Active/passive mode
Jason
Active/passive mode
Two questions here:
  1. The active/passive mode option is greyed out.
    WinSCP version 4.2.7
    How to get it back?
  2. How to set active/passive mode in script?
Re: active/passive mode
How to get it back?
You have to select FTP protocol first.
Edit 2023: Since this has been implemented:
Issue 669 – Option to enable active mode with FTP protocol in scripting.
you can use -passive=off switch of the open command to switch to the active mode (the passive is the default):
https://winscp.net/eng/docs/scriptcommand_open#passive
Sopor
Sopor avatar
Sweden
So there is no Auto for "passive"?
I read that I can use 0, 1 or 2 instead of on, off and auto. That is why I wrote as I did.
FtpForcePasvIp2 Force IP address for passive mode connections 0/on = On, 1/off = Off, 2/auto = Auto
