Transfer of file with filesize 0
Juergen Wiedemann
when trying to transfer a file with filesize=0 from w2k to solaris 9 (sparc) using winscp 3.4.2. (Build 197) I receive an error "EAccessViolation". Everything else works fine. Thank you for help.
Regards,
Juergen
Re: Transfer of file with filesize 0
This is known bug. It happens for upload of empty file in text (ASCII) mode only. It will be fixed in next version (this week).
Juergen Wiedemann
Thank you very much. Juergen
deoren
Hey Guys,
It might not be of much help, but I was having that problem when using SCP to copy empty ASCII files. When I switched to SFTP it went away.
The problem described above affects both SCP and SFTP. You have probably other problem. Let me know if your have further details on this.
