Separate move & copy options
ehuss
I am using the Explorer interface, and love it. There is one thing that seems kinda odd.
Right now, WinSCP only allows you to configure it to always MOVE or always COPY. Instead it should give you both options on the transfer dialog box. This would make it (slightly) more like explorer where if you right-button drag a file, it gives you options to copy/move/create shortcut/etc.
Does that make sense?
Re: Separate move & copy options
File is copied, when you hold Ctrl (or Control) while dragging, while it is moved when you do not hold Ctrl. Just as with Explorer. I may add that right-click menu too.
