WinSCP source code
Re: WinSCP source code
I will, but I still don't have time to clean the code and make order in files, so it would make any use to someone other than me.
RichardWorth
Can I Please Help?
  • I would be willing to help clean up the code. Have you considered releasing it under the GPL?
Others Want It Too
  • I am a contributor for GNUWin II – a Windows CD distribution of Free Windows Software. They can't include WinSCP because it's 'freeware' – the source code is not readily available.
  • I would like to see the source code released so that I can recommend this program to friends and family as Free Software (or Open Source), not just freeware.
It Just Makes Sense (TM)
  • One important aspect of security-related software like this is that without source code it's extremely difficult to audit how secure the software is.
Reply with quote E-mail
Thanks, I've already did that. But I've noticed, that author one of the GUI libraries (for drag&drop) I'm using does not allow me to publish the source code without his approval. Problem is that page, where I've downloaded the code does not exist anymore. So I don't know how to contact him. I may release only part of the code (without the library), but nobody can compile it.
Sure, I understand this.
sylvan
That would be a big improvement over what we have now. And perhaps somebody will be able to replace or at least stub out the missing library.
Thanks! sdb
@sylvan: OK, I'll release the code with next version, but without the library. Probably I may release library file compiled with C++ Builder 6 (IDE, I'm using). WinSCP can't be compiled in anything else anyway (maybe in older versions of C++ Builder).
htaccess
Is there any updates on the chances of WinSCP being open sourced? WinSCP is a very good application but the freeware licence is holding it back. There is another project called the OpenCD (<invalid hyperlink removed by admin>) which is distributing open source software for Windows, it would also include WinSCP if it were open source (being an OSI approved licence https://opensource.org/license is a requirement for distribution).
I also work for an ISP and we distribute open source software for our users I would like to add WinSCP because I think its a great app, but I don't because of the licence and lack of source.
Also you may find that people provide patches and help for the project that you otherwise wouldn't get.
Anyway, I add my voice, I thing WinSCP is great, please open source it
Thanks!
I just want to say thanks for releasing WinSCP under the GPL, it realy is a high class application and now its gpl'ed it will always be avalible.
Kepp up the good work :)
