cd in script returns 'no such file' error
                I am running WinSCP 4.1.7 on WinXP SP3, running a script in console mode, passing 3 parameters. The parameters are for session name, a filename, and a remote directory name. The script tries to 'cd' to the remotedirectory. I get 'no such file' error. This is because WinSCP is appends parameter %3% to the default folder path. However, the directory I want to change to is not a subfolder of the default directory.
Default session directory is: /afs/myserver/home/c/m/cmartin
I want to change to this folder: /afs/myserver/depts/med/cgibd/public_html/POPS/Asher
WinSCP attempts cd as: '/afs/myserver/home/c/m/cmartin/%3%' instead of '%3%'
Here is cmdline:
"C:\Program Files\WinSCP\WinSCP.com" /log="E:\Docs\Batch\Libs\winscp.log" /script="E:\Docs\Batch\Libs\put.txt" /parameter myserv_cfm "E:\Docs\Batch\Libs\RefFile.txt" /afs/myserver/depts/med/cgibd/public_html/POPS/Asher
Here is the script:
option batch on
option transfer automatic
open %1%
cd %3%
close
Here is the log:
. 2010-06-16 16:10:47.731 --------------------------------------------------------------------------
. 2010-06-16 16:10:47.731 Using SFTP protocol.
. 2010-06-16 16:10:47.762 Doing startup conversation with host.
> 2010-06-16 16:10:47.762 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2010-06-16 16:10:47.762 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2010-06-16 16:10:47.762 SFTP version 3 negotiated.
. 2010-06-16 16:10:47.762 We believe the server has signed timestamps bug
. 2010-06-16 16:10:47.762 We will use UTF-8 strings for status messages only
. 2010-06-16 16:10:47.762 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2010-06-16 16:10:47.762 Changing directory to "/afs/myserver/home/c/m/cmartin".
. 2010-06-16 16:10:47.762 Getting real path for '/afs/myserver/home/c/m/cmartin'
> 2010-06-16 16:10:47.762 Type: SSH_FXP_REALPATH, Size: 43, Number: 16
< 2010-06-16 16:10:47.762 Type: SSH_FXP_NAME, Size: 89, Number: 16
. 2010-06-16 16:10:47.762 Real path is '/afs/myserver/home/c/m/cmartin'
. 2010-06-16 16:10:47.762 Trying to open directory "/afs/myserver/home/c/m/cmartin".
> 2010-06-16 16:10:47.762 Type: SSH_FXP_LSTAT, Size: 43, Number: 263
< 2010-06-16 16:10:47.762 Type: SSH_FXP_ATTRS, Size: 37, Number: 263
. 2010-06-16 16:10:47.762 Getting current directory name.
. 2010-06-16 16:10:47.762 Startup conversation with host finished.
. 2010-06-16 16:10:47.778 Changing directory to "%3%".
. 2010-06-16 16:10:47.778 Getting real path for '/afs/myserver/home/c/m/cmartin/%3%'
> 2010-06-16 16:10:47.778 Type: SSH_FXP_REALPATH, Size: 47, Number: 528
< 2010-06-16 16:10:47.778 Type: SSH_FXP_STATUS, Size: 29, Number: 528
< 2010-06-16 16:10:47.778 Status/error code: 2, Message: 528, Server: No such file, Language:
* 2010-06-16 16:10:47.778 (ECommand) Error changing directory to '%3%'.
* 2010-06-16 16:10:47.778 Cannot get real path for '/afs/myserver/home/c/m/cmartin/%3%'.
* 2010-06-16 16:10:47.778 No such file or directory.
* 2010-06-16 16:10:47.778 Error code: 2
* 2010-06-16 16:10:47.778 Error message from server: No such file
* 2010-06-16 16:10:47.778 Request code: 16
. 2010-06-16 16:10:47.794 Closing connection.
. 2010-06-16 16:10:47.794 Sending special code: 12
. 2010-06-16 16:10:47.794 Sent EOF message
This is log from a GUI session, just to show that remote directory exists:
Cached directory change via "/afs/myserver/depts/med/cgibd/public_html/POPS/Asher" to "/afs/myserver/depts/med/cgibd/public_html/POPS/Asher".
Listing directory "/afs/myserver/depts/med/cgibd/public_html/POPS/Asher".
Type: SSH_FXP_OPENDIR, Size: 65, Number: 16907
Type: SSH_FXP_STATUS, Size: 24, Number: 16644
Discarding reserved response
Type: SSH_FXP_HANDLE, Size: 13, Number: 16907
Type: SSH_FXP_READDIR, Size: 13, Number: 17164
Type: SSH_FXP_NAME, Size: 879, Number: 17164
Type: SSH_FXP_READDIR, Size: 13, Number: 17420
Type: SSH_FXP_STATUS, Size: 28, Number: 17420
Status/error code: 1
Type: SSH_FXP_CLOSE, Size: 13, Number: 17668
Here is cmdline:
Here is the script:
option batch on
open %1%
cd %3%
close
Here is the log:
