Trouble to read content of remote "/" directory
Druckguss
Germany
I am having round about 10 PCs within the same network. Some of them easily getting FTP connection with WinSCP. See log
@sessionlog@
. 2010-06-21 14:37:06.109 --------------------------------------------------------------------------
. 2010-06-21 14:37:06.109 WinSCP Version 4.2.7 (Build 758) (OS 5.1.2600 Service Pack 3)
. 2010-06-21 14:37:06.109 Login time: Montag, 21. Juni 2010 14:37:06
. 2010-06-21 14:37:06.125 Session name: ...
. 2010-06-21 14:37:06.125 Host name: ... (Port: 21)
. 2010-06-21 14:37:06.125 User name: ... (Password: Yes, Key file: No)
. 2010-06-21 14:37:06.125 Tunnel: No
. 2010-06-21 14:37:06.125 Transfer Protocol: FTP
. 2010-06-21 14:37:06.125 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2010-06-21 14:37:06.125 Proxy: HTTP
. 2010-06-21 14:37:06.125 HostName: ... (Port: ...); Username: ...; Passwd: Yes
. 2010-06-21 14:37:06.125 FTP: FTPS: None; Passive: Yes [Force IP: No]
. 2010-06-21 14:37:06.125 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-06-21 14:37:06.125 Cache directory changes: Yes, Permanent: Yes
. 2010-06-21 14:37:06.125 DST mode: 1
. 2010-06-21 14:37:06.125 --------------------------------------------------------------------------
. 2010-06-21 14:37:06.203 Verbinde mit ... ...
. 2010-06-21 14:37:06.203 m_pProxyLayer changed state from 0 to 1
. 2010-06-21 14:37:06.203 m_pProxyLayer changed state from 1 to 2
. 2010-06-21 14:37:06.296 m_pProxyLayer changed state from 2 to 4
. 2010-06-21 14:37:06.343 Verbunden mit hdo-gmbh.com. erwarte Willkommensnachricht ...
< 2010-06-21 14:37:06.609 220 FTP on ... ready
> 2010-06-21 14:37:06.609 USER ...
< 2010-06-21 14:37:06.671 331 Password required for ...
> 2010-06-21 14:37:06.671 PASS ***********
< 2010-06-21 14:37:06.875 230 User ... logged in
> 2010-06-21 14:37:06.875 SYST
< 2010-06-21 14:37:07.000 215 UNIX Type: L8
> 2010-06-21 14:37:07.000 FEAT
< 2010-06-21 14:37:07.156 211-Features:
< 2010-06-21 14:37:07.156  MDTM
< 2010-06-21 14:37:07.156  MFMT
< 2010-06-21 14:37:07.156  AUTH TLS
< 2010-06-21 14:37:07.156  MFF modify;UNIX.group;UNIX.mode;
< 2010-06-21 14:37:07.156  MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.mode*;UNIX.owner*;
< 2010-06-21 14:37:07.156  PBSZ
< 2010-06-21 14:37:07.156  PROT
< 2010-06-21 14:37:07.156  REST STREAM
< 2010-06-21 14:37:07.156  SIZE
< 2010-06-21 14:37:07.156 211 End
. 2010-06-21 14:37:07.171 Verbunden
. 2010-06-21 14:37:07.171 Got reply 1 to the command 1
. 2010-06-21 14:37:07.171 --------------------------------------------------------------------------
. 2010-06-21 14:37:07.171 Using FTP protocol.
. 2010-06-21 14:37:07.171 Doing startup conversation with host.
> 2010-06-21 14:37:07.171 PWD
< 2010-06-21 14:37:07.343 257 "/" is the current directory
. 2010-06-21 14:37:07.343 Got reply 1 to the command 16
. 2010-06-21 14:37:07.343 Getting current directory name.
. 2010-06-21 14:37:07.343 Rufe Verzeichnisinhalt ab...
> 2010-06-21 14:37:07.359 TYPE A
< 2010-06-21 14:37:07.406 200 Type set to A
> 2010-06-21 14:37:07.406 PASV
. 2010-06-21 14:37:07.406 m_pProxyLayer changed state from 0 to 1
< 2010-06-21 14:37:07.609 227 Entering Passive Mode (85,13,129,166,195,86).
