Hangs without any reason
Sowmya
I have 3 source folders each having 3-10 differnt folders with 8 tiff files.trying to copy using the below code to remote fodler ,the code hangs after copying 2-3 folders and it does not throw any error.Pls let me know if i am doing it correctly or anything to be modified.
Below is the code runs in .NET
Dim WinSCP As New Process
WinSCP.StartInfo.FileName = strWinSCPExe
WinSCP.StartInfo.Arguments = "/log=" + "log"
WinSCP.StartInfo.UseShellExecute = False
WinSCP.StartInfo.RedirectStandardInput = True
WinSCP.StartInfo.RedirectStandardOutput = True
WinSCP.StartInfo.CreateNoWindow = True
WinSCP.Start()
' Feed in the scripting commands
WinSCP.StandardInput.WriteLine("option batch abort")
WinSCP.StandardInput.WriteLine("option confirm off")
WinSCP.StandardInput.WriteLine("option batch continue")
WinSCP.StandardInput.WriteLine("open " & """" & strSession & """" & " -hostkey=" & """" & strhostKey & """" & " -timeout=3600")
File.Delete("batch.bat")
If (Directory.Exists("D:\\Brokers\")) Then
strDirectory = Directory.GetFiles(strSourceFolder, strTouchFileName, SearchOption.AllDirectories)
If (strDirectory.Length > 0) Then
For Each strTargetFullpath In strDirectory
sbCmdCode = New StringBuilder()
strParentDir = Directory.GetParent(strTargetFullpath).FullName.ToString()
strFullpathRoot = Directory.GetParent(strTargetFullpath).Parent.Name
strParentDirName = Directory.GetParent(strTargetFullpath).Name
''copy the Batch folder to NAS Share
''making directory
If (strPrevFolder <> strTargetFolder & strFullpathRoot) Then
WinSCP.StandardInput.WriteLine("mkdir " & strTargetFolder & strFullpathRoot)
End If
WinSCP.StandardInput.WriteLine("put " & """" & strParentDir & """" & " " & """" & strTargetFolder & strFullpathRoot & "/" & """")
strtargetLocalfolder = strParentDir.Replace("Incoming", "Incoming_Archive")
sbCmdCode.Append(vbCrLf)
sbCmdCode.Append("D: CD " & strArchiveFolder & " IF EXIST " & strtargetLocalfolder & " ")
sbCmdCode.Append(" ( move " & strParentDir & " " & strtargetLocalfolder & "\ )")
sbCmdCode.Append(" ELSE")
sbCmdCode.Append("MKDIR " & strtargetLocalfolder)
File.AppendAllText("batch.bat", sbCmdCode.ToString())
strPrevFolder = strTargetFolder & strFullpathRoot
Next
End If
WinSCP.StandardInput.Close()
Dim output As String
output = WinSCP.StandardOutput.ReadToEnd()
' Wait until WinSCP finishes
WinSCP.WaitForExit()
'Success (0) or error?
If WinSCP.ExitCode <> 0 Then
Log.Error("Error occured while copying files file local to remote directoy" & WinSCP.ExitCode)
Else
Process.Start("batch.bat")
End If
SOWMYA
Re: Hangs without any reason
I get below error pop up "timeout waiting for external console to complete the command"[/img]
SOWMYA
Log file message.Can any of you let me know how to resolve this?
This is little urgent!
. 2010-05-27 11:53:00.245 --------------------------------------------------------------------------
. 2010-05-27 11:53:00.245 WinSCP Version 4.2.7 (Build 758) (OS 5.1.2600 Service Pack 3)
. 2010-05-27 11:53:00.245 Login time: Thursday, May 27, 2010 11:53:00 AM
. 2010-05-27 11:53:00.245 Session name: autosutl@cmfalgaqutil01v.comfin.ge.com
. 2010-05-27 11:53:00.245 Host name: cmfalgaqutil01v.comfin.ge.com (Port: 22)
. 2010-05-27 11:53:00.245 User name: autosutl (Password: No, Key file: Yes)
. 2010-05-27 11:53:00.245 Tunnel: No
. 2010-05-27 11:53:00.245 Transfer Protocol: SFTP
. 2010-05-27 11:53:00.245 Ping type: -, Ping interval: 30 sec; Timeout: 3600 sec
. 2010-05-27 11:53:00.245 Proxy: none
. 2010-05-27 11:53:00.245 SSH protocol version: 2; Compression: No
. 2010-05-27 11:53:00.245 Bypass authentication: No
. 2010-05-27 11:53:00.245 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-05-27 11:53:00.245 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-05-27 11:53:00.245 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-05-27 11:53:00.245 SFTP Bugs: -,-
. 2010-05-27 11:53:00.245 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-05-27 11:53:00.245 Shell: default, EOL: 0
. 2010-05-27 11:53:00.245 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-05-27 11:53:00.245 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-05-27 11:53:00.245 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-05-27 11:53:00.245 Cache directory changes: Yes, Permanent: Yes
. 2010-05-27 11:53:00.245 DST mode: 1
. 2010-05-27 11:53:00.245 Looking up host "cmfalgaqutil01v.comfin.ge.com"
. 2010-05-27 11:53:00.261 Connecting to 3.34.17.28 port 22
. 2010-05-27 11:53:00.480 Waiting for the server to continue with the initialisation
. 2010-05-27 11:53:00.480 Detected network event
. 2010-05-27 11:53:00.558 Detected network event
. 2010-05-27 11:53:00.558 Server version: SSH-2.0-Sun_SSH_1.1.1
. 2010-05-27 11:53:00.558 Using SSH protocol version 2
. 2010-05-27 11:53:00.558 We claim version: SSH-2.0-WinSCP_release_4.2.7
. 2010-05-27 11:53:00.558 Waiting for the server to continue with the initialisation
. 2010-05-27 11:53:00.902 Detected network event
. 2010-05-27 11:53:00.902 Doing Diffie-Hellman group exchange
. 2010-05-27 11:53:00.902 Waiting for the server to continue with the initialisation
. 2010-05-27 11:53:00.948 Detected network event
. 2010-05-27 11:53:00.948 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-05-27 11:53:00.964 Waiting for the server to continue with the initialisation
. 2010-05-27 11:53:01.073 Detected network event
. 2010-05-27 11:53:01.073 Host key fingerprint is:
. 2010-05-27 11:53:01.073 ssh-rsa 1024 f8:4c:01:82:eb:43:8f:04:10:b9:dc:71:e2:30:fc:df
. 2010-05-27 11:53:01.073 Initialised AES-128 SDCTR client->server encryption
. 2010-05-27 11:53:01.073 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-05-27 11:53:01.073 Initialised AES-128 SDCTR server->client encryption
. 2010-05-27 11:53:01.073 Initialised HMAC-SHA1 server->client MAC algorithm
. 2010-05-27 11:53:01.073 Waiting for the server to continue with the initialisation
. 2010-05-27 11:53:01.277 Detected network event
. 2010-05-27 11:53:01.277 Reading private key file "D:\sowmya\GE\Brokers\Winscp\rsa_keys\id_rsa.ppk"
! 2010-05-27 11:53:01.277 Using username "autosutl".
. 2010-05-27 11:53:01.277 Waiting for the server to continue with the initialisation
. 2010-05-27 11:53:01.323 Detected network event
. 2010-05-27 11:53:01.323 Offered public key
. 2010-05-27 11:53:01.323 Waiting for the server to continue with the initialisation
. 2010-05-27 11:53:01.370 Detected network event
. 2010-05-27 11:53:01.370 Offer of public key accepted
! 2010-05-27 11:53:01.370 Authenticating with public key "rsa-key-20100510"
. 2010-05-27 11:53:01.433 Waiting for the server to continue with the initialisation
. 2010-05-27 11:53:01.495 Detected network event
. 2010-05-27 11:53:01.495 Access granted
. 2010-05-27 11:53:01.495 Waiting for the server to continue with the initialisation
. 2010-05-27 11:53:01.542 Detected network event
. 2010-05-27 11:53:01.542 Opened channel for session
. 2010-05-27 11:53:01.542 Waiting for the server to continue with the initialisation
. 2010-05-27 11:53:01.745 Detected network event
. 2010-05-27 11:53:01.745 Started a shell/command
. 2010-05-27 11:53:01.745 --------------------------------------------------------------------------
. 2010-05-27 11:53:01.745 Using SFTP protocol.
