00:11.812 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-10-11 12:00:11.812 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-10-11 12:00:11.812 Cache directory changes: Yes, Permanent: Yes
. 2010-10-11 12:00:11.812 DST mode: 1
. 2010-10-11 12:00:11.828 Looking up host
. 2010-10-11 12:00:11.828 Connecting to port 22
. 2010-10-11 12:00:11.844 Selecting events 63 for socket 484
. 2010-10-11 12:00:11.844 Waiting for the server to continue with the initialisation
. 2010-10-11 12:00:11.844 Looking for incoming data
. 2010-10-11 12:00:11.844 Looking for network events
. 2010-10-11 12:00:11.844 Detected network event
. 2010-10-11 12:00:11.844 Enumerating network events for socket 484
. 2010-10-11 12:00:11.844 Enumerated 18 network events making 18 cumulative events for socket 484
. 2010-10-11 12:00:11.844 Handling network write event on socket 484 with error 0
. 2010-10-11 12:00:11.844 Handling network connect event on socket 484 with error 0
. 2010-10-11 12:00:11.844 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:11.844 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:11.844 Server version: SSH-2.0-6.0.0.362 SSH Tectia Server
. 2010-10-11 12:00:11.844 We believe remote version has SSH-2 ignore bug
. 2010-10-11 12:00:11.844 Using SSH protocol version 2
. 2010-10-11 12:00:11.844 We claim version: SSH-2.0-WinSCP_release_4.2.9
. 2010-10-11 12:00:11.844 Using Diffie-Hellman with standard group "group1"
. 2010-10-11 12:00:11.844 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-10-11 12:00:11.875 Waiting for the server to continue with the initialisation
. 2010-10-11 12:00:11.875 Looking for incoming data
. 2010-10-11 12:00:11.875 Looking for network events
. 2010-10-11 12:00:12.109 Detected network event
. 2010-10-11 12:00:12.109 Enumerating network events for socket 484
. 2010-10-11 12:00:12.109 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.109 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.140 Selecting events 63 for socket 484
. 2010-10-11 12:00:12.140 Host key fingerprint is:
. 2010-10-11 12:00:12.140 ssh-rsa 1536 a9:20:49:09:83:70:19:1b:58:9a:35:83:19:f2:0a:fa
. 2010-10-11 12:00:12.140 Initialised AES-256 CBC client->server encryption
. 2010-10-11 12:00:12.140 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-10-11 12:00:12.140 Initialised AES-256 CBC server->client encryption
. 2010-10-11 12:00:12.140 Initialised HMAC-SHA1 server->client MAC algorithm
. 2010-10-11 12:00:12.140 Waiting for the server to continue with the initialisation
. 2010-10-11 12:00:12.140 Looking for incoming data
. 2010-10-11 12:00:12.140 Looking for network events
. 2010-10-11 12:00:12.265 Detected network event
. 2010-10-11 12:00:12.265 Enumerating network events for socket 484
. 2010-10-11 12:00:12.265 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.265 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.265 Reading private key file "C:\PuttyKeyGenerator\PrivateKey_Alldevdb.ppk"
! 2010-10-11 12:00:12.265 Using username "islifaiam".
. 2010-10-11 12:00:12.265 Waiting for the server to continue with the initialisation
. 2010-10-11 12:00:12.265 Looking for incoming data
. 2010-10-11 12:00:12.265 Looking for network events
. 2010-10-11 12:00:12.312 Detected network event
. 2010-10-11 12:00:12.312 Enumerating network events for socket 484
. 2010-10-11 12:00:12.312 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.312 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.312 Offered public key
. 2010-10-11 12:00:12.312 Waiting for the server to continue with the initialisation
. 2010-10-11 12:00:12.312 Looking for incoming data
. 2010-10-11 12:00:12.312 Looking for network events
. 2010-10-11 12:00:12.344 Detected network event
. 2010-10-11 12:00:12.344 Enumerating network events for socket 484
. 2010-10-11 12:00:12.344 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.344 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.344 Offer of public key accepted
! 2010-10-11 12:00:12.344 Authenticating with public key "rsa-key-20100908"
. 2010-10-11 12:00:12.437 Waiting for the server to continue with the initialisation
. 2010-10-11 12:00:12.437 Looking for incoming data
. 2010-10-11 12:00:12.437 Looking for network events
. 2010-10-11 12:00:12.453 Detected network event
. 2010-10-11 12:00:12.453 Enumerating network events for socket 484
. 2010-10-11 12:00:12.453 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.453 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.453 Access granted
. 2010-10-11 12:00:12.453 Waiting for the server to continue with the initialisation
. 2010-10-11 12:00:12.453 Looking for incoming data
. 2010-10-11 12:00:12.453 Looking for network events
. 2010-10-11 12:00:12.453 Opened channel for session
. 2010-10-11 12:00:12.453 Enumerated 0 network events making 0 cumulative events for socket 484
. 2010-10-11 12:00:12.594 Detected network event
. 2010-10-11 12:00:12.594 Enumerating network events for socket 484
. 2010-10-11 12:00:12.594 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.594 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.594 Started a shell/command
. 2010-10-11 12:00:12.594 --------------------------------------------------------------------------
. 2010-10-11 12:00:12.594 Using SFTP protocol.
. 2010-10-11 12:00:12.594 Doing startup conversation with host.
> 2010-10-11 12:00:12.594 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2010-10-11 12:00:12.594 01,00,00,00,05,
. 2010-10-11 12:00:12.594 Sent 9 bytes
. 2010-10-11 12:00:12.594 There are 0 bytes remaining in the send buffer
. 2010-10-11 12:00:12.594 Looking for network events
. 2010-10-11 12:00:12.594 Timeout waiting for network events
. 2010-10-11 12:00:12.594 Waiting for another 4 bytes
. 2010-10-11 12:00:12.594 Looking for incoming data
. 2010-10-11 12:00:12.640 Detected network event
. 2010-10-11 12:00:12.640 Enumerating network events for socket 484
. 2010-10-11 12:00:12.640 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.640 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.640 Received 5 bytes (0)
. 2010-10-11 12:00:12.640 Received 33 bytes (0)
. 2010-10-11 12:00:12.640 Read 4 bytes (34 pending)
. 2010-10-11 12:00:12.640 Read 34 bytes (0 pending)
< 2010-10-11 12:00:12.640 Type: SSH_FXP_VERSION, Size: 34, Number: -1
< 2010-10-11 12:00:12.640 02,00,00,00,03,00,00,00,13,6E,65,77,6C,69,6E,65,40,76,61,6E,64,79,6B,65,2E,
< 2010-10-11 12:00:12.640 63,6F,6D,00,00,00,02,0D,0A,
. 2010-10-11 12:00:12.640 SFTP version 3 negotiated.
. 2010-10-11 12:00:12.640 Unknown server extension newline@vandyke.com="\r\n"
. 2010-10-11 12:00:12.640 We believe the server has signed timestamps bug
. 2010-10-11 12:00:12.640 We will use UTF-8 strings for status messages only
. 2010-10-11 12:00:12.640 Getting current directory name.
. 2010-10-11 12:00:12.640 Getting real path for '.'
> 2010-10-11 12:00:12.640 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
> 2010-10-11 12:00:12.640 10,00,00,00,10,00,00,00,01,2E,
. 2010-10-11 12:00:12.640 Sent 14 bytes
. 2010-10-11 12:00:12.640 There are 0 bytes remaining in the send buffer
. 2010-10-11 12:00:12.640 Looking for network events
. 2010-10-11 12:00:12.640 Timeout waiting for network events
. 2010-10-11 12:00:12.640 Waiting for another 4 bytes
. 2010-10-11 12:00:12.640 Looking for incoming data
. 2010-10-11 12:00:12.656 Received 5 bytes (0)
. 2010-10-11 12:00:12.656 Read 4 bytes (1 pending)
. 2010-10-11 12:00:12.656 Waiting for another 48 bytes
. 2010-10-11 12:00:12.656 Looking for incoming data
. 2010-10-11 12:00:12.656 Looking for network events
. 2010-10-11 12:00:12.656 Detected network event
. 2010-10-11 12:00:12.656 Enumerating network events for socket 484
. 2010-10-11 12:00:12.656 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.656 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.656 Received 48 bytes (0)
. 2010-10-11 12:00:12.656 Read 49 bytes (0 pending)
< 2010-10-11 12:00:12.656 Type: SSH_FXP_NAME, Size: 49, Number: 16
< 2010-10-11 12:00:12.656 68,00,00,00,10,00,00,00,01,00,00,00,04,2F,43,3A,5C,00,00,00,04,2F,43,3A,5C,
< 2010-10-11 12:00:12.656 00,00,00,0D,00,00,00,00,00,00,00,00,00,00,41,C0,4C,B2,DF,EC,4C,B2,BE,C2,
. 2010-10-11 12:00:12.656 Real path is '/C:\'
. 2010-10-11 12:00:12.656 Listing directory "/C:\".
> 2010-10-11 12:00:12.656 Type: SSH_FXP_OPENDIR, Size: 13, Number: 267
> 2010-10-11 12:00:12.656 0B,00,00,01,0B,00,00,00,04,2F,43,3A,5C,
. 2010-10-11 12:00:12.656 Sent 17 bytes
. 2010-10-11 12:00:12.656 There are 0 bytes remaining in the send buffer
. 2010-10-11 12:00:12.656 Timeout waiting for network events
. 2010-10-11 12:00:12.656 Waiting for another 4 bytes
. 2010-10-11 12:00:12.672 Detected network event
. 2010-10-11 12:00:12.672 Enumerating network events for socket 484
. 2010-10-11 12:00:12.672 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.672 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.672 Received 5 bytes (0)
. 2010-10-11 12:00:12.672 Received 16 bytes (0)
. 2010-10-11 12:00:12.672 Read 4 bytes (17 pending)
. 2010-10-11 12:00:12.672 Read 17 bytes (0 pending)
< 2010-10-11 12:00:12.672 Type: SSH_FXP_HANDLE, Size: 17, Number: 267
< 2010-10-11 12:00:12.672 66,00,00,01,0B,00,00,00,08,00,7F,F9,48,00,7F,33,38,
> 2010-10-11 12:00:12.672 Type: SSH_FXP_READDIR, Size: 17, Number: 524
> 2010-10-11 12:00:12.672 0C,00,00,02,0C,00,00,00,08,00,7F,F9,48,00,7F,33,38,
. 2010-10-11 12:00:12.672 Sent 21 bytes
. 2010-10-11 12:00:12.672 There are 0 bytes remaining in the send buffer
. 2010-10-11 12:00:12.672 Looking for network events
. 2010-10-11 12:00:12.672 Timeout waiting for network events
. 2010-10-11 12:00:12.672 Waiting for another 4 bytes
. 2010-10-11 12:00:12.672 Looking for incoming data
. 2010-10-11 12:00:12.672 Read 4 bytes (1 pending)
. 2010-10-11 12:00:12.672 Waiting for another 3126 bytes
. 2010-10-11 12:00:12.687 Detected network event
. 2010-10-11 12:00:12.687 Enumerating network events for socket 484
. 2010-10-11 12:00:12.687 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.687 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.687 Received 128 bytes (0)
. 2010-10-11 12:00:12.687 Received 256 bytes (0)
. 2010-10-11 12:00:12.687 Waiting for another 2742 bytes
. 2010-10-11 12:00:12.687 Looking for incoming data
. 2010-10-11 12:00:12.687 Looking for network events
. 2010-10-11 12:00:12.687 Received 512 bytes (0)
. 2010-10-11 12:00:12.687 Received 1024 bytes (0)
. 2010-10-11 12:00:12.687 Waiting for another 1206 bytes
. 2010-10-11 12:00:12.687 Received 1206 bytes (0)
. 2010-10-11 12:00:12.687 Read 3127 bytes (0 pending)
< 2010-10-11 12:00:12.687 Type: SSH_FXP_NAME, Size: 3127, Number: 524
< 2010-10-11 12:00:12.687 68,00,00,02,0C,00,00,00,16,00,00,00,01,2E,00,00,00,39,64,72,77,78,2D,2D,2D,
< 2010-10-11 12:00:12.687 2D,2D,2D,20,20,20,31,20,30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,20,20,30,20,4F,63,74,20,31,31,20,20,39,3A,33,37,20,2E,2F,
< 2010-10-11 12:00:12.687 00,00,00,0D,00,00,00,00,00,00,00,00,00,00,41,C0,4C,B2,DF,EC,4C,B2,BE,C2,00,
< 2010-10-11 12:00:12.687 00,00,02,2E,2E,00,00,00,3A,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,31,20,30,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,20,20,20,20,30,
< 2010-10-11 12:00:12.687 20,53,65,70,20,32,38,20,31,35,3A,33,31,20,2E,2E,2F,00,00,00,0D,00,00,00,00,
< 2010-10-11 12:00:12.687 00,00,00,00,00,00,41,C0,4C,B2,DF,E9,4C,A1,EE,47,00,00,00,09,45,72,72,6F,72,
< 2010-10-11 12:00:12.687 2E,6C,6F,67,00,00,00,40,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,31,20,30,20,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,20,38,39,35,34,20,
< 2010-10-11 12:00:12.687 4F,63,74,20,20,38,20,31,30,3A,35,39,20,45,72,72,6F,72,2E,6C,6F,67,00,00,00,
< 2010-10-11 12:00:12.687 0D,00,00,00,00,00,00,22,FA,00,00,81,80,4C,AF,0D,61,4C,AE,DD,80,00,00,00,13,
< 2010-10-11 12:00:12.687 49,73,6C,49,66,61,49,61,6D,50,76,74,4B,65,79,2E,70,70,6B,00,00,00,4A,2D,72,
< 2010-10-11 12:00:12.687 77,2D,2D,2D,2D,2D,2D,2D,20,20,20,31,20,30,20,20,20,20,20,20,20,20,30,20,20,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,20,20,20,20,20,38,36,39,20,53,65,70,20,20,37,20,31,31,3A,
< 2010-10-11 12:00:12.687 35,31,20,49,73,6C,49,66,61,49,61,6D,50,76,74,4B,65,79,2E,70,70,6B,00,00,00,
< 2010-10-11 12:00:12.687 0D,00,00,00,00,00,00,03,65,00,00,81,80,4C,AF,0D,61,4C,86,0B,05,00,00,00,20,
< 2010-10-11 12:00:12.687 49,53,4C,5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,30,39,32,39,5F,30,30,30,
< 2010-10-11 12:00:12.687 30,30,30,2E,74,78,74,00,00,00,57,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,31,
< 2010-10-11 12:00:12.687 20,30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,20,20,33,
< 2010-10-11 12:00:12.687 32,34,20,4F,63,74,20,20,38,20,31,37,3A,31,38,20,49,53,4C,5F,48,6F,6C,64,69,
