Multiple Watch Folders..?
topcat888
Hi
I want to use the 'Keep Retmote Directory up to Date' but I have a problem, the subfolders are not all within the same folder stucture... In others words I want to be able to pick multiple folders to watch at the same time within the same session, is this possible becasue I can only see that you can pick only one folder and its subs..??
Re: Multiple Watch Folders..?
Start it from common root and use exclude/include mask to narrow down the set of directories to watch.
topcat888
Thanks for the pointer... I have tried that and can not get it to work, could you give me some examples..?