. 2010-05-27 11:53:01.745 Doing startup conversation with host.
> 2010-05-27 11:53:01.745 Type: SSH_FXP_INIT, Size: 5, Number: -1
. 2010-05-27 11:53:01.745 Sent 9 bytes
. 2010-05-27 11:53:01.745 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:01.745 Waiting for another 4 bytes
. 2010-05-27 11:53:01.792 Detected network event
. 2010-05-27 11:53:01.792 Received 9 bytes (0)
. 2010-05-27 11:53:01.792 Read 4 bytes (5 pending)
. 2010-05-27 11:53:01.792 Read 5 bytes (0 pending)
< 2010-05-27 11:53:01.792 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2010-05-27 11:53:01.792 SFTP version 3 negotiated.
. 2010-05-27 11:53:01.792 We believe the server has signed timestamps bug
. 2010-05-27 11:53:01.792 We will use UTF-8 strings for status messages only
. 2010-05-27 11:53:01.792 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2010-05-27 11:53:01.792 Getting current directory name.
. 2010-05-27 11:53:01.792 Getting real path for '.'
> 2010-05-27 11:53:01.792 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
. 2010-05-27 11:53:01.792 Sent 14 bytes
. 2010-05-27 11:53:01.792 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:01.792 Waiting for another 4 bytes
. 2010-05-27 11:53:01.855 Detected network event
. 2010-05-27 11:53:01.855 Received 67 bytes (0)
. 2010-05-27 11:53:01.855 Read 4 bytes (63 pending)
. 2010-05-27 11:53:01.855 Read 63 bytes (0 pending)
< 2010-05-27 11:53:01.855 Type: SSH_FXP_NAME, Size: 63, Number: 16
. 2010-05-27 11:53:01.855 Real path is '/export/home/autosutl'
. 2010-05-27 11:53:01.855 Startup conversation with host finished.
. 2010-05-27 11:53:01.855 Session upkeep
. 2010-05-27 11:53:01.855 Creating directory "/p8_shared/P8SharedFolders/Inbound/Brokers/InComing/05262010".
. 2010-05-27 11:53:01.855 Canonifying: "/p8_shared/P8SharedFolders/Inbound/Brokers/InComing/05262010"
. 2010-05-27 11:53:01.855 Getting real path for '/p8_shared/P8SharedFolders/Inbound/Brokers/InComing/05262010'
> 2010-05-27 11:53:01.855 Type: SSH_FXP_REALPATH, Size: 69, Number: 528
. 2010-05-27 11:53:01.855 Sent 73 bytes
. 2010-05-27 11:53:01.855 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:01.855 Waiting for another 4 bytes
. 2010-05-27 11:53:01.901 Detected network event
. 2010-05-27 11:53:01.901 Received 145 bytes (0)
. 2010-05-27 11:53:01.901 Read 4 bytes (141 pending)
. 2010-05-27 11:53:01.901 Read 141 bytes (0 pending)
< 2010-05-27 11:53:01.901 Type: SSH_FXP_NAME, Size: 141, Number: 528
. 2010-05-27 11:53:01.901 Real path is '/p8_shared/P8SharedFolders/Inbound/Brokers/InComing/05262010'
. 2010-05-27 11:53:01.901 Canonified: "/p8_shared/P8SharedFolders/Inbound/Brokers/InComing/05262010"
> 2010-05-27 11:53:01.901 Type: SSH_FXP_MKDIR, Size: 73, Number: 270
. 2010-05-27 11:53:01.901 Sent 77 bytes
. 2010-05-27 11:53:01.901 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:01.901 Waiting for another 4 bytes
. 2010-05-27 11:53:01.948 Detected network event
. 2010-05-27 11:53:01.948 Received 28 bytes (0)
. 2010-05-27 11:53:01.948 Read 4 bytes (24 pending)
. 2010-05-27 11:53:01.948 Read 24 bytes (0 pending)
< 2010-05-27 11:53:01.948 Type: SSH_FXP_STATUS, Size: 24, Number: 270
< 2010-05-27 11:53:01.948 Status code: 4, Message: 270, Server: Failure, Language:
. 2010-05-27 11:53:01.948 Asking user:
. 2010-05-27 11:53:01.948 Error creating folder '/p8_shared/P8SharedFolders/Inbound/Brokers/InComing/05262010'. ("General failure (server should provide error description).
. 2010-05-27 11:53:01.948 Error code: 4
. 2010-05-27 11:53:01.948 Error message from server: Failure
. 2010-05-27 11:53:01.948 Request code: 14")
. 2010-05-27 11:53:01.948 Session upkeep
. 2010-05-27 11:53:01.948 Copying 1 files/directories to remote directory "/p8_shared/P8SharedFolders/Inbound/Brokers/InComing/05262010/"
. 2010-05-27 11:53:01.948 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: Yes (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-05-27 11:53:01.948 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-05-27 11:53:01.948 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-05-27 11:53:01.948 File: "D:\Brokers\Incoming\05262010\Copy of 18917"
. 2010-05-27 11:53:01.948 Trying to open directory "/p8_shared/P8SharedFolders/Inbound/Brokers/InComing/05262010/Copy of 18917/".
> 2010-05-27 11:53:01.948 Type: SSH_FXP_LSTAT, Size: 84, Number: 775
. 2010-05-27 11:53:01.948 Sent 88 bytes
. 2010-05-27 11:53:01.948 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:01.948 Waiting for another 4 bytes
. 2010-05-27 11:53:02.026 Detected network event
. 2010-05-27 11:53:02.026 Received 41 bytes (0)
. 2010-05-27 11:53:02.026 Read 4 bytes (37 pending)
. 2010-05-27 11:53:02.026 Read 37 bytes (0 pending)
< 2010-05-27 11:53:02.026 Type: SSH_FXP_ATTRS, Size: 37, Number: 775
. 2010-05-27 11:53:02.026 File: "D:\Brokers\Incoming\05262010\Copy of 18917\18917.XML"
. 2010-05-27 11:53:02.026 Copying "D:\Brokers\Incoming\05262010\Copy of 18917\18917.XML" to remote directory started.
. 2010-05-27 11:53:02.026 Ascii transfer mode selected.
. 2010-05-27 11:53:02.026 Opening remote file.
> 2010-05-27 11:53:02.026 Type: SSH_FXP_OPEN, Size: 109, Number: 1027
. 2010-05-27 11:53:02.026 Sent 113 bytes
. 2010-05-27 11:53:02.026 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:02.026 Waiting for another 4 bytes
. 2010-05-27 11:53:02.089 Detected network event
. 2010-05-27 11:53:02.089 Received 17 bytes (0)
. 2010-05-27 11:53:02.089 Read 4 bytes (13 pending)
. 2010-05-27 11:53:02.089 Read 13 bytes (0 pending)
< 2010-05-27 11:53:02.089 Type: SSH_FXP_HANDLE, Size: 13, Number: 1027
. 2010-05-27 11:53:02.089 Write request offset: 0, len: 3871
> 2010-05-27 11:53:02.089 Type: SSH_FXP_WRITE, Size: 3896, Number: 1542
. 2010-05-27 11:53:02.089 Sent 3900 bytes
. 2010-05-27 11:53:02.089 There are 0 bytes remaining in the send buffer
> 2010-05-27 11:53:02.089 Type: SSH_FXP_CLOSE, Size: 13, Number: 1796
. 2010-05-27 11:53:02.089 Sent 17 bytes
> 2010-05-27 11:53:02.089 Type: SSH_FXP_SETSTAT, Size: 109, Number: 1289
. 2010-05-27 11:53:02.089 Sent 113 bytes
. 2010-05-27 11:53:02.089 Waiting for another 4 bytes
. 2010-05-27 11:53:02.198 Detected network event
. 2010-05-27 11:53:02.198 Received 28 bytes (0)
. 2010-05-27 11:53:02.198 Read 4 bytes (24 pending)
. 2010-05-27 11:53:02.198 Read 24 bytes (0 pending)
< 2010-05-27 11:53:02.198 Type: SSH_FXP_STATUS, Size: 24, Number: 1542
. 2010-05-27 11:53:02.198 Waiting for another 4 bytes
. 2010-05-27 11:53:02.401 Detected network event
. 2010-05-27 11:53:02.401 Received 28 bytes (0)
. 2010-05-27 11:53:02.401 Read 4 bytes (52 pending)
. 2010-05-27 11:53:02.401 Read 24 bytes (28 pending)
< 2010-05-27 11:53:02.401 Type: SSH_FXP_STATUS, Size: 24, Number: 1796
< 2010-05-27 11:53:02.401 Status code: 0
. 2010-05-27 11:53:02.401 Read 4 bytes (24 pending)
. 2010-05-27 11:53:02.401 Read 24 bytes (0 pending)
< 2010-05-27 11:53:02.401 Type: SSH_FXP_STATUS, Size: 24, Number: 1289
. 2010-05-27 11:53:02.401 File: "D:\Brokers\Incoming\05262010\Copy of 18917\incoming.touch"
. 2010-05-27 11:53:02.401 Copying "D:\Brokers\Incoming\05262010\Copy of 18917\incoming.touch" to remote directory started.
