can't upload or create folder path longer than 260 character
zenith
i try to upload a folder with multiple sub folder, the error says fail to upload.
how could i solve the issue.
Freitag
Freitag avatar
The only solution is to stop using Windows. Sorry, that is a built in limit.
https://learn.microsoft.com/en-us/windows/win32/fileio/naming-a-file
Maximum Path Length Limitation
In the Windows API (with some exceptions discussed in the following paragraphs), the maximum length for a path is MAX_PATH, which is defined as 260 characters. A local path is structured in the following order: drive letter, colon, backslash, name components separated by backslashes, and a terminating null character. For example, the maximum path on drive D is "D:\<some 256-character path string><NUL>" where "<NUL>" represents the invisible terminating null character for the current system codepage. (The characters < > are used here for visual clarity and cannot be part of a valid path string.)
