Master password makes WinSCP open in the background
zero
I just set up a master password to secure some passwords I stored within WinSCP.
When I start WinSCP, I get the regular Login dialog.
When I open a site with a set password I get prompted for the master password.
Ok so far. When the password is correctly entered WinSCP opens but now it opens in the background. Without a master password the program was directly in the foreground, focussed, ready to use.
Could this be changed so that it opens in the foreground with a master password, too?
Re: Master password makes WinSCP open in the background
Sorry for late answer. I wasn't able to reproduce your problem. What version of Windows are you using? What version of WinSCP? Can you try the latest version?
