Copy Files from PC in more folders on server by one step
Nicosia
Hello. I would like to copy different files from my PC to Server by drag & drop for excample in 2 folders in one time.
Example: 4 files to copy by one step in folder Test1 and Test2
I need this, because i have on my server different folders with the same contents.
Maybe any of u could explain me? Thanks. [/img]
Re: Copy Files from PC in more folders on server by one step
You cannot do this with drag&drop. You may set up script for this if you do the same operation frequently.
Nicosia
Thank you for your answer.
Ok, that is not so good because the files an folders change every time...
Ok, I hope for the future :lol:
