How show only Percent in batch?
kschweitzer
i use a command like this winscp.com /command "option confirm off" ... for the transfer and get this result.
Searching for host...
Connecting to host...
Authenticating...
Using username "kschweitzer".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] kschweitzer@192.168.1.8
/cygdrive/d
C:\...\K.zip | 31 KiB | 292,9 KiB/s | binary | 100%
But, i need only the status line of the transfering. How can i do this?
Thanks for the help, Kevin
Re: How show only Percent in batch?
You cannot do this with WinSCP. Though you can filter its output with another tool/script.