< 2010-10-11 12:00:12.687 6E,67,73,5F,32,30,31,30,30,39,32,39,5F,30,30,30,30,30,30,2E,74,78,74,00,00,
< 2010-10-11 12:00:12.687 00,0D,00,00,00,00,00,00,01,44,00,00,81,80,4C,AF,36,35,4C,AF,36,35,00,00,00,
< 2010-10-11 12:00:12.687 20,49,53,4C,5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,30,39,33,30,5F,30,30,
< 2010-10-11 12:00:12.687 30,30,30,30,2E,74,78,74,00,00,00,57,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,
< 2010-10-11 12:00:12.687 31,20,30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,20,20,
< 2010-10-11 12:00:12.687 33,32,33,20,4F,63,74,20,20,38,20,31,37,3A,31,39,20,49,53,4C,5F,48,6F,6C,64,
< 2010-10-11 12:00:12.687 69,6E,67,73,5F,32,30,31,30,30,39,33,30,5F,30,30,30,30,30,30,2E,74,78,74,00,
< 2010-10-11 12:00:12.687 00,00,0D,00,00,00,00,00,00,01,43,00,00,81,80,4C,AF,36,97,4C,AF,36,97,00,00,
< 2010-10-11 12:00:12.687 00,20,49,53,4C,5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,30,30,31,5F,30,
< 2010-10-11 12:00:12.687 30,30,30,30,30,2E,74,78,74,00,00,00,57,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,
< 2010-10-11 12:00:12.687 20,31,20,30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,20,
< 2010-10-11 12:00:12.687 20,33,32,33,20,4F,63,74,20,20,38,20,31,37,3A,32,32,20,49,53,4C,5F,48,6F,6C,
< 2010-10-11 12:00:12.687 64,69,6E,67,73,5F,32,30,31,30,31,30,30,31,5F,30,30,30,30,30,30,2E,74,78,74,
< 2010-10-11 12:00:12.687 00,00,00,0D,00,00,00,00,00,00,01,43,00,00,81,80,4C,AF,37,24,4C,AF,37,24,00,
< 2010-10-11 12:00:12.687 00,00,20,49,53,4C,5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,30,30,34,5F,
< 2010-10-11 12:00:12.687 30,30,30,30,30,30,2E,74,78,74,00,00,00,57,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,
< 2010-10-11 12:00:12.687 20,20,31,20,30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,
< 2010-10-11 12:00:12.687 20,20,33,32,34,20,4F,63,74,20,20,38,20,31,38,3A,30,37,20,49,53,4C,5F,48,6F,
< 2010-10-11 12:00:12.687 6C,64,69,6E,67,73,5F,32,30,31,30,31,30,30,34,5F,30,30,30,30,30,30,2E,74,78,
< 2010-10-11 12:00:12.687 74,00,00,00,0D,00,00,00,00,00,00,01,44,00,00,81,80,4C,AF,41,B4,4C,AF,41,B4,
< 2010-10-11 12:00:12.687 00,00,00,20,49,53,4C,5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,30,30,35,
< 2010-10-11 12:00:12.687 5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,57,2D,72,77,2D,2D,2D,2D,2D,2D,2D,
< 2010-10-11 12:00:12.687 20,20,20,31,20,30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,
< 2010-10-11 12:00:12.687 20,20,20,32,31,32,20,4F,63,74,20,20,38,20,31,38,3A,30,37,20,49,53,4C,5F,48,
< 2010-10-11 12:00:12.687 6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,30,30,35,5F,30,30,30,30,30,30,2E,74,
< 2010-10-11 12:00:12.687 78,74,00,00,00,0D,00,00,00,00,00,00,00,D4,00,00,81,80,4C,AF,41,D3,4C,AF,41,
< 2010-10-11 12:00:12.687 D3,00,00,00,20,49,53,4C,5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,30,30,
< 2010-10-11 12:00:12.687 36,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,57,2D,72,77,2D,2D,2D,2D,2D,2D,
< 2010-10-11 12:00:12.687 2D,20,20,20,31,20,30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,
< 2010-10-11 12:00:12.687 20,20,20,20,32,31,32,20,4F,63,74,20,20,38,20,31,37,3A,32,34,20,49,53,4C,5F,
< 2010-10-11 12:00:12.687 48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,30,30,36,5F,30,30,30,30,30,30,2E,
< 2010-10-11 12:00:12.687 74,78,74,00,00,00,0D,00,00,00,00,00,00,00,D4,00,00,81,80,4C,AF,37,96,4C,AF,
< 2010-10-11 12:00:12.687 37,97,00,00,00,20,49,53,4C,5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,30,
< 2010-10-11 12:00:12.687 30,37,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,57,2D,72,77,2D,2D,2D,2D,2D,
< 2010-10-11 12:00:12.687 2D,2D,20,20,20,31,20,30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,
< 2010-10-11 12:00:12.687 20,20,20,20,20,32,31,32,20,4F,63,74,20,20,38,20,31,37,3A,32,35,20,49,53,4C,
< 2010-10-11 12:00:12.687 5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,30,30,37,5F,30,30,30,30,30,30,
< 2010-10-11 12:00:12.687 2E,74,78,74,00,00,00,0D,00,00,00,00,00,00,00,D4,00,00,81,80,4C,AF,37,D4,4C,
< 2010-10-11 12:00:12.687 AF,37,D4,00,00,00,20,49,53,4C,5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,
< 2010-10-11 12:00:12.687 30,30,38,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,57,2D,72,77,2D,2D,2D,2D,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,32,31,32,20,4F,63,74,20,31,31,20,20,39,3A,32,35,20,49,53,
< 2010-10-11 12:00:12.687 4C,5F,48,6F,6C,64,69,6E,67,73,5F,32,30,31,30,31,30,30,38,5F,30,30,30,30,30,
< 2010-10-11 12:00:12.687 30,2E,74,78,74,00,00,00,0D,00,00,00,00,00,00,00,D4,00,00,81,80,4C,B2,BB,F1,
< 2010-10-11 12:00:12.687 4C,B2,BB,F1,00,00,00,24,49,53,4C,5F,54,72,61,6E,73,61,63,74,69,6F,6E,73,5F,
< 2010-10-11 12:00:12.687 32,30,31,30,30,39,32,39,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,5B,2D,72,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,20,20,20,20,20,36,30,33,20,4F,63,74,20,20,38,20,31,38,3A,
< 2010-10-11 12:00:12.687 30,38,20,49,53,4C,5F,54,72,61,6E,73,61,63,74,69,6F,6E,73,5F,32,30,31,30,30,
< 2010-10-11 12:00:12.687 39,32,39,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,0D,00,00,00,00,00,00,02,
< 2010-10-11 12:00:12.687 5B,00,00,81,80,4C,AF,42,10,4C,AF,42,12,00,00,00,24,49,53,4C,5F,54,72,61,6E,
< 2010-10-11 12:00:12.687 73,61,63,74,69,6F,6E,73,5F,32,30,31,30,30,39,33,30,5F,30,30,30,30,30,30,2E,
< 2010-10-11 12:00:12.687 74,78,74,00,00,00,5B,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,31,20,30,20,20,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,20,20,32,32,33,20,4F,
< 2010-10-11 12:00:12.687 63,74,20,20,38,20,31,38,3A,31,30,20,49,53,4C,5F,54,72,61,6E,73,61,63,74,69,
< 2010-10-11 12:00:12.687 6F,6E,73,5F,32,30,31,30,30,39,33,30,5F,30,30,30,30,30,30,2E,74,78,74,00,00,
< 2010-10-11 12:00:12.687 00,0D,00,00,00,00,00,00,00,DF,00,00,81,80,4C,AF,42,79,4C,AF,42,7A,00,00,00,
< 2010-10-11 12:00:12.687 24,49,53,4C,5F,54,72,61,6E,73,61,63,74,69,6F,6E,73,5F,32,30,31,30,31,30,30,
