- smurphy8564
- 2
- Not sure what this is
Using WinSCP to upload from Windows XP to IBM mainframe.
Just a general questions. Should I be able to use WinSCP to transfer files from my Windows XP box to an IBM Mainframe where the directory strings look something like this: TEST.ASU.AGENCY123.INPUT ??? I get an error that says no such directory found. (or something like that) Thanks.
One more thing about the last post.
I read a posing somewhere that said that WinSCP does not support IBM mainframe directory strings. Is that true??
Site Admin -
- 42,969
- Prague, Czechia
Yes. That is true.
- TimThackerISF
- 1
- Florida
I saw that the answer was from 2010 and was wondering if it was still an issue with the directory names from IBM mainframe. I can get connected but can't get the remote directory to change to the correct path. It works in Filezilla but I wanted to use the automated C# library. Is it possible to read IBM mainframe directory strings?
Tim
Tim
Site Admin -
- 42,969
- Prague, Czechia
Re: IBM mainframe directory strings
There's no update yet.I saw that the answer was from 2010 and was wondering if it was still an issue with the directory names from IBM mainframe. I can get connected but can't get the remote directory to change to the correct path. It works in Filezilla but I wanted to use the automated C# library. Is it possible to read IBM mainframe directory strings?
May I get a test account on your server?
orlando.colamatteo
any updates?
I am trying to do the same thing with an IBM mainframe and am not able to download a file named as
'filename(0).blah'
I am assuming the name is resolved on the mainframe side but the ftp WinSCP component must have something to do with it because I can download it using the .NET WebCLient class.
'filename(0).blah'
Site Admin -
- 42,969
- Prague, Czechia
Re: any updates?
Please attach a full log file showing the problem (using the latest version of WinSCP).I am assuming the name is resolved on the mainframe side but the ftp WinSCP component must have something to do with it because I can download it using the .NET WebCLient class.
pasha-hef3
WinSCP ftp tls-explicit encrypted connection to a mainframe
Hi, I cannot display a directory listing when I connect to an IBM mainframe from Windows 7 with WinSCP using FTP protocol with TLS explicit encryption. Is it still true that WinSCP does not support IBM mainframe directory strings?
Thanks!
Thanks!
Site Admin -
Re: WinSCP ftp tls-explicit encrypted connection to a mainframe
Yes.Hi, I cannot display a directory listing when I connect to an IBM mainframe from Windows 7 with WinSCP using FTP protocol with TLS explicit encryption. Is it still true that WinSCP does not support IBM mainframe directory strings?
Ada
May I have a update?
May I have a update for the WinSCP to support MainFrame either by SFTP or FTPS in April, 2017?
Thanks.
Thanks.
Site Admin -
- 42,969
- Prague, Czechia
Re: May I have a update?
There were some small improvements. But in general, it's still not supported.May I have a update for the WinSCP to support MainFrame either by SFTP or FTPS in April, 2017?
Thanks.
ven6329
can i change Listing directory in main frames ?
I am trying to change Listing directory in mainframes.i am getting the error as no such directory found
My LS CMD
"ls /+mode=text,clientcp=ISO8859-1,servercp=IBM-1047","ls /+lrecl=921,blksize=27630,recfm=VB,space=cyl.4000.40.release"
is this work ?
My LS CMD
is this work ?