. 2010-05-27 11:53:02.401 Binary transfer mode selected.
. 2010-05-27 11:53:02.401 Opening remote file.
> 2010-05-27 11:53:02.401 Type: SSH_FXP_OPEN, Size: 114, Number: 2051
. 2010-05-27 11:53:02.401 Sent 118 bytes
. 2010-05-27 11:53:02.401 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:02.401 Waiting for another 4 bytes
. 2010-05-27 11:53:02.448 Detected network event
. 2010-05-27 11:53:02.448 Received 17 bytes (0)
. 2010-05-27 11:53:02.448 Read 4 bytes (13 pending)
. 2010-05-27 11:53:02.448 Read 13 bytes (0 pending)
< 2010-05-27 11:53:02.448 Type: SSH_FXP_HANDLE, Size: 13, Number: 2051
> 2010-05-27 11:53:02.448 Type: SSH_FXP_CLOSE, Size: 13, Number: 2564
. 2010-05-27 11:53:02.448 Sent 17 bytes
. 2010-05-27 11:53:02.448 There are 0 bytes remaining in the send buffer
> 2010-05-27 11:53:02.448 Type: SSH_FXP_SETSTAT, Size: 114, Number: 2313
. 2010-05-27 11:53:02.448 Sent 118 bytes
. 2010-05-27 11:53:02.448 Waiting for another 4 bytes
. 2010-05-27 11:53:02.495 Detected network event
. 2010-05-27 11:53:02.495 Received 28 bytes (0)
. 2010-05-27 11:53:02.495 Read 4 bytes (24 pending)
. 2010-05-27 11:53:02.495 Read 24 bytes (0 pending)
< 2010-05-27 11:53:02.495 Type: SSH_FXP_STATUS, Size: 24, Number: 2564
< 2010-05-27 11:53:02.495 Status code: 0
. 2010-05-27 11:53:02.495 Waiting for another 4 bytes
. 2010-05-27 11:53:02.542 Detected network event
. 2010-05-27 11:53:02.542 Received 28 bytes (0)
. 2010-05-27 11:53:02.542 Read 4 bytes (24 pending)
. 2010-05-27 11:53:02.542 Read 24 bytes (0 pending)
< 2010-05-27 11:53:02.542 Type: SSH_FXP_STATUS, Size: 24, Number: 2313
< 2010-05-27 11:53:02.542 Status code: 0
. 2010-05-27 11:53:02.542 File: "D:\Brokers\Incoming\05262010\Copy of 18917\Thumbs.db"
. 2010-05-27 11:53:02.542 Copying "D:\Brokers\Incoming\05262010\Copy of 18917\Thumbs.db" to remote directory started.
. 2010-05-27 11:53:02.542 Binary transfer mode selected.
. 2010-05-27 11:53:02.542 Opening remote file.
> 2010-05-27 11:53:02.542 Type: SSH_FXP_OPEN, Size: 109, Number: 2819
. 2010-05-27 11:53:02.542 Sent 113 bytes
. 2010-05-27 11:53:02.542 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:02.542 Waiting for another 4 bytes
. 2010-05-27 11:53:02.589 Detected network event
. 2010-05-27 11:53:02.589 Received 17 bytes (0)
. 2010-05-27 11:53:02.589 Read 4 bytes (13 pending)
. 2010-05-27 11:53:02.589 Read 13 bytes (0 pending)
< 2010-05-27 11:53:02.589 Type: SSH_FXP_HANDLE, Size: 13, Number: 2819
. 2010-05-27 11:53:02.589 Write request offset: 0, len: 4096
> 2010-05-27 11:53:02.589 Type: SSH_FXP_WRITE, Size: 4121, Number: 3334
. 2010-05-27 11:53:02.589 Sent 4125 bytes
. 2010-05-27 11:53:02.589 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:02.589 Write request offset: 4096, len: 8192
> 2010-05-27 11:53:02.589 Type: SSH_FXP_WRITE, Size: 8217, Number: 3590
. 2010-05-27 11:53:02.589 Sent 8221 bytes
. 2010-05-27 11:53:02.589 Write request offset: 12288, len: 6144
> 2010-05-27 11:53:02.589 Type: SSH_FXP_WRITE, Size: 6169, Number: 3846
. 2010-05-27 11:53:02.589 Sent 6173 bytes
> 2010-05-27 11:53:02.589 Type: SSH_FXP_CLOSE, Size: 13, Number: 4100
. 2010-05-27 11:53:02.589 Sent 17 bytes
> 2010-05-27 11:53:02.589 Type: SSH_FXP_SETSTAT, Size: 109, Number: 3081
. 2010-05-27 11:53:02.589 Sent 113 bytes
. 2010-05-27 11:53:02.589 Waiting for another 4 bytes
. 2010-05-27 11:53:02.636 Detected network event
. 2010-05-27 11:53:02.636 Received 28 bytes (0)
. 2010-05-27 11:53:02.636 Read 4 bytes (24 pending)
. 2010-05-27 11:53:02.636 Read 24 bytes (0 pending)
< 2010-05-27 11:53:02.636 Type: SSH_FXP_STATUS, Size: 24, Number: 3334
. 2010-05-27 11:53:02.636 Waiting for another 4 bytes
. 2010-05-27 11:53:02.823 Detected network event
. 2010-05-27 11:53:02.823 Received 28 bytes (0)
. 2010-05-27 11:53:02.823 Read 4 bytes (108 pending)
. 2010-05-27 11:53:02.823 Read 24 bytes (84 pending)
< 2010-05-27 11:53:02.823 Type: SSH_FXP_STATUS, Size: 24, Number: 3590
. 2010-05-27 11:53:02.823 Read 4 bytes (80 pending)
. 2010-05-27 11:53:02.823 Read 24 bytes (56 pending)
< 2010-05-27 11:53:02.823 Type: SSH_FXP_STATUS, Size: 24, Number: 3846
. 2010-05-27 11:53:02.823 Read 4 bytes (52 pending)
. 2010-05-27 11:53:02.823 Read 24 bytes (28 pending)
< 2010-05-27 11:53:02.823 Type: SSH_FXP_STATUS, Size: 24, Number: 4100
< 2010-05-27 11:53:02.823 Status code: 0
. 2010-05-27 11:53:02.823 Read 4 bytes (24 pending)
. 2010-05-27 11:53:02.823 Read 24 bytes (0 pending)
< 2010-05-27 11:53:02.823 Type: SSH_FXP_STATUS, Size: 24, Number: 3081
. 2010-05-27 11:53:02.823 File: "D:\Brokers\Incoming\05262010\Copy of 18917\{105C4D26-03E5-421E-BAD5-3ABC2D9740B3}.tif"
. 2010-05-27 11:53:02.823 Copying "D:\Brokers\Incoming\05262010\Copy of 18917\{105C4D26-03E5-421E-BAD5-3ABC2D9740B3}.tif" to remote directory started.
. 2010-05-27 11:53:02.839 Binary transfer mode selected.
. 2010-05-27 11:53:02.839 Opening remote file.
