Cannot create remote directory using sync browsing
peterbay
Dublin
I have this probelm below. It only appears sometimes and other times it works perfectly.
When I have sync browsing on and I click into a folder on the left panel that does not appear on the right WinSCP gives me this message
Cannot open corresponding directory in the opposite panel.
Do you want to try to create directory '/home/content/newfolder'?
Error changing directory to '/home/content/newfolder'.
Error listing directory '/home/content/newfolder'.
No such file or directory.
Error code: 2
Error message from server: No such file
Request code: 11
It gives me the options Yes, No, Help
After clicking Yes I get the following message
Error creating folder 'home/content/newfolder'.
Error code: 2
Request code: 14
After I click ok I get imformed that Directory Browsing failed and it has been turned off.
I am using WinSCP version 4.2.8 (Build 818).
This happens about 50% of the time.
Any ideas what could be wrong or at least where I could maybe see logs or something which may help me solve the problem.
Pete
Re: Cannot create remote directory using sync browsing
peterbay
Dublin
Sorry for the delay in replying
Here is the log of the event.
Cached directory change via "/home/content/www/mysite/new-folder" to "/home/content/www/mysite/new-folder".
Getting current directory name.
Listing directory "/home/content/www/mysite/new-folder".
Type: SSH_FXP_OPENDIR, Size: 68, Number: 94731
Type: SSH_FXP_STATUS, Size: 29, Number: 94731
Status code: 2, Message: 94731, Server: No such file, Language:
Creating directory "/home/content/www/mysite/new-folder/new-folder".
Canonifying: "/home/content/www/mysite/new-folder/new-folder"
Getting real path for '/home/content/www/mysite/new-folder/new-folder'
Type: SSH_FXP_REALPATH, Size: 93, Number: 95248
Type: SSH_FXP_STATUS, Size: 29, Number: 95248
Status code: 2, Message: 95248, Server: No such file, Language:
Getting real path for '/home/content/www/mysite/new-folder/'
Type: SSH_FXP_REALPATH, Size: 69, Number: 95504
Type: SSH_FXP_STATUS, Size: 29, Number: 95504
Status code: 2, Message: 95504, Server: No such file, Language:
Canonified: "/home/content/www/mysite/new-folder/new-folder"
Type: SSH_FXP_MKDIR, Size: 97, Number: 94990
Type: SSH_FXP_STATUS, Size: 29, Number: 94990
Status code: 2, Message: 94990, Server: No such file, Language:
(ECommand) Error creating folder '/home/content/www/mysite/new-folder/new-folder'.
Error code: 2
Request code: 14
This is all during synchronised browsing.
When I am opening the folder 'new-folder' it asks me do I want to create it on the opposite panel and then it tries to create it in a folder (same name) which does not exist.
Hence I get error (in the form of a windows alert).
Error
Error code: 2
Request code: 14
OK Help
Thanks very much
I believe I've sent ou and email. If you haven't received it, can you send me an email yourself, so I can send you back a debug version of WinSCP to track the problem? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
