Disconnects after 30 minutes regardless of activity.
jsherk
United States
What is the default disconnect time?
Is it set by WinSCP or by the server to which we are connected?
I am having an issue, where WinSCP will disconnect after 30 to 35 minutes regardless of any activity that just occured. At 29 minutes I changed to a new directory and a couple minutes later it still disconnected. Also, it will even disconnect in the middle of a file transfer. I was in the middle of also transferring file during the above times and it still disconnected.
This is reproduceable every time I use WinSCP v4.2.8 on Win XP Pro sp3.
Even if keepalives are set to either Sending NULL SSH packets or Executing Dummy Protocol Commands, it will still disconnect after 30-35 minutes.
Re: Disconnects after 30 minutes regardless of activity.
WinSCP never disconnectes automatically. It has to be your server that does it.
jsherk
United States
Ok I will look into it on the server side.
Just as a side note though, I never had this issue when I used FileZilla, so I am not sure why it would disconnect WinSCP.
jsherk
United States
SOLVED
Ok, it turns out that my webhost has a firewall, and it will disconnect anything that has been connected for 30+ minutes regardless of activity. They said they are actually in the process of replacing it anyways this week, so it should not be an issue anymore.
And a secondary note, I checked FileZilla again, and it is also disconnected after 30 minutes... the reason I never noticed, is that FileZilla will remember the password I used earlier and reconnect automatically.