< 2010-10-11 12:00:12.687 31,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,5B,2D,72,77,2D,2D,2D,2D,2D,2D,
< 2010-10-11 12:00:12.687 20,20,20,20,39,37,37,20,4F,63,74,20,20,38,20,31,38,3A,31,33,20,49,53,4C,5F,
< 2010-10-11 12:00:12.687 54,72,61,6E,73,61,63,74,69,6F,6E,73,5F,32,30,31,30,31,30,30,31,5F,30,30,30,
< 2010-10-11 12:00:12.687 30,30,30,2E,74,78,74,00,00,00,0D,00,00,00,00,00,00,03,D1,00,00,81,80,4C,AF,
< 2010-10-11 12:00:12.687 43,0F,4C,AF,43,10,00,00,00,24,49,53,4C,5F,54,72,61,6E,73,61,63,74,69,6F,6E,
< 2010-10-11 12:00:12.687 73,5F,32,30,31,30,31,30,30,34,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,5B,
< 2010-10-11 12:00:12.687 2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,31,20,30,20,20,20,20,20,20,20,20,30,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,20,20,20,20,20,20,20,32,32,33,20,4F,63,74,20,20,38,20,31,
< 2010-10-11 12:00:12.687 38,3A,31,33,20,49,53,4C,5F,54,72,61,6E,73,61,63,74,69,6F,6E,73,5F,32,30,31,
< 2010-10-11 12:00:12.687 30,31,30,30,34,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,0D,00,00,00,00,00,
< 2010-10-11 12:00:12.687 00,00,DF,00,00,81,80,4C,AF,43,3F,4C,AF,43,3F,00,00,00,24,49,53,4C,5F,54,72,
< 2010-10-11 12:00:12.687 61,6E,73,61,63,74,69,6F,6E,73,5F,32,30,31,30,31,30,30,35,5F,30,30,30,30,30,
< 2010-10-11 12:00:12.687 30,2E,74,78,74,00,00,00,5B,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,31,20,30,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,20,20,36,31,35,
< 2010-10-11 12:00:12.687 20,4F,63,74,20,20,38,20,31,38,3A,32,39,20,49,53,4C,5F,54,72,61,6E,73,61,63,
< 2010-10-11 12:00:12.687 74,69,6F,6E,73,5F,32,30,31,30,31,30,30,35,5F,30,30,30,30,30,30,2E,74,78,74,
< 2010-10-11 12:00:12.687 00,00,00,0D,00,00,00,00,00,00,02,67,00,00,81,80,4C,AF,46,E4,4C,AF,46,EA,00,
< 2010-10-11 12:00:12.687 00,00,24,49,53,4C,5F,54,72,61,6E,73,61,63,74,69,6F,6E,73,5F,32,30,31,30,31,
< 2010-10-11 12:00:12.687 30,30,36,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,5B,2D,72,77,2D,2D,2D,2D,
< 2010-10-11 12:00:12.687 20,20,20,20,20,20,32,32,33,20,4F,63,74,20,20,38,20,31,38,3A,32,30,20,49,53,
< 2010-10-11 12:00:12.687 4C,5F,54,72,61,6E,73,61,63,74,69,6F,6E,73,5F,32,30,31,30,31,30,30,36,5F,30,
< 2010-10-11 12:00:12.687 30,30,30,30,30,2E,74,78,74,00,00,00,0D,00,00,00,00,00,00,00,DF,00,00,81,80,
< 2010-10-11 12:00:12.703 4C,B2,E0,16,4C,AF,44,B0,00,00,00,24,49,53,4C,5F,54,72,61,6E,73,61,63,74,69,
< 2010-10-11 12:00:12.703 6F,6E,73,5F,32,30,31,30,31,30,30,37,5F,30,30,30,30,30,30,2E,74,78,74,00,00,
< 2010-10-11 12:00:12.703 00,5B,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,31,20,30,20,20,20,20,20,20,20,
< 2010-10-11 12:00:12.703 20,30,20,20,20,20,20,20,20,20,20,20,20,20,20,32,32,33,20,4F,63,74,20,20,38,
< 2010-10-11 12:00:12.703 20,31,38,3A,32,30,20,49,53,4C,5F,54,72,61,6E,73,61,63,74,69,6F,6E,73,5F,32,
< 2010-10-11 12:00:12.703 30,31,30,31,30,30,37,5F,30,30,30,30,30,30,2E,74,78,74,00,00,00,0D,00,00,00,
< 2010-10-11 12:00:12.703 00,00,00,00,DF,00,00,81,80,4C,AF,44,E1,4C,AF,44,E1,00,00,00,24,49,53,4C,5F,
< 2010-10-11 12:00:12.703 54,72,61,6E,73,61,63,74,69,6F,6E,73,5F,32,30,31,30,31,30,30,38,5F,30,30,30,
< 2010-10-11 12:00:12.703 30,30,30,2E,74,78,74,00,00,00,5B,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,31,
< 2010-10-11 12:00:12.703 20,30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,20,20,34,
< 2010-10-11 12:00:12.703 31,33,20,4F,63,74,20,31,31,20,20,39,3A,32,35,20,49,53,4C,5F,54,72,61,6E,73,
< 2010-10-11 12:00:12.703 61,63,74,69,6F,6E,73,5F,32,30,31,30,31,30,30,38,5F,30,30,30,30,30,30,2E,74,
< 2010-10-11 12:00:12.703 78,74,00,00,00,0D,00,00,00,00,00,00,01,9D,00,00,81,80,4C,B2,BB,F0,4C,B2,BB,
< 2010-10-11 12:00:12.703 F0,00,00,00,0D,74,65,73,74,61,6E,61,6E,64,2E,74,78,74,00,00,00,44,2D,72,77,
< 2010-10-11 12:00:12.703 2D,2D,2D,2D,2D,2D,2D,20,20,20,31,20,30,20,20,20,20,20,20,20,20,30,20,20,20,
< 2010-10-11 12:00:12.703 20,20,20,20,20,20,20,20,20,20,20,32,31,20,4F,63,74,20,20,35,20,31,32,3A,33,
< 2010-10-11 12:00:12.703 33,20,74,65,73,74,61,6E,61,6E,64,2E,74,78,74,00,00,00,0D,00,00,00,00,00,00,
< 2010-10-11 12:00:12.703 00,15,00,00,81,80,4C,AF,0D,62,4C,AA,FF,03,00,00,00,0D,57,69,6E,53,63,70,4C,
< 2010-10-11 12:00:12.703 6F,67,2E,6C,6F,67,00,00,00,44,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,31,20,
< 2010-10-11 12:00:12.703 30,20,20,20,20,20,20,20,20,30,20,20,20,20,20,20,20,20,20,20,20,32,33,31,39,
< 2010-10-11 12:00:12.703 34,20,4F,63,74,20,20,36,20,31,35,3A,33,38,20,57,69,6E,53,63,70,4C,6F,67,2E,
< 2010-10-11 12:00:12.703 6C,6F,67,00,00,00,0D,00,00,00,00,00,00,5A,9A,00,00,81,80,4C,B2,CE,1F,4C,AC,
< 2010-10-11 12:00:12.703 7B,C9,
> 2010-10-11 12:00:12.703 Type: SSH_FXP_READDIR, Size: 17, Number: 780
> 2010-10-11 12:00:12.703 0C,00,00,03,0C,00,00,00,08,00,7F,F9,48,00,7F,33,38,
. 2010-10-11 12:00:12.703 Sent 21 bytes
. 2010-10-11 12:00:12.703 There are 0 bytes remaining in the send buffer
. 2010-10-11 12:00:12.703 Looking for network events
. 2010-10-11 12:00:12.703 Timeout waiting for network events
. 2010-10-11 12:00:12.703 Read file '.' from listing
. 2010-10-11 12:00:12.703 Read file '..' from listing
. 2010-10-11 12:00:12.703 Read file 'Error.log' from listing
. 2010-10-11 12:00:12.703 Read file 'IslIfaIamPvtKey.ppk' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Holdings_20100929_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Holdings_20100930_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Holdings_20101001_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Holdings_20101004_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Holdings_20101005_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Holdings_20101006_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Holdings_20101007_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Holdings_20101008_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Transactions_20100929_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Transactions_20100930_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Transactions_20101001_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Transactions_20101004_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Transactions_20101005_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Transactions_20101006_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Transactions_20101007_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'ISL_Transactions_20101008_000000.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'testanand.txt' from listing
