imperialx
Zip and Unzip files
Site Admin -
- 43,224
- Prague, Czechia
Re: Zip and Unzip files
imperialx
Forgive me if I didn't understand your reply, are you saying that I can indeed unzip files within WinSCP remotely?
I have this scenario where I zip my files locally then upload the zipped file through WinSCP at my hoster. Once uploaded, I would like to unzipped the file within WinSCP, is this possible?
And where can I input the custom commands?
Thank you for your help.
cheers,
-imperialx
Site Admin -
- 43,224
- Prague, Czechia
Correct. Under some circumstances.Forgive me if I didn't understand your reply, are you saying that I can indeed unzip files within WinSCP remotely?
You will find all the details on the page linked in my previous post.And where can I input the custom commands?
imperialx
There is this one list "Zip" under custom commands section with this syntax unzip "!", however, I'm getting this error "Windows cannot find 'unzip'. Make sure you typed the name correctly, and then try again."
I uploaded a zipped file (photo.zip) to remote then select the uploaded zipped file, next, using the custom command dialog, I input this custom command unzip "!" and that is how I get the error.
Did I miss anything?
Thanks,
imperialx
Site Admin -
imperialx
Under File > Custom Commands, I can't find the Remote command button.
Thanks,
imperialx
Site Admin -
Tracster
Windows cannot find unzip remote command
Does this command only work on windows servers, as most servers are not run on windows?
Site Admin -
- 43,224
- Prague, Czechia
Re: Windows cannot find unzip remote command
Make sure you use remote custom command. You seem to be using local custom command.I am trying to unzip a file on the remote site, and also get the error message "Windows cannot find unzip" after it copies the files to a temporary location.
Tomas Tobis
I tried many things, I tried to edit Custom commands, but then question appeared, how can I use them ? I tried also Commands/Open Terminal and I tried to Execute some commands. No success. I think it is time to show, how this magic really works :lol:
Tomas
P.S.: Wouldn't it be great to have context menu option for zipping/unzipping files ?
Site Admin -
- 43,224
- Prague, Czechia
The custom commands do not work with FTP. Only with SCP and possibly with SFTP.Hi Martin. I use WinScp in Windows style mode. I also would like to do zipping/unzipping, but it is horribly hard to do. Also the documentation you pointed to is hard to understand. Can you provide please real steps how to zip/unzip the remote file ? I mean file on FTP server I am connected to.
CoyoteKG
Zip command
I found this command on your documentation, but I don't know how to use it.
zip -r "!?&Enter an Archive Name:?archive.zip!" !&
Please, can you write example, like file name is just backup.zip
Site Admin -
- 43,224
- Prague, Czechia
Re: Zip command
You cannot run arbitrary shell commands over FTP session. Only SFTP/SCP.Hello, I'm trying to zip wordpress site over FTP, and transfer it locally.
RichardHC
Unzipping made easy
- Guest
Re: Unzipping made easy
The easiest, fastest, best way to unzip a file on your hosting site is to be sure you zip it recursively so you have the files in their correct folders, upload it by FTP then log into your hosting service C-panel, select the file manager, go to the folder you uploaded the zip file to, select it then click on "extract" - add a path to where you want it unzipped to or just extract it into the root folder of your domain folder. Done. Easy.
Six years gone and I was hoping to find some "better" solution than filezilla+cpanel for zipping/unzipping on the server but seems no way :(((
Any good news I missed?
Site Admin -
- 43,224
- Prague, Czechia
I believe this thread shows the way. Or what are you looking for?Six years gone and I was hoping to find some "better" solution than filezilla+cpanel for zipping/unzipping on the server but seems no way :(((
- Guest
I imagine an easy peasy right-click zip/unzip option (rar, gzip, etc...) :wink:
Site Admin -
- 43,224
- Prague, Czechia
Just define a custom command that works on your specific server.
https://winscp.net/eng/docs/custom_commands#archiving
There's no standard solution that works everywhere.
EDIT: See also https://winscp.net/eng/docs/library_example_zip_and_upload
auto-debilitator
Transfer & unzip in one step
Remote Unix server has gzipped files (1 file per archive). I'd like to be able to pull these files over and unz6ip (locally on my PC) and open in Notepad++ in one step. Unzipping on the remote server isn't an option because I don't have write rights, and I don't want to clutter the server up.
Right now you can right-click a file and choose "Edit". It would be AWESOME if you could right-click a file and choose "Unzip and Edit", where that unzip happened locally, perhaps just in memory, instead of on the server.
hellreaser
Zip and upload
- Guest
Re: Zip and upload
Please help what happened to the zip file when I do zip and upload above. Where went the zip file after creating ?Please could you tell me which is the location of the file in Windows that I zip and upload with winscp? Thanks
Site Admin -
- 43,224
- Prague, Czechia
Re: Transfer & unzip in one step
Write a script/extension for that.The use case I have is:
It's not difficult.
Your task has many steps common with these extensions/scripts:
https://winscp.net/eng/docs/library_example_verify_file_checksum
https://winscp.net/eng/docs/library_example_download_clipboard
https://winscp.net/eng/docs/extension_archive_and_download
Site Admin -
- 43,224
- Prague, Czechia
Re: Zip and upload
What "ZIP and upload" do you refer to?Please help what happened to the zip file when I do zip and upload above. Where went the zip file after creating ?
Do you mean the official "ZIP and Upload" extension?
It uploads the file to the current remote working directory.
If that does not work, enable logging in the extension configuration and attach the log here.
(Start a new thread for this).
- Fuana
- 3
- Canada
Zip Upload with password to the archive
Site Admin -
- 43,224
- Prague, Czechia
Re: Zip Upload with password to the archive
- Add new runtimeHow can I modify the Zip Upload command to allow the -p parameter to add a password to the archive
@option option
- Pass its value to a new PowerShell
param variable
- Pass the variable to 7zip
-p switch.
Site Admin -
- 43,224
- Prague, Czechia
What particular step is not clear?Could you put an example as it is not too clear to me what to add to the command
apathan
Unzip file
I am trying to unzip files automatically from FTP server using command in WinSCP but I am not able to do so. I want to download that files on my local computer in an unzipped format.
Site Admin -
- 43,224
- Prague, Czechia
Re: Unzip file
There's hardly any way to unzip a file on FTP server.I am trying to unzip files automatically from FTP server using command in WinSCP but I am not able to do so. I want to download that files on my local computer in an unzipped format.
See https://superuser.com/q/479661/213663 or https://stackoverflow.com/q/45935372/850848
