copying files: fatally failed
drotte
I can log on to server fine, navigate around, etc. But when I copy a file it either hangs the program or finishes the xfer and gives the following error:
Copying file 'D:\MYDOCS\myfile.rar' fatally failed.
Network error: Connection reset by peer
Then the program crashes. Here's the last few lines of the log:
. SCP remote side confirmation (0)
. Sending BINARY data (first block)
. Network error: Connection reset by peer
* (ESshFatal) Copying files to remote side failed.
* (EAccessViolation) EAccessViolation
This is odd because I was using winSCP for a long while with no problems to this same host.
Re: copying files: fatally failed
  • Do you know of any configuration changes on your server?
  • Have you tried latest version of WinSCP: 2.1?
Yes, using latest version, winSCP 2.1
I do not know of any changes myself but I can try getting a hold of the operator. Any ideas on things to try in the meantime?
So please try 2.0 too.
You may try different shell.
Tried that, same exact problem.
Tried the options there, same troubles. When I start a transfer of anything over say 100kb, the program locks up (can't minimize, can't drag windows around), and if I hit cancel, windows tells me program not responding and it bombs. If I touch nothing, it goes ahead and xfers the whole file but then bombs at the end with that same timeout/connection reset by peer error.
Perhaps my troubles are related to my platform, win2kpro? Just an idea, I have no idea what I'm talking about :)
