Queue pane uses binary prefixes
The queue pane displays the transferred amount of bytes with binary prefixes (MiB) but the explorer-style file browser pane uses plain integers without any prefixes. SI prefixes would be easier to compare.
Re: Queue pane uses binary prefixes
The lower pane displays KiB, MiB etc. The upper pane does not use any prefixes to display file sizes. I think the binary prefixes only add confusion because almost everyone uses powers of 10 to count things. I would prefer that WinSCP use SI prefixes, e.g. 1234 MB for 1 234 123 123 bytes, not 1205 MiB.
I do not think it is true.
Anyway, so you do you want to use prefixes for both places or use exact number for both?
