Bug in custom commands with !/
Chanz
Hi there,
WinSCP v4.2.7 build 758
There is a bug with the custom commands.
When I use: ln -s '!/!' !?Enter target?!
then !/ is always the last folder I used.
Example:
I'm in /home/test/ and create some symlinks of some files. That works without problems, but then when I go to /home/anothertest/ and create some symlinks they are created with the first path, like /home/test/fileof-anothertest-dir.txt
Dunno if I did something wrong there but in the FAQ it says:
"!/ Any Current remote path."
Re: Bug in custom commands with !/