. 2010-10-11 12:00:12.703 Read file 'WinScpLog.log' from listing
. 2010-10-11 12:00:12.703 Waiting for another 4 bytes
. 2010-10-11 12:00:12.703 Looking for incoming data
. 2010-10-11 12:00:12.703 Detected network event
. 2010-10-11 12:00:12.703 Enumerating network events for socket 484
. 2010-10-11 12:00:12.703 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:12.703 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:12.703 Received 5 bytes (0)
. 2010-10-11 12:00:12.703 Received 21 bytes (0)
. 2010-10-11 12:00:12.703 Read 4 bytes (22 pending)
. 2010-10-11 12:00:12.703 Read 22 bytes (0 pending)
< 2010-10-11 12:00:12.703 Type: SSH_FXP_STATUS, Size: 22, Number: 780
< 2010-10-11 12:00:12.703 65,00,00,03,0C,00,00,00,01,00,00,00,03,45,4F,46,00,00,00,02,65,6E,
< 2010-10-11 12:00:12.703 Status code: 1
> 2010-10-11 12:00:12.703 Type: SSH_FXP_CLOSE, Size: 17, Number: 1028
> 2010-10-11 12:00:12.703 04,00,00,04,04,00,00,00,08,00,7F,F9,48,00,7F,33,38,
. 2010-10-11 12:00:12.703 Startup conversation with host finished.
. 2010-10-11 12:00:13.531 Session upkeep
. 2010-10-11 12:00:13.531 Looking for network events
. 2010-10-11 12:00:13.531 Detected network event
. 2010-10-11 12:00:13.531 Enumerating network events for socket 484
. 2010-10-11 12:00:13.531 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:13.531 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:13.531 Received 5 bytes (0)
. 2010-10-11 12:00:13.531 Received 20 bytes (0)
. 2010-10-11 12:00:14.031 Session upkeep
. 2010-10-11 12:00:14.031 Looking for network events
. 2010-10-11 12:00:14.031 Timeout waiting for network events
. 2010-10-11 12:00:14.531 Session upkeep
. 2010-10-11 12:00:14.531 Looking for network events
. 2010-10-11 12:00:14.531 Timeout waiting for network events
. 2010-10-11 12:00:15.031 Session upkeep
. 2010-10-11 12:00:15.031 Looking for network events
. 2010-10-11 12:00:15.031 Timeout waiting for network events
. 2010-10-11 12:00:15.531 Session upkeep
. 2010-10-11 12:00:15.531 Looking for network events
. 2010-10-11 12:00:15.531 Timeout waiting for network events
. 2010-10-11 12:00:16.031 Session upkeep
. 2010-10-11 12:00:16.031 Looking for network events
. 2010-10-11 12:00:16.031 Timeout waiting for network events
. 2010-10-11 12:00:16.531 Session upkeep
. 2010-10-11 12:00:16.531 Looking for network events
. 2010-10-11 12:00:16.531 Timeout waiting for network events
. 2010-10-11 12:00:17.031 Session upkeep
. 2010-10-11 12:00:17.031 Looking for network events
. 2010-10-11 12:00:17.031 Timeout waiting for network events
. 2010-10-11 12:00:17.531 Session upkeep
. 2010-10-11 12:00:17.531 Looking for network events
. 2010-10-11 12:00:17.531 Timeout waiting for network events
. 2010-10-11 12:00:18.031 Session upkeep
. 2010-10-11 12:00:18.031 Looking for network events
. 2010-10-11 12:00:18.031 Timeout waiting for network events
. 2010-10-11 12:00:18.531 Session upkeep
. 2010-10-11 12:00:18.531 Looking for network events
. 2010-10-11 12:00:18.531 Timeout waiting for network events
. 2010-10-11 12:00:19.031 Session upkeep
. 2010-10-11 12:00:19.031 Looking for network events
. 2010-10-11 12:00:19.031 Timeout waiting for network events
. 2010-10-11 12:00:19.609 Session upkeep
. 2010-10-11 12:00:19.797 Looking for network events
. 2010-10-11 12:00:19.797 Timeout waiting for network events
. 2010-10-11 12:00:20.031 Session upkeep
. 2010-10-11 12:00:20.031 Looking for network events
. 2010-10-11 12:00:20.031 Timeout waiting for network events
. 2010-10-11 12:00:20.531 Session upkeep
. 2010-10-11 12:00:20.531 Looking for network events
. 2010-10-11 12:00:20.531 Timeout waiting for network events
. 2010-10-11 12:00:21.031 Session upkeep
. 2010-10-11 12:00:21.031 Looking for network events
. 2010-10-11 12:00:21.031 Timeout waiting for network events
. 2010-10-11 12:00:21.531 Session upkeep
. 2010-10-11 12:00:21.531 Looking for network events
. 2010-10-11 12:00:21.531 Timeout waiting for network events
. 2010-10-11 12:00:22.031 Session upkeep
. 2010-10-11 12:00:22.031 Looking for network events
. 2010-10-11 12:00:22.031 Timeout waiting for network events
. 2010-10-11 12:00:22.531 Session upkeep
. 2010-10-11 12:00:22.531 Looking for network events
. 2010-10-11 12:00:22.531 Timeout waiting for network events
. 2010-10-11 12:00:23.031 Session upkeep
. 2010-10-11 12:00:23.031 Looking for network events
. 2010-10-11 12:00:23.031 Timeout waiting for network events
. 2010-10-11 12:00:23.531 Session upkeep
. 2010-10-11 12:00:23.531 Looking for network events
. 2010-10-11 12:00:23.531 Timeout waiting for network events
. 2010-10-11 12:00:24.031 Session upkeep
. 2010-10-11 12:00:24.031 Looking for network events
. 2010-10-11 12:00:24.031 Timeout waiting for network events
. 2010-10-11 12:00:24.531 Session upkeep
. 2010-10-11 12:00:24.531 Looking for network events
. 2010-10-11 12:00:24.531 Timeout waiting for network events
. 2010-10-11 12:00:25.031 Session upkeep
. 2010-10-11 12:00:25.031 Looking for network events
. 2010-10-11 12:00:25.031 Timeout waiting for network events
. 2010-10-11 12:00:25.531 Session upkeep
. 2010-10-11 12:00:25.531 Looking for network events
. 2010-10-11 12:00:25.531 Timeout waiting for network events
. 2010-10-11 12:00:25.922 File: "/C:\/ISL_Transactions_20101008_000000.txt"
. 2010-10-11 12:00:25.922 Copying "/C:\/ISL_Transactions_20101008_000000.txt" to local directory started.
. 2010-10-11 12:00:25.922 Ascii transfer mode selected.