> 2010-05-27 11:53:02.839 Type: SSH_FXP_OPEN, Size: 142, Number: 4355
. 2010-05-27 11:53:02.839 Sent 146 bytes
. 2010-05-27 11:53:02.839 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:02.839 Waiting for another 4 bytes
. 2010-05-27 11:53:02.886 Detected network event
. 2010-05-27 11:53:02.886 Received 17 bytes (0)
. 2010-05-27 11:53:02.886 Read 4 bytes (13 pending)
. 2010-05-27 11:53:02.886 Read 13 bytes (0 pending)
< 2010-05-27 11:53:02.886 Type: SSH_FXP_HANDLE, Size: 13, Number: 4355
. 2010-05-27 11:53:02.886 Write request offset: 0, len: 6818
> 2010-05-27 11:53:02.886 Type: SSH_FXP_WRITE, Size: 6843, Number: 4870
. 2010-05-27 11:53:02.886 Sent 6847 bytes
. 2010-05-27 11:53:02.886 There are 0 bytes remaining in the send buffer
> 2010-05-27 11:53:02.886 Type: SSH_FXP_CLOSE, Size: 13, Number: 5124
. 2010-05-27 11:53:02.886 Sent 17 bytes
> 2010-05-27 11:53:02.886 Type: SSH_FXP_SETSTAT, Size: 142, Number: 4617
. 2010-05-27 11:53:02.886 Sent 146 bytes
. 2010-05-27 11:53:02.886 Waiting for another 4 bytes
. 2010-05-27 11:53:02.980 Detected network event
. 2010-05-27 11:53:02.980 Received 28 bytes (0)
. 2010-05-27 11:53:02.980 Read 4 bytes (24 pending)
. 2010-05-27 11:53:02.980 Read 24 bytes (0 pending)
< 2010-05-27 11:53:02.980 Type: SSH_FXP_STATUS, Size: 24, Number: 4870
. 2010-05-27 11:53:02.980 Waiting for another 4 bytes
. 2010-05-27 11:53:03.167 Detected network event
. 2010-05-27 11:53:03.167 Received 28 bytes (0)
. 2010-05-27 11:53:03.167 Read 4 bytes (52 pending)
. 2010-05-27 11:53:03.167 Read 24 bytes (28 pending)
< 2010-05-27 11:53:03.167 Type: SSH_FXP_STATUS, Size: 24, Number: 5124
< 2010-05-27 11:53:03.167 Status code: 0
. 2010-05-27 11:53:03.167 Read 4 bytes (24 pending)
. 2010-05-27 11:53:03.167 Read 24 bytes (0 pending)
< 2010-05-27 11:53:03.167 Type: SSH_FXP_STATUS, Size: 24, Number: 4617
. 2010-05-27 11:53:03.167 File: "D:\Brokers\Incoming\05262010\Copy of 18917\{49110D47-1D97-469D-8A4E-1E14489241D9}.tif"
. 2010-05-27 11:53:03.167 Copying "D:\Brokers\Incoming\05262010\Copy of 18917\{49110D47-1D97-469D-8A4E-1E14489241D9}.tif" to remote directory started.
. 2010-05-27 11:53:03.167 Binary transfer mode selected.
. 2010-05-27 11:53:03.167 Opening remote file.
> 2010-05-27 11:53:03.167 Type: SSH_FXP_OPEN, Size: 142, Number: 5379
. 2010-05-27 11:53:03.167 Sent 146 bytes
. 2010-05-27 11:53:03.167 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:03.167 Waiting for another 4 bytes
. 2010-05-27 11:53:03.214 Detected network event
. 2010-05-27 11:53:03.214 Received 17 bytes (0)
. 2010-05-27 11:53:03.214 Read 4 bytes (13 pending)
. 2010-05-27 11:53:03.214 Read 13 bytes (0 pending)
< 2010-05-27 11:53:03.214 Type: SSH_FXP_HANDLE, Size: 13, Number: 5379
. 2010-05-27 11:53:03.214 Write request offset: 0, len: 5803
> 2010-05-27 11:53:03.214 Type: SSH_FXP_WRITE, Size: 5828, Number: 5894
. 2010-05-27 11:53:03.214 Sent 5832 bytes
. 2010-05-27 11:53:03.214 There are 0 bytes remaining in the send buffer
> 2010-05-27 11:53:03.214 Type: SSH_FXP_CLOSE, Size: 13, Number: 6148
. 2010-05-27 11:53:03.214 Sent 17 bytes
> 2010-05-27 11:53:03.214 Type: SSH_FXP_SETSTAT, Size: 142, Number: 5641
. 2010-05-27 11:53:03.214 Sent 146 bytes
. 2010-05-27 11:53:03.214 Waiting for another 4 bytes
. 2010-05-27 11:53:03.308 Detected network event
. 2010-05-27 11:53:03.308 Received 28 bytes (0)
. 2010-05-27 11:53:03.308 Read 4 bytes (24 pending)
. 2010-05-27 11:53:03.308 Read 24 bytes (0 pending)
< 2010-05-27 11:53:03.308 Type: SSH_FXP_STATUS, Size: 24, Number: 5894
. 2010-05-27 11:53:03.308 Waiting for another 4 bytes
. 2010-05-27 11:53:03.480 Detected network event
. 2010-05-27 11:53:03.480 Received 28 bytes (0)
. 2010-05-27 11:53:03.480 Read 4 bytes (52 pending)
. 2010-05-27 11:53:03.480 Read 24 bytes (28 pending)
< 2010-05-27 11:53:03.480 Type: SSH_FXP_STATUS, Size: 24, Number: 6148
< 2010-05-27 11:53:03.480 Status code: 0
. 2010-05-27 11:53:03.480 Read 4 bytes (24 pending)
. 2010-05-27 11:53:03.480 Read 24 bytes (0 pending)
< 2010-05-27 11:53:03.480 Type: SSH_FXP_STATUS, Size: 24, Number: 5641
. 2010-05-27 11:53:03.480 File: "D:\Brokers\Incoming\05262010\Copy of 18917\{93599975-3610-4D34-BCBB-94C0D3A5AE08}.tif"
. 2010-05-27 11:53:03.480 Copying "D:\Brokers\Incoming\05262010\Copy of 18917\{93599975-3610-4D34-BCBB-94C0D3A5AE08}.tif" to remote directory started.
. 2010-05-27 11:53:03.480 Binary transfer mode selected.
. 2010-05-27 11:53:03.480 Opening remote file.
> 2010-05-27 11:53:03.480 Type: SSH_FXP_OPEN, Size: 142, Number: 6403
. 2010-05-27 11:53:03.480 Sent 146 bytes
. 2010-05-27 11:53:03.480 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:03.480 Waiting for another 4 bytes
. 2010-05-27 11:53:03.542 Detected network event
. 2010-05-27 11:53:03.542 Received 17 bytes (0)
. 2010-05-27 11:53:03.542 Read 4 bytes (13 pending)
. 2010-05-27 11:53:03.542 Read 13 bytes (0 pending)
< 2010-05-27 11:53:03.542 Type: SSH_FXP_HANDLE, Size: 13, Number: 6403
. 2010-05-27 11:53:03.542 Write request offset: 0, len: 12606
> 2010-05-27 11:53:03.542 Type: SSH_FXP_WRITE, Size: 12631, Number: 6918
. 2010-05-27 11:53:03.542 Sent 12635 bytes
. 2010-05-27 11:53:03.542 There are 0 bytes remaining in the send buffer
> 2010-05-27 11:53:03.542 Type: SSH_FXP_CLOSE, Size: 13, Number: 7172
. 2010-05-27 11:53:03.542 Sent 17 bytes
> 2010-05-27 11:53:03.542 Type: SSH_FXP_SETSTAT, Size: 142, Number: 6665
. 2010-05-27 11:53:03.542 Sent 146 bytes
. 2010-05-27 11:53:03.542 Waiting for another 4 bytes
. 2010-05-27 11:53:03.589 Detected network event
. 2010-05-27 11:53:03.589 Received 28 bytes (0)
. 2010-05-27 11:53:03.589 Read 4 bytes (24 pending)
. 2010-05-27 11:53:03.589 Read 24 bytes (0 pending)
< 2010-05-27 11:53:03.589 Type: SSH_FXP_STATUS, Size: 24, Number: 6918
. 2010-05-27 11:53:03.589 Waiting for another 4 bytes
. 2010-05-27 11:53:03.823 Detected network event
. 2010-05-27 11:53:03.823 Received 28 bytes (0)
. 2010-05-27 11:53:03.823 Read 4 bytes (52 pending)
. 2010-05-27 11:53:03.823 Read 24 bytes (28 pending)
< 2010-05-27 11:53:03.823 Type: SSH_FXP_STATUS, Size: 24, Number: 7172
< 2010-05-27 11:53:03.823 Status code: 0
. 2010-05-27 11:53:03.823 Read 4 bytes (24 pending)
. 2010-05-27 11:53:03.823 Read 24 bytes (0 pending)
< 2010-05-27 11:53:03.823 Type: SSH_FXP_STATUS, Size: 24, Number: 6665
. 2010-05-27 11:53:03.823 File: "D:\Brokers\Incoming\05262010\Copy of 18917\{C8E97957-27EB-47C9-9F13-1FF2B4CB412E}.tif"
. 2010-05-27 11:53:03.823 Copying "D:\Brokers\Incoming\05262010\Copy of 18917\{C8E97957-27EB-47C9-9F13-1FF2B4CB412E}.tif" to remote directory started.
