Synchronize inside script
mapmusic
Here is part of my WinSCP script.
cd /Clips
lcd d:\clips
synchronize local -delete -speed=10240
I think after this script remote files should be deleted.
But files remains in remote dir.
I need to delete these after successfull transfer.
Thanks for tips
Martin
mapmusic
Bratislava, SLovakia
Re: Synchronize inside script
You probably want to do:
get -delete -speed=10240
I use synchronize because I need to copy only files which are not in local directory.
M.
OK, but you are misusing synchronization then. As synchronization aims to end with synchronized directories, not with one of the directoeries being empty.
Anyway, you can use synchronization and remove the remote directory once synchronization ends.