. 2010-10-11 12:00:25.922 Opening remote file.
> 2010-10-11 12:00:25.922 Type: SSH_FXP_OPEN, Size: 58, Number: 1283
> 2010-10-11 12:00:25.922 03,00,00,05,03,00,00,00,29,2F,43,3A,5C,2F,49,53,4C,5F,54,72,61,6E,73,61,63,
> 2010-10-11 12:00:25.922 74,69,6F,6E,73,5F,32,30,31,30,31,30,30,38,5F,30,30,30,30,30,30,2E,74,78,74,
> 2010-10-11 12:00:25.922 00,00,00,01,00,00,00,00,
. 2010-10-11 12:00:25.922 Sent 62 bytes
. 2010-10-11 12:00:25.922 There are 0 bytes remaining in the send buffer
. 2010-10-11 12:00:25.922 Looking for network events
. 2010-10-11 12:00:25.922 Timeout waiting for network events
. 2010-10-11 12:00:25.922 Read 4 bytes (21 pending)
. 2010-10-11 12:00:25.922 Read 21 bytes (0 pending)
< 2010-10-11 12:00:25.922 Type: SSH_FXP_STATUS, Size: 21, Number: 1028
< 2010-10-11 12:00:25.922 65,00,00,04,04,00,00,00,00,00,00,00,02,4F,4B,00,00,00,02,65,6E,
. 2010-10-11 12:00:25.922 Discarding reserved response
. 2010-10-11 12:00:25.922 Waiting for another 4 bytes
. 2010-10-11 12:00:25.922 Looking for incoming data
. 2010-10-11 12:00:25.938 Detected network event
. 2010-10-11 12:00:25.938 Enumerating network events for socket 484
. 2010-10-11 12:00:25.938 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:25.938 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:25.938 Received 5 bytes (0)
. 2010-10-11 12:00:25.938 Received 16 bytes (0)
. 2010-10-11 12:00:25.938 Read 4 bytes (17 pending)
. 2010-10-11 12:00:25.938 Read 17 bytes (0 pending)
< 2010-10-11 12:00:25.938 Type: SSH_FXP_HANDLE, Size: 17, Number: 1283
< 2010-10-11 12:00:25.938 66,00,00,05,03,00,00,00,08,00,7F,F9,48,00,80,2B,40,
> 2010-10-11 12:00:25.938 Type: SSH_FXP_FSTAT, Size: 17, Number: 1544
> 2010-10-11 12:00:25.938 08,00,00,06,08,00,00,00,08,00,7F,F9,48,00,80,2B,40,
. 2010-10-11 12:00:25.938 Sent 21 bytes
. 2010-10-11 12:00:25.938 There are 0 bytes remaining in the send buffer
. 2010-10-11 12:00:25.938 Looking for network events
. 2010-10-11 12:00:25.938 Timeout waiting for network events
> 2010-10-11 12:00:25.938 Type: SSH_FXP_READ, Size: 29, Number: 1797
> 2010-10-11 12:00:25.938 05,00,00,07,05,00,00,00,08,00,7F,F9,48,00,80,2B,40,00,00,00,00,00,00,00,00,
> 2010-10-11 12:00:25.938 00,00,0F,F3,
. 2010-10-11 12:00:25.938 Sent 33 bytes
. 2010-10-11 12:00:25.938 Waiting for another 4 bytes
. 2010-10-11 12:00:25.938 Looking for incoming data
. 2010-10-11 12:00:25.938 Received 12 bytes (0)
. 2010-10-11 12:00:25.938 Read 4 bytes (29 pending)
. 2010-10-11 12:00:25.938 Read 29 bytes (0 pending)
< 2010-10-11 12:00:25.938 Type: SSH_FXP_ATTRS, Size: 29, Number: 1544
< 2010-10-11 12:00:25.938 69,00,00,06,08,00,00,00,0D,00,00,00,00,00,00,01,9D,00,00,81,80,4C,B2,BB,F0,
< 2010-10-11 12:00:25.938 4C,B2,BB,F0,
. 2010-10-11 12:00:25.938 Storing reserved response
. 2010-10-11 12:00:25.953 Detected network event
. 2010-10-11 12:00:25.953 Enumerating network events for socket 484
. 2010-10-11 12:00:25.953 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:25.953 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:25.953 Waiting for another 4 bytes
. 2010-10-11 12:00:25.953 Looking for incoming data
. 2010-10-11 12:00:25.953 Looking for network events
. 2010-10-11 12:00:25.953 Received 5 bytes (0)
. 2010-10-11 12:00:25.953 Received 8 bytes (0)
. 2010-10-11 12:00:25.953 Read 4 bytes (9 pending)
. 2010-10-11 12:00:25.953 Waiting for another 413 bytes
. 2010-10-11 12:00:25.953 Received 16 bytes (0)
. 2010-10-11 12:00:25.953 Received 32 bytes (0)
. 2010-10-11 12:00:25.953 Received 64 bytes (0)
. 2010-10-11 12:00:25.953 Waiting for another 301 bytes
. 2010-10-11 12:00:25.953 Received 128 bytes (0)
. 2010-10-11 12:00:25.953 Received 173 bytes (0)
. 2010-10-11 12:00:25.953 Read 422 bytes (0 pending)
< 2010-10-11 12:00:25.953 Type: SSH_FXP_DATA, Size: 422, Number: 1797
< 2010-10-11 12:00:25.953 67,00,00,07,05,00,00,01,9D,50,53,50,5F,41,63,63,6F,75,6E,74,5F,43,6F,64,65,
< 2010-10-11 12:00:25.953 7C,44,61,74,65,5F,41,63,74,69,6F,6E,7C,44,61,74,65,5F,54,72,61,6E,73,61,63,
< 2010-10-11 12:00:25.953 74,69,6F,6E,7C,44,65,73,63,72,69,70,74,69,6F,6E,7C,54,72,61,6E,73,61,63,74,
< 2010-10-11 12:00:25.953 69,6F,6E,5F,54,79,70,65,7C,43,47,54,5F,41,6D,6F,75,6E,74,7C,41,6D,6F,75,6E,
< 2010-10-11 12:00:25.953 74,7C,4E,61,72,72,61,74,69,76,65,7C,50,72,6F,76,69,64,65,72,7C,43,75,72,72,
< 2010-10-11 12:00:25.953 65,6E,63,79,7C,52,65,66,65,72,65,6E,63,65,7C,51,75,61,6E,74,69,74,79,7C,50,
< 2010-10-11 12:00:25.953 72,69,63,65,7C,42,72,6F,6B,65,72,5F,46,65,65,73,7C,54,72,61,64,65,5F,43,6F,
< 2010-10-11 12:00:25.953 73,74,73,7C,47,72,6F,73,73,5F,41,6D,6F,75,6E,74,7C,50,53,50,5F,49,6E,73,74,
< 2010-10-11 12:00:25.953 72,75,6D,65,6E,74,5F,43,6F,64,65,7C,50,53,50,5F,49,6E,73,74,72,75,6D,65,6E,
< 2010-10-11 12:00:25.953 74,5F,4E,61,6D,65,0A,31,33,33,33,37,36,34,7C,30,38,20,4F,63,74,20,32,30,31,
< 2010-10-11 12:00:25.953 30,7C,30,38,20,4F,63,74,20,32,30,31,30,7C,44,49,56,2E,20,31,30,30,20,43,49,
< 2010-10-11 12:00:25.953 50,4C,41,4D,45,44,20,20,20,20,20,20,20,20,20,20,20,20,20,20,20,20,20,20,20,
< 2010-10-11 12:00:25.953 20,20,20,20,7C,44,56,7C,7C,2D,35,2E,30,30,30,30,30,30,7C,44,49,56,2E,20,31,
< 2010-10-11 12:00:25.953 30,30,20,43,49,50,4C,41,4D,45,44,20,20,20,20,20,20,20,20,20,20,20,20,20,20,
< 2010-10-11 12:00:25.953 20,20,20,20,20,20,20,20,20,7C,37,34,33,31,35,7C,5A,41,52,7C,7C,2E,30,30,30,
< 2010-10-11 12:00:25.953 30,30,30,7C,31,2E,30,30,30,30,30,30,7C,2E,30,30,30,30,30,30,7C,2E,30,30,30,
< 2010-10-11 12:00:25.953 30,30,30,7C,2E,30,30,30,30,30,30,7C,43,61,73,68,7C,43,61,73,68,0A,
> 2010-10-11 12:00:25.953 Type: SSH_FXP_READ, Size: 29, Number: 2053
> 2010-10-11 12:00:25.953 05,00,00,08,05,00,00,00,08,00,7F,F9,48,00,80,2B,40,00,00,00,00,00,00,0F,F3,