. 2010-05-27 11:53:03.823 Binary transfer mode selected.
. 2010-05-27 11:53:03.823 Opening remote file.
> 2010-05-27 11:53:03.823 Type: SSH_FXP_OPEN, Size: 142, Number: 7427
. 2010-05-27 11:53:03.823 Sent 146 bytes
. 2010-05-27 11:53:03.823 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:03.823 Waiting for another 4 bytes
. 2010-05-27 11:53:03.870 Detected network event
. 2010-05-27 11:53:03.870 Received 17 bytes (0)
. 2010-05-27 11:53:03.870 Read 4 bytes (13 pending)
. 2010-05-27 11:53:03.870 Read 13 bytes (0 pending)
< 2010-05-27 11:53:03.870 Type: SSH_FXP_HANDLE, Size: 13, Number: 7427
. 2010-05-27 11:53:03.870 Write request offset: 0, len: 4251
> 2010-05-27 11:53:03.870 Type: SSH_FXP_WRITE, Size: 4276, Number: 7942
. 2010-05-27 11:53:03.870 Sent 4280 bytes
. 2010-05-27 11:53:03.870 There are 0 bytes remaining in the send buffer
> 2010-05-27 11:53:03.870 Type: SSH_FXP_CLOSE, Size: 13, Number: 8196
. 2010-05-27 11:53:03.870 Sent 17 bytes
> 2010-05-27 11:53:03.870 Type: SSH_FXP_SETSTAT, Size: 142, Number: 7689
. 2010-05-27 11:53:03.870 Sent 146 bytes
. 2010-05-27 11:53:03.870 Waiting for another 4 bytes
. 2010-05-27 11:53:03.964 Detected network event
. 2010-05-27 11:53:03.964 Received 28 bytes (0)
. 2010-05-27 11:53:03.964 Read 4 bytes (24 pending)
. 2010-05-27 11:53:03.964 Read 24 bytes (0 pending)
< 2010-05-27 11:53:03.964 Type: SSH_FXP_STATUS, Size: 24, Number: 7942
. 2010-05-27 11:53:03.964 Waiting for another 4 bytes
. 2010-05-27 11:53:04.136 Detected network event
. 2010-05-27 11:53:04.136 Received 28 bytes (0)
. 2010-05-27 11:53:04.136 Read 4 bytes (52 pending)
. 2010-05-27 11:53:04.136 Read 24 bytes (28 pending)
< 2010-05-27 11:53:04.136 Type: SSH_FXP_STATUS, Size: 24, Number: 8196
< 2010-05-27 11:53:04.136 Status code: 0
. 2010-05-27 11:53:04.136 Read 4 bytes (24 pending)
. 2010-05-27 11:53:04.136 Read 24 bytes (0 pending)
< 2010-05-27 11:53:04.136 Type: SSH_FXP_STATUS, Size: 24, Number: 7689
. 2010-05-27 11:53:04.136 File: "D:\Brokers\Incoming\05262010\Copy of 18917\{F59B1BC7-102C-4532-A9D7-63320493063C}.tif"
. 2010-05-27 11:53:04.136 Copying "D:\Brokers\Incoming\05262010\Copy of 18917\{F59B1BC7-102C-4532-A9D7-63320493063C}.tif" to remote directory started.
. 2010-05-27 11:53:04.136 Binary transfer mode selected.
. 2010-05-27 11:53:04.136 Opening remote file.
> 2010-05-27 11:53:04.136 Type: SSH_FXP_OPEN, Size: 142, Number: 8451
. 2010-05-27 11:53:04.136 Sent 146 bytes
. 2010-05-27 11:53:04.136 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:04.136 Waiting for another 4 bytes
. 2010-05-27 11:53:04.214 Detected network event
. 2010-05-27 11:53:04.214 Received 17 bytes (0)
. 2010-05-27 11:53:04.214 Read 4 bytes (13 pending)
. 2010-05-27 11:53:04.214 Read 13 bytes (0 pending)
< 2010-05-27 11:53:04.214 Type: SSH_FXP_HANDLE, Size: 13, Number: 8451
. 2010-05-27 11:53:04.214 Write request offset: 0, len: 8064
> 2010-05-27 11:53:04.214 Type: SSH_FXP_WRITE, Size: 8089, Number: 8966
. 2010-05-27 11:53:04.214 Sent 8093 bytes
. 2010-05-27 11:53:04.214 There are 0 bytes remaining in the send buffer
> 2010-05-27 11:53:04.214 Type: SSH_FXP_CLOSE, Size: 13, Number: 9220
. 2010-05-27 11:53:04.214 Sent 17 bytes
> 2010-05-27 11:53:04.214 Type: SSH_FXP_SETSTAT, Size: 142, Number: 8713
. 2010-05-27 11:53:04.214 Sent 146 bytes
. 2010-05-27 11:53:04.214 Waiting for another 4 bytes
. 2010-05-27 11:53:04.261 Detected network event
. 2010-05-27 11:53:04.261 Received 28 bytes (0)
. 2010-05-27 11:53:04.261 Read 4 bytes (24 pending)
. 2010-05-27 11:53:04.261 Read 24 bytes (0 pending)
< 2010-05-27 11:53:04.261 Type: SSH_FXP_STATUS, Size: 24, Number: 8966
. 2010-05-27 11:53:04.261 Waiting for another 4 bytes
. 2010-05-27 11:53:04.464 Detected network event
. 2010-05-27 11:53:04.464 Received 28 bytes (0)
. 2010-05-27 11:53:04.464 Read 4 bytes (52 pending)
. 2010-05-27 11:53:04.464 Read 24 bytes (28 pending)
< 2010-05-27 11:53:04.464 Type: SSH_FXP_STATUS, Size: 24, Number: 9220
< 2010-05-27 11:53:04.464 Status code: 0
. 2010-05-27 11:53:04.464 Read 4 bytes (24 pending)
. 2010-05-27 11:53:04.464 Read 24 bytes (0 pending)
< 2010-05-27 11:53:04.464 Type: SSH_FXP_STATUS, Size: 24, Number: 8713
. 2010-05-27 11:53:04.464 Session upkeep
. 2010-05-27 11:53:04.479 Copying 1 files/directories to remote directory "/p8_shared/P8SharedFolders/Inbound/Brokers/InComing/05262010/"
. 2010-05-27 11:53:04.479 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: Yes (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-05-27 11:53:04.479 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-05-27 11:53:04.479 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-05-27 11:53:04.479 File: "D:\Brokers\Incoming\05262010\Copy (99) of 18917"
. 2010-05-27 11:53:04.479 Trying to open directory "/p8_shared/P8SharedFolders/Inbound/Brokers/InComing/05262010/Copy (99) of 18917/".
> 2010-05-27 11:53:04.479 Type: SSH_FXP_LSTAT, Size: 89, Number: 9479
. 2010-05-27 11:53:04.479 Sent 93 bytes
. 2010-05-27 11:53:04.479 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:04.479 Waiting for another 4 bytes
. 2010-05-27 11:53:04.526 Detected network event
. 2010-05-27 11:53:04.526 Received 41 bytes (0)
. 2010-05-27 11:53:04.526 Read 4 bytes (37 pending)
. 2010-05-27 11:53:04.526 Read 37 bytes (0 pending)
< 2010-05-27 11:53:04.526 Type: SSH_FXP_ATTRS, Size: 37, Number: 9479
. 2010-05-27 11:53:04.526 File: "D:\Brokers\Incoming\05262010\Copy (99) of 18917\18917.XML"
. 2010-05-27 11:53:04.526 Copying "D:\Brokers\Incoming\05262010\Copy (99) of 18917\18917.XML" to remote directory started.
. 2010-05-27 11:53:04.526 Ascii transfer mode selected.
. 2010-05-27 11:53:04.526 Opening remote file.
