Disable keyboard-interactive after key refusal
I'm running a certificate authenticated SFTP script using "option batch abort" every 15 minutes. Approx every two weeks I get "Server refused our key" - I assume it's about a network problem and the key isn't transfered correctly to the server. Anyway, I can't do anything about that.
What's bugging me is that after the has been refused the script switches to keyboard-interactive authentication and stalls.
I tried serveral options in the Authetication tab in WinSCP.exe, none of them worked.
Is there a way to abort the login process at all when the key is refused?
Regards
Re: Disable keyboard-interactive after key refusal
The prompt should cancel itself in 10 secs. Doesn't it? What version of WinSCP are you using?
thanks for your answer, unfortunately it doesn't cancel itself, it stalles for hours.
I'm using WinSCP 4.2.7 (Build 758). I use WinSCP.com and don't use the /console switch of the .exe
Here's a part of log:
. 2010-07-21 07:00:01.430 Initialised AES-256 CBC server->client encryption
. 2010-07-21 07:00:01.430 Initialised HMAC-SHA1 server->client MAC algorithm
. 2010-07-21 07:00:01.648 Reading private key file "C:\SomeDummyDir\Dummy.ppk"
! 2010-07-21 07:00:01.648 Using username "Dummy".
. 2010-07-21 07:00:01.695 Offered public key
! 2010-07-21 07:00:01.758 Server refused our key
. 2010-07-21 07:00:01.758 Server refused public key
. 2010-07-21 07:00:01.820 Prompt (5, SSH server authentication, Using keyboard-interactive authentication., Password: )
I start Winscp.com out of the script with this command:
winscp.com /log=%SFTPLog% /command "option batch abort" "option transfer ascii" "open %SFTPUser%@%SFTPHost%" "get *.*" bye
Regards
HoloMan
Munich, Germany
Mail sent
Hello prikryl,
I've registered in the forum and sent you an email.
Thanks for you help.
HoloMan
Munich, Germany
Debug sent
I've reproduced the problem and sent the debug output.
Thanks for your support
Regards