> 2010-06-21 14:37:07.609 LIST -a
. 2010-06-21 14:37:07.609 m_pProxyLayer changed state from 1 to 2
. 2010-06-21 14:37:07.687 m_pProxyLayer changed state from 2 to 4
< 2010-06-21 14:37:07.921 150 Opening ASCII mode data connection for file list
. 2010-06-21 14:37:07.921 drwxr-xr-x   3 ... ...     4096 Jun  1 11:44 .
. 2010-06-21 14:37:07.921 drwxr-xr-x   3 ... ...     4096 Jun  1 11:44 ..
. 2010-06-21 14:37:07.921 drwxr-xr-x   2 ... ...     4096 May 12 15:40 Already transmitted
. 2010-06-21 14:37:07.921 -rw-r--r--   1 ... ... 85340012 Sep 10  2003 ....mpg
< 2010-06-21 14:37:07.953 226 Transfer complete
. 2010-06-21 14:37:07.953 Verzeichnisinhalt erfolgreich abgerufen
. 2010-06-21 14:37:07.953 Got reply 1 to the command 2
. 2010-06-21 14:37:07.953 Startup conversation with host finished.
But others having trouble to receive the content of the remote directory and cannot start. See log.
. 2010-06-21 14:26:18.859 --------------------------------------------------------------------------
. 2010-06-21 14:26:18.859 WinSCP Version 4.2.7 (Build 758) (OS 5.2.3790 Service Pack 2)
. 2010-06-21 14:26:18.859 Login time: Montag, 21. Juni 2010 14:26:18
. 2010-06-21 14:26:18.859 Session name: ...
. 2010-06-21 14:26:18.859 Host name: ... (Port: 21)
. 2010-06-21 14:26:18.859 User name: ... (Password: Yes, Key file: No)
. 2010-06-21 14:26:18.859 Tunnel: No
. 2010-06-21 14:26:18.859 Transfer Protocol: FTP
. 2010-06-21 14:26:18.859 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2010-06-21 14:26:18.859 Proxy: HTTP
. 2010-06-21 14:26:18.859 HostName: ... (Port: ...); Username: ...; Passwd: Yes
. 2010-06-21 14:26:18.859 FTP: FTPS: None; Passive: Yes [Force IP: No]
. 2010-06-21 14:26:18.859 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-06-21 14:26:18.859 Cache directory changes: Yes, Permanent: Yes
. 2010-06-21 14:26:18.859 DST mode: 1
. 2010-06-21 14:26:18.875 Verbinde mit ... ...
. 2010-06-21 14:26:18.875 m_pProxyLayer changed state from 0 to 1
. 2010-06-21 14:26:18.875 m_pProxyLayer changed state from 1 to 2
. 2010-06-21 14:26:19.078 m_pProxyLayer changed state from 2 to 4
. 2010-06-21 14:26:19.375 Verbunden mit ... erwarte Willkommensnachricht ...
< 2010-06-21 14:26:20.921 220 FTP on ... ready
> 2010-06-21 14:26:20.921 USER ...
< 2010-06-21 14:26:21.218 331 Password required for ...
> 2010-06-21 14:26:21.218 PASS ***********
< 2010-06-21 14:26:21.593 230 User ... logged in
> 2010-06-21 14:26:21.593 SYST
< 2010-06-21 14:26:21.875 215 UNIX Type: L8
> 2010-06-21 14:26:21.875 FEAT
< 2010-06-21 14:26:22.078 211-Features:
< 2010-06-21 14:26:22.078  MDTM
< 2010-06-21 14:26:22.078  MFMT
< 2010-06-21 14:26:22.078  AUTH TLS
< 2010-06-21 14:26:22.078  MFF modify;UNIX.group;UNIX.mode;
< 2010-06-21 14:26:22.078  MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.mode*;UNIX.owner*;
< 2010-06-21 14:26:22.078  PBSZ
< 2010-06-21 14:26:22.078  PROT
< 2010-06-21 14:26:22.078  REST STREAM
< 2010-06-21 14:26:22.078  SIZE
< 2010-06-21 14:26:22.078 211 End
. 2010-06-21 14:26:22.078 Verbunden
. 2010-06-21 14:26:22.078 Got reply 1 to the command 1
. 2010-06-21 14:26:22.078 --------------------------------------------------------------------------
. 2010-06-21 14:26:22.078 Using FTP protocol.