> 2010-05-27 11:53:04.526 Type: SSH_FXP_OPEN, Size: 114, Number: 9731
. 2010-05-27 11:53:04.526 Sent 118 bytes
. 2010-05-27 11:53:04.526 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:04.526 Waiting for another 4 bytes
. 2010-05-27 11:53:04.573 Detected network event
. 2010-05-27 11:53:04.573 Received 17 bytes (0)
. 2010-05-27 11:53:04.573 Read 4 bytes (13 pending)
. 2010-05-27 11:53:04.573 Read 13 bytes (0 pending)
< 2010-05-27 11:53:04.573 Type: SSH_FXP_HANDLE, Size: 13, Number: 9731
. 2010-05-27 11:53:04.573 Write request offset: 0, len: 3871
> 2010-05-27 11:53:04.573 Type: SSH_FXP_WRITE, Size: 3896, Number: 10246
. 2010-05-27 11:53:04.573 Sent 3900 bytes
. 2010-05-27 11:53:04.573 There are 0 bytes remaining in the send buffer
> 2010-05-27 11:53:04.573 Type: SSH_FXP_CLOSE, Size: 13, Number: 10500
. 2010-05-27 11:53:04.573 Sent 17 bytes
> 2010-05-27 11:53:04.573 Type: SSH_FXP_SETSTAT, Size: 114, Number: 9993
. 2010-05-27 11:53:04.573 Sent 118 bytes
. 2010-05-27 11:53:04.573 Waiting for another 4 bytes
. 2010-05-27 11:53:04.620 Detected network event
. 2010-05-27 11:53:04.620 Waiting for another 4 bytes
. 2010-05-27 11:53:04.808 Detected network event
. 2010-05-27 11:53:04.808 Received 28 bytes (0)
. 2010-05-27 11:53:04.808 Read 4 bytes (80 pending)
. 2010-05-27 11:53:04.808 Read 24 bytes (56 pending)
< 2010-05-27 11:53:04.808 Type: SSH_FXP_STATUS, Size: 24, Number: 10246
. 2010-05-27 11:53:04.808 Read 4 bytes (52 pending)
. 2010-05-27 11:53:04.808 Read 24 bytes (28 pending)
< 2010-05-27 11:53:04.808 Type: SSH_FXP_STATUS, Size: 24, Number: 10500
< 2010-05-27 11:53:04.808 Status code: 0
. 2010-05-27 11:53:04.808 Read 4 bytes (24 pending)
. 2010-05-27 11:53:04.808 Read 24 bytes (0 pending)
< 2010-05-27 11:53:04.808 Type: SSH_FXP_STATUS, Size: 24, Number: 9993
. 2010-05-27 11:53:04.808 File: "D:\Brokers\Incoming\05262010\Copy (99) of 18917\incoming.touch"
. 2010-05-27 11:53:04.808 Copying "D:\Brokers\Incoming\05262010\Copy (99) of 18917\incoming.touch" to remote directory started.
. 2010-05-27 11:53:04.808 Binary transfer mode selected.
. 2010-05-27 11:53:04.808 Opening remote file.
> 2010-05-27 11:53:04.808 Type: SSH_FXP_OPEN, Size: 119, Number: 10755
. 2010-05-27 11:53:04.808 Sent 123 bytes
. 2010-05-27 11:53:04.808 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:04.808 Waiting for another 4 bytes
. 2010-05-27 11:53:04.854 Detected network event
. 2010-05-27 11:53:04.854 Received 17 bytes (0)
. 2010-05-27 11:53:04.854 Read 4 bytes (13 pending)
. 2010-05-27 11:53:04.854 Read 13 bytes (0 pending)
< 2010-05-27 11:53:04.854 Type: SSH_FXP_HANDLE, Size: 13, Number: 10755
> 2010-05-27 11:53:04.854 Type: SSH_FXP_CLOSE, Size: 13, Number: 11268
. 2010-05-27 11:53:04.854 Sent 17 bytes
. 2010-05-27 11:53:04.854 There are 0 bytes remaining in the send buffer
> 2010-05-27 11:53:04.854 Type: SSH_FXP_SETSTAT, Size: 119, Number: 11017
. 2010-05-27 11:53:04.854 Sent 123 bytes
. 2010-05-27 11:53:04.854 Waiting for another 4 bytes
. 2010-05-27 11:53:04.901 Detected network event
. 2010-05-27 11:53:04.901 Received 28 bytes (0)
. 2010-05-27 11:53:04.901 Read 4 bytes (24 pending)
. 2010-05-27 11:53:04.901 Read 24 bytes (0 pending)
< 2010-05-27 11:53:04.901 Type: SSH_FXP_STATUS, Size: 24, Number: 11268
< 2010-05-27 11:53:04.901 Status code: 0
. 2010-05-27 11:53:04.901 Waiting for another 4 bytes
. 2010-05-27 11:53:04.948 Detected network event
. 2010-05-27 11:53:04.948 Received 28 bytes (0)
. 2010-05-27 11:53:04.948 Read 4 bytes (24 pending)
. 2010-05-27 11:53:04.948 Read 24 bytes (0 pending)
< 2010-05-27 11:53:04.948 Type: SSH_FXP_STATUS, Size: 24, Number: 11017
< 2010-05-27 11:53:04.948 Status code: 0
. 2010-05-27 11:53:04.948 File: "D:\Brokers\Incoming\05262010\Copy (99) of 18917\Thumbs.db"
. 2010-05-27 11:53:04.948 Copying "D:\Brokers\Incoming\05262010\Copy (99) of 18917\Thumbs.db" to remote directory started.
. 2010-05-27 11:53:04.948 Binary transfer mode selected.
. 2010-05-27 11:53:04.948 Opening remote file.
> 2010-05-27 11:53:04.948 Type: SSH_FXP_OPEN, Size: 114, Number: 11523
. 2010-05-27 11:53:04.948 Sent 118 bytes
. 2010-05-27 11:53:04.948 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:04.948 Waiting for another 4 bytes
. 2010-05-27 11:53:04.995 Detected network event
. 2010-05-27 11:53:04.995 Received 17 bytes (0)
. 2010-05-27 11:53:04.995 Read 4 bytes (13 pending)
. 2010-05-27 11:53:04.995 Read 13 bytes (0 pending)
< 2010-05-27 11:53:04.995 Type: SSH_FXP_HANDLE, Size: 13, Number: 11523
. 2010-05-27 11:53:04.995 Write request offset: 0, len: 4096
> 2010-05-27 11:53:04.995 Type: SSH_FXP_WRITE, Size: 4121, Number: 12038
. 2010-05-27 11:53:04.995 Sent 4125 bytes
. 2010-05-27 11:53:04.995 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:04.995 Write request offset: 4096, len: 9706
> 2010-05-27 11:53:04.995 Type: SSH_FXP_WRITE, Size: 9731, Number: 12294
. 2010-05-27 11:53:04.995 Sent 9735 bytes
. 2010-05-27 11:53:04.995 Write request offset: 13802, len: 4630
> 2010-05-27 11:53:04.995 Type: SSH_FXP_WRITE, Size: 4655, Number: 12550
. 2010-05-27 11:53:04.995 Sent 4659 bytes
> 2010-05-27 11:53:04.995 Type: SSH_FXP_CLOSE, Size: 13, Number: 12804
. 2010-05-27 11:53:04.995 Sent 17 bytes
> 2010-05-27 11:53:04.995 Type: SSH_FXP_SETSTAT, Size: 114, Number: 11785
. 2010-05-27 11:53:04.995 Sent 118 bytes
. 2010-05-27 11:53:04.995 Waiting for another 4 bytes
. 2010-05-27 11:53:05.042 Detected network event
. 2010-05-27 11:53:05.042 Received 28 bytes (0)
. 2010-05-27 11:53:05.042 Read 4 bytes (24 pending)
. 2010-05-27 11:53:05.042 Read 24 bytes (0 pending)
< 2010-05-27 11:53:05.042 Type: SSH_FXP_STATUS, Size: 24, Number: 12038
. 2010-05-27 11:53:05.042 Waiting for another 4 bytes
. 2010-05-27 11:53:05.229 Detected network event
. 2010-05-27 11:53:05.229 Received 28 bytes (0)
. 2010-05-27 11:53:05.229 Read 4 bytes (108 pending)
. 2010-05-27 11:53:05.229 Read 24 bytes (84 pending)
< 2010-05-27 11:53:05.229 Type: SSH_FXP_STATUS, Size: 24, Number: 12294
. 2010-05-27 11:53:05.229 Read 4 bytes (80 pending)
. 2010-05-27 11:53:05.229 Read 24 bytes (56 pending)
< 2010-05-27 11:53:05.229 Type: SSH_FXP_STATUS, Size: 24, Number: 12550
. 2010-05-27 11:53:05.229 Read 4 bytes (52 pending)
. 2010-05-27 11:53:05.229 Read 24 bytes (28 pending)
< 2010-05-27 11:53:05.229 Type: SSH_FXP_STATUS, Size: 24, Number: 12804
< 2010-05-27 11:53:05.229 Status code: 0
. 2010-05-27 11:53:05.229 Read 4 bytes (24 pending)
. 2010-05-27 11:53:05.229 Read 24 bytes (0 pending)
< 2010-05-27 11:53:05.229 Type: SSH_FXP_STATUS, Size: 24, Number: 11785
. 2010-05-27 11:53:05.229 File: "D:\Brokers\Incoming\05262010\Copy (99) of 18917\{105C4D26-03E5-421E-BAD5-3ABC2D9740B3}.tif"
. 2010-05-27 11:53:05.229 Copying "D:\Brokers\Incoming\05262010\Copy (99) of 18917\{105C4D26-03E5-421E-BAD5-3ABC2D9740B3}.tif" to remote directory started.
