WinSCP "Clean Up" tool
ashugg-epits
Perth, Western Australia
Please consider adding a method in the "Tools..." -> "Clean Up..." window to remove
shortcuts created via the "Shell Icon..." button.
The desktop icons are not difficult to delete manually but the "Send To" icons are
more of a hassle.
Thank you
Andrew S.
Re: WinSCP "Clean Up" tool
It would have to delete all shortcuts pointing to WinSCP. As WinSCP cannot regognize which shortcuts were created manually.
ashugg-epits
Agreed, asking WinSCP to track which shortcuts it created might not be reasonable.
Maybe just clear out any shortcuts that invoke WinSCP with a particular profile? It is a (small) bother when a "Send To" shortcut is created, and then the profile is deleted in favour of a new one so the "Send To" shortcut will not work any more. This would involve reading the properties of the shortcuts though. I assume that's possible but don't know what's involved.
