Add number of bytes stransferred to log file
trybik
would it be possible to log an information about a number of bytes transferred? Right now there is an information that copying is started, like this:
. 2010-03-29 12:04:02.650 Copying "T:\MT1030123.TXT" to remote directory started.
. 2010-03-29 12:04:02.650 Binary transfer mode selected.
But there's no clear "end of copying" information. I'd like to have something like "File transfer complete, 123456 bytes transferred". This would make it clear about what happened in the past.
Re: Add number of bytes stransferred to log file
The plain text log is for debugging only. You can use XML logging instead.
Request to log bytes transferred has been added to tracker.
The latest version of WinSCP logs something like this at the end of every transfer:
. 2020-03-18 10:58:24.262 Transfer done: 'C:\source\file.txt' => '/target/file.txt' [1024]