> 2010-10-11 12:00:25.953 00,00,0F,F3,
. 2010-10-11 12:00:25.953 Sent 33 bytes
. 2010-10-11 12:00:25.953 There are 0 bytes remaining in the send buffer
. 2010-10-11 12:00:25.953 Timeout waiting for network events
. 2010-10-11 12:00:25.953 Read 9 bytes (0 pending)
< 2010-10-11 12:00:25.953 Type: SSH_FXP_DATA, Size: 9, Number: 2053
< 2010-10-11 12:00:25.953 67,00,00,08,05,00,00,00,00,
> 2010-10-11 12:00:25.953 Type: SSH_FXP_READ, Size: 29, Number: 2309
> 2010-10-11 12:00:25.953 05,00,00,09,05,00,00,00,08,00,7F,F9,48,00,80,2B,40,00,00,00,00,00,00,1F,E6,
. 2010-10-11 12:00:25.953 Received incomplete data packet before end of file, offset: 413, size: 413, requested: 4083
. 2010-10-11 12:00:25.969 Waiting for another 4 bytes
. 2010-10-11 12:00:25.969 Looking for incoming data
. 2010-10-11 12:00:25.969 Looking for network events
. 2010-10-11 12:00:25.969 Detected network event
. 2010-10-11 12:00:25.969 Enumerating network events for socket 484
. 2010-10-11 12:00:25.969 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:25.969 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:25.969 Received 5 bytes (0)
. 2010-10-11 12:00:25.969 Read 4 bytes (1 pending)
. 2010-10-11 12:00:25.969 Waiting for another 8 bytes
. 2010-10-11 12:00:25.969 Received 8 bytes (0)
. 2010-10-11 12:00:25.969 Read 9 bytes (0 pending)
< 2010-10-11 12:00:25.969 Type: SSH_FXP_DATA, Size: 9, Number: 2309
< 2010-10-11 12:00:25.969 67,00,00,09,05,00,00,00,00,
> 2010-10-11 12:00:25.969 Type: SSH_FXP_CLOSE, Size: 17, Number: 2564
> 2010-10-11 12:00:25.969 04,00,00,0A,04,00,00,00,08,00,7F,F9,48,00,80,2B,40,
. 2010-10-11 12:00:25.969 Sent 21 bytes
. 2010-10-11 12:00:25.969 There are 0 bytes remaining in the send buffer
. 2010-10-11 12:00:25.969 Timeout waiting for network events
* 2010-10-11 12:00:25.969 (ECommand) Copying files from remote side failed.
* 2010-10-11 12:00:25.969 Received incomplete data packet before end of file.
. 2010-10-11 12:00:26.031 Session upkeep
. 2010-10-11 12:00:26.031 Looking for network events
. 2010-10-11 12:00:26.031 Detected network event
. 2010-10-11 12:00:26.031 Enumerating network events for socket 484
. 2010-10-11 12:00:26.031 Enumerated 1 network events making 1 cumulative events for socket 484
. 2010-10-11 12:00:26.031 Handling network read event on socket 484 with error 0
. 2010-10-11 12:00:26.031 Received 5 bytes (0)
. 2010-10-11 12:00:26.031 Received 8 bytes (0)
. 2010-10-11 12:00:26.031 Received 12 bytes (0)
. 2010-10-11 12:00:26.531 Session upkeep
. 2010-10-11 12:00:26.531 Looking for network events
. 2010-10-11 12:00:26.531 Timeout waiting for network events
. 2010-10-11 12:00:27.031 Session upkeep
. 2010-10-11 12:00:27.031 Looking for network events
. 2010-10-11 12:00:27.031 Timeout waiting for network events
. 2010-10-11 12:00:27.531 Session upkeep
. 2010-10-11 12:00:27.531 Looking for network events
. 2010-10-11 12:00:27.531 Timeout waiting for network events
. 2010-10-11 12:00:28.031 Session upkeep
. 2010-10-11 12:00:28.031 Looking for network events
. 2010-10-11 12:00:28.031 Timeout waiting for network events
. 2010-10-11 12:00:28.531 Session upkeep
. 2010-10-11 12:00:28.531 Looking for network events
. 2010-10-11 12:00:28.531 Timeout waiting for network events
. 2010-10-11 12:00:29.031 Session upkeep
. 2010-10-11 12:00:29.031 Looking for network events
. 2010-10-11 12:00:29.031 Timeout waiting for network events
. 2010-10-11 12:00:29.531 Session upkeep
. 2010-10-11 12:00:29.531 Looking for network events
. 2010-10-11 12:00:29.531 Timeout waiting for network events
. 2010-10-11 12:00:30.031 Session upkeep
. 2010-10-11 12:00:30.031 Looking for network events
. 2010-10-11 12:00:30.031 Timeout waiting for network events
. 2010-10-11 12:00:30.531 Session upkeep
. 2010-10-11 12:00:30.531 Looking for network events
. 2010-10-11 12:00:30.531 Timeout waiting for network events
. 2010-10-11 12:00:31.047 Session upkeep
. 2010-10-11 12:00:31.047 Looking for network events
. 2010-10-11 12:00:31.047 Timeout waiting for network events
. 2010-10-11 12:00:31.531 Session upkeep
. 2010-10-11 12:00:31.531 Looking for network events
. 2010-10-11 12:00:31.531 Timeout waiting for network events
. 2010-10-11 12:00:32.031 Session upkeep
. 2010-10-11 12:00:32.031 Looking for network events
. 2010-10-11 12:00:32.031 Timeout waiting for network events
. 2010-10-11 12:00:32.531 Session upkeep
. 2010-10-11 12:00:32.531 Looking for network events
. 2010-10-11 12:00:32.531 Timeout waiting for network events
. 2010-10-11 12:00:33.031 Session upkeep
. 2010-10-11 12:00:33.031 Looking for network events
. 2010-10-11 12:00:33.031 Timeout waiting for network events
. 2010-10-11 12:00:33.531 Session upkeep
. 2010-10-11 12:00:33.531 Looking for network events
. 2010-10-11 12:00:33.531 Timeout waiting for network events
. 2010-10-11 12:00:34.031 Session upkeep
. 2010-10-11 12:00:34.031 Looking for network events
. 2010-10-11 12:00:34.031 Timeout waiting for network events
. 2010-10-11 12:00:34.531 Session upkeep
. 2010-10-11 12:00:34.531 Looking for network events
. 2010-10-11 12:00:34.531 Timeout waiting for network events
. 2010-10-11 12:00:36.203 Session upkeep
. 2010-10-11 12:00:36.203 Looking for network events
. 2010-10-11 12:00:36.203 Timeout waiting for network events
. 2010-10-11 12:00:36.532 Session upkeep
. 2010-10-11 12:00:36.532 Looking for network events
. 2010-10-11 12:00:36.532 Timeout waiting for network events
. 2010-10-11 12:00:37.032 Session upkeep
. 2010-10-11 12:00:37.032 Looking for network events
. 2010-10-11 12:00:37.032 Timeout waiting for network events
. 2010-10-11 12:00:37.532 Session upkeep
. 2010-10-11 12:00:37.532 Looking for network events
