add sudo parameter to command line winscp
jsimmon
I need to add "sudo su -" command to command line execution of winscp in order to put it in a batch file. I know how to accomplish that in GUI, but i need it in command line mode.
Looking at winscp.ini file I see this option in a saved session where sudo is enabled:
[Sessions\remoteUsr@remoteServer]
HostName=linuxdev04.servizi.infogroup.it
UserName=name
FSProtocol=0
LocalDirectory=C:%5C
RemoteDirectory=/opt/remoteUsr
Shell=sudo%20su%20-%20remoteUsr
Color=13408767
How can i add to "Shell=..." as a command line parameter? I don't want to use saved session for portability reason.
Re: add sudo parameter to command line winscp
There's no other way. I believe that using stored session in an INI file is portable.
jsimmon
Thanks for your reply.
I think that INI file portability is at least questionable, but I understand that at present that's it.
I hope in future versions you will add parameters to command line execution to enhance scripting capability of WinSCP, at least to match GUI's settings.
jsimmon
Hi again,
I also tried to put sudo command as first statement in the script launched by
winscp.com user:pwd@host /script="transfer.txt":
with transfer.txt content as follows:
call sudo su - otherUser
cd lib
mkdir %1%
mv *.jar %1%
lcd %2%
put *.jar ./
getting this result:
Automatic actions are disabled when URL address is provided on command-line.
Searching for host...
Connecting to host...
Authenticating...
Using username "user".
Authenticated.
Starting the session...
Error looking up user groups.
Command 'groups'
failed with return code 127 and error message
groups : command not allowed.
Reading remote directory...
Session started.
Instead, if I try doing the same with
and then manually writing the command "call sudo su - otherUser" I get this error after 15 seconds delay:
Host is not communicating for more than 15 seconds. Still waiting...
Warning: Aborting this operation will close connection!
(A)bort:
kidata
Germany
You cannot execute commands that require user input.
Is it still not possible to send user inputs?
We also need to work with sudo and have to send the password, when it's asked for.
It's technically not possible. So it never will.
lionking
I have this timeout too.
My sudo does not need user input, why i have this timeout of 15 seconds?
What is the best workarround?
MrWade
Did this get solved?
I have a script that calls "sudo su - username" which is password-less and has no user input. However, the script when executed (including on PLINK) shows "[YOU HAVE NEW MAIL]" and doesn't skip pass this point. Any ideas?
Re: Did this get solved?
Please start a new thread. Show us some logs, outputs and screenshots; and try harder explaining your problem.
