Newbe email notification question
torentine
Monterey California
First of all congratulation on a great product.
Now moving on, I have a folder on my network on which users store lab results. I created a scheduled task which call on WINSCP to automatically upload any new files to remote FTP server and then it moves those files to a different directoy on the local server. All this is working just fine.
The problem is that I also configured email notification for when the job fails. The email portion works a little to well. The problem is that when there are no files to be transfered I get an email with an error notification.
This is what I have as a script which get called on by a batch file.
option batch on
open labresults
put *.*
Please Help
oh ok after the script runs it calls on a bat file with the following code:
winscp.com /script=MoveLabResults.txt
if errorlevel 1 goto error
echo Upload succeeded, moving local files
move C:\cssw\hl7\emd\Results\*.* c:\backup\
:error
echo Error!
bmail.exe -s 192.168.16.10 -t user@example.com -f Results@example.com -b "FTP File Transfer Failed To SVMH" -a "PCM LabLab Results Transfer Failure"
:end
lyf
Your batch file misses goto end command after move command, so you get the email even on success.
I think when WinSCP finds there are no files to upload, it sees this as an error but it is actually perfectly fine since not everytime there will be files to send. So how are we going to differentiate this error from the real problems?
cheers
lyf
This is not true.
Your batch file is simply wrong, as I have suggested in my previous post.
