Assertion failed message when trying to connect
pkayg1970
I am on Windows XP, and was using winscp version 4.2.6. When trying to log in to my secure image server, which I have accessed successfully in the past, I could not connect and got this message: Assertion failed: random_active>=0, file putty\SSHRAND.C, line 242.
I looked up this error message on the forum here and thought that perhaps if I upgraded to the latest version of winscp, that would fix the problem, so I upgraded to version 4.2.8, and tried connecting again. Now I am not getting the error message, but I still cannot connect, it keeps timing out.
I am able to access my regular FTP server just fine, but cannot access my SFTP server
Re: Assertion failed message when trying to connect