. 2010-06-21 14:26:22.093 Doing startup conversation with host.
> 2010-06-21 14:26:22.093 PWD
< 2010-06-21 14:26:22.437 257 "/" is the current directory
. 2010-06-21 14:26:22.437 Got reply 1 to the command 16
. 2010-06-21 14:26:22.437 Getting current directory name.
. 2010-06-21 14:26:22.437 Rufe Verzeichnisinhalt ab...
> 2010-06-21 14:26:22.437 TYPE A
< 2010-06-21 14:26:22.703 200 Type set to A
> 2010-06-21 14:26:22.703 PASV
. 2010-06-21 14:26:22.703 m_pProxyLayer changed state from 0 to 1
< 2010-06-21 14:26:22.921 227 Entering Passive Mode (85,13,129,166,195,93).
> 2010-06-21 14:26:22.921 LIST -a
. 2010-06-21 14:26:22.921 m_pProxyLayer changed state from 1 to 2
. 2010-06-21 14:26:23.031 m_pProxyLayer changed state from 2 to 4
. 2010-06-21 14:26:37.906 Zeit abgelaufen
. 2010-06-21 14:26:37.906 Konnte Verzeichnisinhalt nicht abrufen
. 2010-06-21 14:26:37.906 Got reply 1004 to the command 2
* 2010-06-21 14:26:37.906 (ESshFatal) Verbindung verloren.
* 2010-06-21 14:26:37.906 Zeit abgelaufen
* 2010-06-21 14:26:37.906 Konnte Verzeichnisinhalt nicht abrufen
* 2010-06-21 14:26:37.906 Entering Passive Mode (85,13,129,166,195,93).
* 2010-06-21 14:26:37.906 Fehler beim Anzeigen des Verzeichnisses "/".
For security reasons I replaced the confidential things in the log files by ...
I already marked the relevant differences in the logs in red.
I am using WinSCP Portable Version 4.2.7 (Build 758) placed in a network directory.
The GUI is working with commander style.
First I thought it'ss related to the different OS (WinXP / Win XP64) but I read WinSCP is working fine on both OS.
Thanks in advance
Re: Trouble to read content of remote "/" directory
Are you able to connect with any other FTP client from the XP64 machines?
Druckguss
Germany
Dear Martin
yes on both operating systems (Win XP / Win XP64) FileZilla was working. Everything was fine up to file size of roughly 30 MB. The transfer of bigger files started but the file never became bigger then 0 byte at the target directory.
I assumed a misconfiguration of the proxy and changed to WinSCP. Without changing everything on the proxy configuration files far bigger then 30MB were no problem from WinXP clients.
Remark:
I tried to use keep alive commands with both programs and OS but nothing changed.
Sorry, I'm lost, so does it work now with Filezilla or not?
Druckguss
Germany
Sorry.
Yes it worked with Filezilla on WinXP 64 as long as the files were smaller then 30 MB. I tried to use WinSCP to get rid of the 30 MB size problem.
With Win SCP it's not working on my WinXP 64 systems even if the files are smaller then 30 MB.
OK, if you use GUI, do you get remote directory listing at all?
Druckguss
Germany
I only used GUI.
Remote directory "/" listing:
WinXP with WinSCP = Yes
WinXP with other client = Yes
WinXP64 with WinSCP = No
WinXP64 with other client = Yes
By the way. For me LazyDayzofSummer seems to have a problem that might be linked to mine.
Druckguss
Germany
May I have a test account on your server?
I set up the account. How should I send the login data? I don't want to publish to everyone.
Please keep in mind that my problem occurs when I try to use the following way
My Network -> Our Proxy -> Internet -> Remote FTP server
and you will use
Your network -> Maybe your proxy -> Internet -> Remote FTP server
You might not be able to identify the problem if it's related to the proxy.