. 2010-05-27 11:53:05.229 Binary transfer mode selected.
. 2010-05-27 11:53:05.229 Opening remote file.
> 2010-05-27 11:53:05.229 Type: SSH_FXP_OPEN, Size: 147, Number: 13059
. 2010-05-27 11:53:05.229 Sent 151 bytes
. 2010-05-27 11:53:05.229 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:05.229 Waiting for another 4 bytes
. 2010-05-27 11:53:05.276 Detected network event
. 2010-05-27 11:53:05.276 Received 17 bytes (0)
. 2010-05-27 11:53:05.276 Read 4 bytes (13 pending)
. 2010-05-27 11:53:05.276 Read 13 bytes (0 pending)
< 2010-05-27 11:53:05.276 Type: SSH_FXP_HANDLE, Size: 13, Number: 13059
. 2010-05-27 11:53:05.276 Write request offset: 0, len: 6818
> 2010-05-27 11:53:05.276 Type: SSH_FXP_WRITE, Size: 6843, Number: 13574
. 2010-05-27 11:53:05.292 Sent 6847 bytes
. 2010-05-27 11:53:05.292 There are 0 bytes remaining in the send buffer
> 2010-05-27 11:53:05.292 Type: SSH_FXP_CLOSE, Size: 13, Number: 13828
. 2010-05-27 11:53:05.292 Sent 17 bytes
> 2010-05-27 11:53:05.292 Type: SSH_FXP_SETSTAT, Size: 147, Number: 13321
. 2010-05-27 11:53:05.292 Sent 151 bytes
. 2010-05-27 11:53:05.292 Waiting for another 4 bytes
. 2010-05-27 11:53:05.386 Detected network event
. 2010-05-27 11:53:05.386 Received 28 bytes (0)
. 2010-05-27 11:53:05.386 Read 4 bytes (24 pending)
. 2010-05-27 11:53:05.386 Read 24 bytes (0 pending)
< 2010-05-27 11:53:05.386 Type: SSH_FXP_STATUS, Size: 24, Number: 13574
. 2010-05-27 11:53:05.386 Waiting for another 4 bytes
. 2010-05-27 11:53:05.573 Detected network event
. 2010-05-27 11:53:05.573 Received 28 bytes (0)
. 2010-05-27 11:53:05.573 Read 4 bytes (52 pending)
. 2010-05-27 11:53:05.573 Read 24 bytes (28 pending)
< 2010-05-27 11:53:05.573 Type: SSH_FXP_STATUS, Size: 24, Number: 13828
< 2010-05-27 11:53:05.573 Status code: 0
. 2010-05-27 11:53:05.573 Read 4 bytes (24 pending)
. 2010-05-27 11:53:05.573 Read 24 bytes (0 pending)
< 2010-05-27 11:53:05.573 Type: SSH_FXP_STATUS, Size: 24, Number: 13321
. 2010-05-27 11:53:05.573 File: "D:\Brokers\Incoming\05262010\Copy (99) of 18917\{49110D47-1D97-469D-8A4E-1E14489241D9}.tif"
. 2010-05-27 11:53:05.573 Copying "D:\Brokers\Incoming\05262010\Copy (99) of 18917\{49110D47-1D97-469D-8A4E-1E14489241D9}.tif" to remote directory started.
. 2010-05-27 11:53:05.573 Binary transfer mode selected.
. 2010-05-27 11:53:05.573 Opening remote file.
> 2010-05-27 11:53:05.573 Type: SSH_FXP_OPEN, Size: 147, Number: 14083
. 2010-05-27 11:53:05.573 Sent 151 bytes
. 2010-05-27 11:53:05.573 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:05.573 Waiting for another 4 bytes
. 2010-05-27 11:53:05.620 Detected network event
. 2010-05-27 11:53:05.620 Received 17 bytes (0)
. 2010-05-27 11:53:05.620 Read 4 bytes (13 pending)
. 2010-05-27 11:53:05.620 Read 13 bytes (0 pending)
< 2010-05-27 11:53:05.620 Type: SSH_FXP_HANDLE, Size: 13, Number: 14083
. 2010-05-27 11:53:05.620 Write request offset: 0, len: 5803
> 2010-05-27 11:53:05.620 Type: SSH_FXP_WRITE, Size: 5828, Number: 14598
. 2010-05-27 11:53:05.620 Sent 5832 bytes
. 2010-05-27 11:53:05.620 There are 0 bytes remaining in the send buffer
> 2010-05-27 11:53:05.620 Type: SSH_FXP_CLOSE, Size: 13, Number: 14852
. 2010-05-27 11:53:05.620 Sent 17 bytes
> 2010-05-27 11:53:05.620 Type: SSH_FXP_SETSTAT, Size: 147, Number: 14345
. 2010-05-27 11:53:05.620 Sent 151 bytes
. 2010-05-27 11:53:05.620 Waiting for another 4 bytes
. 2010-05-27 11:53:05.714 Detected network event
. 2010-05-27 11:53:05.714 Received 28 bytes (0)
. 2010-05-27 11:53:05.714 Read 4 bytes (24 pending)
. 2010-05-27 11:53:05.714 Read 24 bytes (0 pending)
< 2010-05-27 11:53:05.714 Type: SSH_FXP_STATUS, Size: 24, Number: 14598
. 2010-05-27 11:53:05.714 Waiting for another 4 bytes
. 2010-05-27 11:53:05.886 Detected network event
. 2010-05-27 11:53:05.886 Received 28 bytes (0)
. 2010-05-27 11:53:05.886 Read 4 bytes (52 pending)
. 2010-05-27 11:53:05.901 Read 24 bytes (28 pending)
< 2010-05-27 11:53:05.901 Type: SSH_FXP_STATUS, Size: 24, Number: 14852
< 2010-05-27 11:53:05.901 Status code: 0
. 2010-05-27 11:53:05.901 Read 4 bytes (24 pending)
. 2010-05-27 11:53:05.901 Read 24 bytes (0 pending)
< 2010-05-27 11:53:05.901 Type: SSH_FXP_STATUS, Size: 24, Number: 14345
. 2010-05-27 11:53:05.901 File: "D:\Brokers\Incoming\05262010\Copy (99) of 18917\{93599975-3610-4D34-BCBB-94C0D3A5AE08}.tif"
. 2010-05-27 11:53:05.901 Copying "D:\Brokers\Incoming\05262010\Copy (99) of 18917\{93599975-3610-4D34-BCBB-94C0D3A5AE08}.tif" to remote directory started.
. 2010-05-27 11:53:05.901 Binary transfer mode selected.
. 2010-05-27 11:53:05.901 Opening remote file.
