Using /parameters with winscp3.com /script= call
Hello -
I'm trying to use parameters with a /script call from winscp3.com. I have a .bat file that sets some date variables, and I'd like to pass those through to the script. I've spent a good deal of time on the documentation, and it appears this is supported, but it's not working as outlined below. Note that if I remove the parameters and "dynamic" date code from the processing, it works like a charm. So I've ruled out permissions, etc. from the equation.
My .bat:
@echo off
set mydate=%date%
set myyear=%mydate:~12,2%
set mymonth=%mydate:~4,2%
set myday=%mydate:~7,2%
winscp3.com /script="\\usmaastdb1\SFTPScripts\GetInfoScript.txt" /parameter %myyear% %mymonth% %myday%
My GetInfoScript.txt file:
option batch on
open [profile_name] <-- replaced for privacy reasons
get filename_%1%%2%%3%.TXT E:\AST_MediaSystem_Incoming\
Any help would be greatly appreciated! Thanks!
My .bat:
@echo off
set mydate=%date%
option batch on