. 2010-10-11 12:00:37.532 Timeout waiting for network events
. 2010-10-11 12:00:38.032 Session upkeep
. 2010-10-11 12:00:38.032 Looking for network events
. 2010-10-11 12:00:38.032 Timeout waiting for network events
. 2010-10-11 12:00:38.532 Session upkeep
. 2010-10-11 12:00:38.532 Looking for network events
. 2010-10-11 12:00:38.532 Timeout waiting for network events
. 2010-10-11 12:00:39.032 Session upkeep
. 2010-10-11 12:00:39.032 Looking for network events
. 2010-10-11 12:00:39.032 Timeout waiting for network events
. 2010-10-11 12:00:39.532 Session upkeep
. 2010-10-11 12:00:39.532 Looking for network events
. 2010-10-11 12:00:39.532 Timeout waiting for network events
. 2010-10-11 12:00:40.032 Session upkeep
. 2010-10-11 12:00:40.032 Looking for network events
. 2010-10-11 12:00:40.032 Timeout waiting for network events
. 2010-10-11 12:00:40.532 Session upkeep
. 2010-10-11 12:00:40.532 Looking for network events
. 2010-10-11 12:00:40.532 Timeout waiting for network events
. 2010-10-11 12:00:41.032 Session upkeep
. 2010-10-11 12:00:41.032 Looking for network events
. 2010-10-11 12:00:41.032 Timeout waiting for network events
. 2010-10-11 12:00:41.532 Session upkeep
. 2010-10-11 12:00:41.532 Looking for network events
. 2010-10-11 12:00:41.532 Timeout waiting for network events
. 2010-10-11 12:00:42.032 Session upkeep
. 2010-10-11 12:00:42.032 Looking for network events
. 2010-10-11 12:00:42.032 Timeout waiting for network events
. 2010-10-11 12:00:42.532 Session upkeep
. 2010-10-11 12:00:42.797 Looking for network events
. 2010-10-11 12:00:42.797 Timeout waiting for network events
. 2010-10-11 12:00:43.032 Session upkeep
. 2010-10-11 12:00:43.032 Looking for network events
. 2010-10-11 12:00:43.032 Timeout waiting for network events
. 2010-10-11 12:00:43.532 Session upkeep
. 2010-10-11 12:00:43.532 Looking for network events
. 2010-10-11 12:00:43.532 Timeout waiting for network events
. 2010-10-11 12:00:44.032 Session upkeep
. 2010-10-11 12:00:44.032 Looking for network events
. 2010-10-11 12:00:44.032 Timeout waiting for network events
. 2010-10-11 12:00:44.532 Session upkeep
. 2010-10-11 12:00:44.532 Looking for network events
. 2010-10-11 12:00:44.532 Timeout waiting for network events
. 2010-10-11 12:00:45.032 Session upkeep
. 2010-10-11 12:00:45.032 Looking for network events
. 2010-10-11 12:00:45.032 Timeout waiting for network events
. 2010-10-11 12:00:45.532 Session upkeep
. 2010-10-11 12:00:45.532 Looking for network events
. 2010-10-11 12:00:45.532 Timeout waiting for network events
. 2010-10-11 12:00:46.032 Session upkeep
. 2010-10-11 12:00:46.032 Looking for network events
. 2010-10-11 12:00:46.032 Timeout waiting for network events
. 2010-10-11 12:00:46.532 Session upkeep
. 2010-10-11 12:00:46.532 Looking for network events
. 2010-10-11 12:00:46.532 Timeout waiting for network events
. 2010-10-11 12:00:47.032 Session upkeep
. 2010-10-11 12:00:47.032 Looking for network events
. 2010-10-11 12:00:47.032 Timeout waiting for network events
. 2010-10-11 12:00:47.532 Session upkeep
. 2010-10-11 12:00:47.532 Looking for network events
. 2010-10-11 12:00:47.532 Timeout waiting for network events
. 2010-10-11 12:00:48.032 Session upkeep
. 2010-10-11 12:00:48.032 Looking for network events
. 2010-10-11 12:00:48.032 Timeout waiting for network events
. 2010-10-11 12:00:48.532 Session upkeep
. 2010-10-11 12:00:48.532 Looking for network events
. 2010-10-11 12:00:48.532 Timeout waiting for network events
. 2010-10-11 12:00:49.032 Session upkeep
. 2010-10-11 12:00:49.032 Looking for network events
. 2010-10-11 12:00:49.032 Timeout waiting for network events
. 2010-10-11 12:00:49.532 Session upkeep
. 2010-10-11 12:00:49.532 Looking for network events
. 2010-10-11 12:00:49.532 Timeout waiting for network events
. 2010-10-11 12:00:50.032 Session upkeep
. 2010-10-11 12:00:50.032 Looking for network events
. 2010-10-11 12:00:50.032 Timeout waiting for network events
. 2010-10-11 12:00:50.532 Session upkeep
. 2010-10-11 12:00:50.532 Looking for network events
. 2010-10-11 12:00:50.532 Timeout waiting for network events
. 2010-10-11 12:00:51.032 Session upkeep
. 2010-10-11 12:00:51.032 Looking for network events
. 2010-10-11 12:00:51.032 Timeout waiting for network events
. 2010-10-11 12:00:51.532 Session upkeep
. 2010-10-11 12:00:51.532 Looking for network events
. 2010-10-11 12:00:51.532 Timeout waiting for network events
. 2010-10-11 12:00:52.032 Session upkeep
. 2010-10-11 12:00:52.032 Looking for network events
. 2010-10-11 12:00:52.032 Timeout waiting for network events
. 2010-10-11 12:00:52.532 Session upkeep
. 2010-10-11 12:00:52.532 Looking for network events
. 2010-10-11 12:00:52.532 Timeout waiting for network events
. 2010-10-11 12:00:53.032 Session upkeep
. 2010-10-11 12:00:53.032 Looking for network events
. 2010-10-11 12:00:53.032 Timeout waiting for network events
. 2010-10-11 12:00:53.532 Session upkeep
. 2010-10-11 12:00:53.532 Looking for network events
. 2010-10-11 12:00:53.532 Timeout waiting for network events
. 2010-10-11 12:00:54.032 Session upkeep
. 2010-10-11 12:00:54.032 Looking for network events
. 2010-10-11 12:00:54.032 Timeout waiting for network events
. 2010-10-11 12:00:54.532 Session upkeep
. 2010-10-11 12:00:54.532 Looking for network events
. 2010-10-11 12:00:54.532 Timeout waiting for network events
. 2010-10-11 12:00:55.032 Session upkeep
. 2010-10-11 12:00:55.032 Looking for network events
. 2010-10-11 12:00:55.032 Timeout waiting for network events
. 2010-10-11 12:00:55.532 Session upkeep
. 2010-10-11 12:00:55.532 Looking for network events
. 2010-10-11 12:00:55.532 Timeout waiting for network events
