Not able to SFTP in MainFrame by WinSCP
singhpk
I am not able to do SFTP in mainframe. Error occurring is below ...
Connecting to 10.15.243.11:20021 ...
Connected with 10.15.243.11:20021, negotiating SSL connection...
SSL connection established. Waiting for welcome message...
Connected
Starting the session...
Reading remote directory...
Session started.
Active session: [1] MF
transfer        binary
D:\manish\ZZZZ0705.T02    |          0 KiB |    0.0 KiB/s | binary |   0%
Error transferring file 'D:\manish\ZZZZ0705.T02'.
CWD cmd failed : EDC5129I No such file or directory.
(A)bort, (R)etry, (S)kip, Ski(p) all:
Please help.
Re: Not able to SFTP in MainFrame by Winscp
pradeepbokaro
:D I have resolved the problem, there was syntax problem.
Now I able to do successful FTP to Mainframe dataset.
