synchronize command hangs if remote folder does not exist
NUTC24CK32
Winscp hangs when you try to synchronize the local folder with the remote folder.
Given that the remote folder does not exist upon execution of the synchronize command.
Re: synchronize command hangs if remote folder does not exist
