resume in new version 4.2
jason
In the most recent version, can I use resume in scripting? I frequently encouter the problem of "connection reset by server".
For ini file, can I just have one section like this:
[Configuration\Interface\CopyParam]
ResumeSupport=10
ResumeThreshold=102400
What is the unit of ResumeThreshold - milli-seconds?
Re: resume in new version 4.2
ResumeSupport does not have value 10 and ResumeThreshold is in bytes. You should better configure it in the GUI.
Jason
I don't see resume option in UI.
I want to use resume function in script. My understanding is that by default there is no resume.
jason
Saw that configuration options. Thanks.
So by default WinScp resumes in 5 seconds. There is no need to specify a ini file. Resume works in both UI and scripting. Am I right?
I changed some configuration and save it, but did not see a ini file in default installtion folder or Application Data folder, neither in registry.
