Invalid access to memory - when use scripting
joujoujou
Hi again.
Already asked for help with scripting, got the answer, but unfortunately not solved totally.
WinSCP 4.2.8 (same problem when used 4.2.7), XP professional SP3 (EN).
My previous thread - https://winscp.net/forum/viewtopic.php?t=8815
Currently used command (batch file):
@ECHO OFF
@ECHO Odpalamy FTP... :-)
@PING 1.1.1.1 -n 1 -w 10000 >NUL
@START C:"\Documents and Settings\joujoujou\Desktop\Pulpitt\winscp\WinSCP.exe" /console /script=C:"\Documents and Settings\joujoujou\Desktop\Pulpitt\winscp\test.txt"
Script:
option batch on
option reconnecttime 1
open user@domain.com
synchronize remote
keepuptodate C:"\Program Files\Cumulus\web" /var/www/domain.com/htdocs/weather
Note: user and domain details changed to keep some privacy. ;)
Problem exists only when use scripts - in GUI mode all is working O.K.
I'd rather prefer not to publish log I've saved.
Would be glad to email it, or somehow like that.
Thank you.
serendipity
France
Re: Invalid access to memory - when use scripting
Hi, i'm facing the same problem. Happy to know it's fixed, but when 4.2.9 will be released?
Thanks.
joujoujou wrote:
Hi again.
@ECHO OFF
Script:
option batch on
synchronize remote
Thank you.
peterj
Melbourne, Australia
Thanks.
I too am suffering from this problem, although it appears to be both in the interactive command line mode and running a script. Can you advise when the next release will be ou as this is affecting a production system now.
Regards,
P
joujoujou wrote:
Exactly the same when running winscp 4.29.