> 2010-05-27 11:53:05.901 Type: SSH_FXP_OPEN, Size: 147, Number: 15107
. 2010-05-27 11:53:05.901 Sent 151 bytes
. 2010-05-27 11:53:05.901 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:05.901 Waiting for another 4 bytes
. 2010-05-27 11:53:05.948 Detected network event
. 2010-05-27 11:53:05.948 Received 17 bytes (0)
. 2010-05-27 11:53:05.948 Read 4 bytes (13 pending)
. 2010-05-27 11:53:05.948 Read 13 bytes (0 pending)
< 2010-05-27 11:53:05.948 Type: SSH_FXP_HANDLE, Size: 13, Number: 15107
. 2010-05-27 11:53:05.948 Write request offset: 0, len: 12606
> 2010-05-27 11:53:05.948 Type: SSH_FXP_WRITE, Size: 12631, Number: 15622
. 2010-05-27 11:53:05.948 Sent 12635 bytes
. 2010-05-27 11:53:05.948 There are 0 bytes remaining in the send buffer
> 2010-05-27 11:53:05.948 Type: SSH_FXP_CLOSE, Size: 13, Number: 15876
. 2010-05-27 11:53:05.948 Sent 17 bytes
> 2010-05-27 11:53:05.948 Type: SSH_FXP_SETSTAT, Size: 147, Number: 15369
. 2010-05-27 11:53:05.948 Sent 151 bytes
. 2010-05-27 11:53:05.948 Waiting for another 4 bytes
. 2010-05-27 11:53:05.995 Detected network event
. 2010-05-27 11:53:05.995 Received 28 bytes (0)
. 2010-05-27 11:53:05.995 Read 4 bytes (24 pending)
. 2010-05-27 11:53:05.995 Read 24 bytes (0 pending)
< 2010-05-27 11:53:05.995 Type: SSH_FXP_STATUS, Size: 24, Number: 15622
. 2010-05-27 11:53:05.995 Waiting for another 4 bytes
. 2010-05-27 11:53:06.229 Detected network event
. 2010-05-27 11:53:06.229 Received 28 bytes (0)
. 2010-05-27 11:53:06.229 Read 4 bytes (52 pending)
. 2010-05-27 11:53:06.229 Read 24 bytes (28 pending)
< 2010-05-27 11:53:06.229 Type: SSH_FXP_STATUS, Size: 24, Number: 15876
< 2010-05-27 11:53:06.229 Status code: 0
. 2010-05-27 11:53:06.229 Read 4 bytes (24 pending)
. 2010-05-27 11:53:06.229 Read 24 bytes (0 pending)
< 2010-05-27 11:53:06.229 Type: SSH_FXP_STATUS, Size: 24, Number: 15369
. 2010-05-27 11:53:06.229 File: "D:\Brokers\Incoming\05262010\Copy (99) of 18917\{C8E97957-27EB-47C9-9F13-1FF2B4CB412E}.tif"
. 2010-05-27 11:53:06.229 Copying "D:\Brokers\Incoming\05262010\Copy (99) of 18917\{C8E97957-27EB-47C9-9F13-1FF2B4CB412E}.tif" to remote directory started.
. 2010-05-27 11:53:06.229 Binary transfer mode selected.
. 2010-05-27 11:53:06.229 Opening remote file.
> 2010-05-27 11:53:06.229 Type: SSH_FXP_OPEN, Size: 147, Number: 16131
. 2010-05-27 11:53:06.229 Sent 151 bytes
. 2010-05-27 11:53:06.229 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:06.229 Waiting for another 4 bytes
. 2010-05-27 11:53:06.276 Detected network event
. 2010-05-27 11:53:06.276 Received 17 bytes (0)
. 2010-05-27 11:53:06.276 Read 4 bytes (13 pending)
. 2010-05-27 11:53:06.276 Read 13 bytes (0 pending)
< 2010-05-27 11:53:06.276 Type: SSH_FXP_HANDLE, Size: 13, Number: 16131
. 2010-05-27 11:53:06.276 Write request offset: 0, len: 4251
> 2010-05-27 11:53:06.276 Type: SSH_FXP_WRITE, Size: 4276, Number: 16646
. 2010-05-27 11:53:06.276 Sent 4280 bytes
. 2010-05-27 11:53:06.276 There are 0 bytes remaining in the send buffer
> 2010-05-27 11:53:06.276 Type: SSH_FXP_CLOSE, Size: 13, Number: 16900
. 2010-05-27 11:53:06.276 Sent 17 bytes
> 2010-05-27 11:53:06.276 Type: SSH_FXP_SETSTAT, Size: 147, Number: 16393
. 2010-05-27 11:53:06.276 Sent 151 bytes
. 2010-05-27 11:53:06.276 Waiting for another 4 bytes
. 2010-05-27 11:53:06.370 Detected network event
. 2010-05-27 11:53:06.370 Received 28 bytes (0)
. 2010-05-27 11:53:06.370 Read 4 bytes (24 pending)
. 2010-05-27 11:53:06.370 Read 24 bytes (0 pending)
< 2010-05-27 11:53:06.370 Type: SSH_FXP_STATUS, Size: 24, Number: 16646
. 2010-05-27 11:53:06.370 Waiting for another 4 bytes
. 2010-05-27 11:53:06.542 Detected network event
. 2010-05-27 11:53:06.542 Received 28 bytes (0)
. 2010-05-27 11:53:06.542 Read 4 bytes (52 pending)
. 2010-05-27 11:53:06.542 Read 24 bytes (28 pending)
< 2010-05-27 11:53:06.542 Type: SSH_FXP_STATUS, Size: 24, Number: 16900
< 2010-05-27 11:53:06.542 Status code: 0
. 2010-05-27 11:53:06.542 Read 4 bytes (24 pending)
. 2010-05-27 11:53:06.542 Read 24 bytes (0 pending)
< 2010-05-27 11:53:06.542 Type: SSH_FXP_STATUS, Size: 24, Number: 16393
. 2010-05-27 11:53:06.542 File: "D:\Brokers\Incoming\05262010\Copy (99) of 18917\{F59B1BC7-102C-4532-A9D7-63320493063C}.tif"
. 2010-05-27 11:53:06.542 Copying "D:\Brokers\Incoming\05262010\Copy (99) of 18917\{F59B1BC7-102C-4532-A9D7-63320493063C}.tif" to remote directory started.
. 2010-05-27 11:53:06.557 Binary transfer mode selected.
. 2010-05-27 11:53:06.557 Opening remote file.
> 2010-05-27 11:53:06.557 Type: SSH_FXP_OPEN, Size: 147, Number: 17155
. 2010-05-27 11:53:06.557 Sent 151 bytes
. 2010-05-27 11:53:06.557 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:06.557 Waiting for another 4 bytes
. 2010-05-27 11:53:06.604 Detected network event
. 2010-05-27 11:53:06.604 Received 17 bytes (0)
. 2010-05-27 11:53:06.604 Read 4 bytes (13 pending)
. 2010-05-27 11:53:06.604 Read 13 bytes (0 pending)
< 2010-05-27 11:53:06.604 Type: SSH_FXP_HANDLE, Size: 13, Number: 17155
. 2010-05-27 11:53:06.604 Write request offset: 0, len: 8064
> 2010-05-27 11:53:06.604 Type: SSH_FXP_WRITE, Size: 8089, Number: 17670
. 2010-05-27 11:53:06.604 Sent 8093 bytes
. 2010-05-27 11:53:06.604 There are 0 bytes remaining in the send buffer
> 2010-05-27 11:53:06.604 Type: SSH_FXP_CLOSE, Size: 13, Number: 17924
. 2010-05-27 11:53:06.604 Sent 17 bytes
> 2010-05-27 11:53:06.604 Type: SSH_FXP_SETSTAT, Size: 147, Number: 17417
. 2010-05-27 11:53:06.604 Sent 151 bytes
. 2010-05-27 11:53:06.604 Waiting for another 4 bytes
. 2010-05-27 11:53:06.651 Detected network event
. 2010-05-27 11:53:06.651 Received 28 bytes (0)
. 2010-05-27 11:53:06.651 Read 4 bytes (24 pending)
. 2010-05-27 11:53:06.651 Read 24 bytes (0 pending)
< 2010-05-27 11:53:06.651 Type: SSH_FXP_STATUS, Size: 24, Number: 17670
. 2010-05-27 11:53:06.651 Waiting for another 4 bytes
. 2010-05-27 11:53:06.886 Detected network event
. 2010-05-27 11:53:06.886 Received 28 bytes (0)
. 2010-05-27 11:53:06.886 Read 4 bytes (52 pending)
. 2010-05-27 11:53:06.886 Read 24 bytes (28 pending)
< 2010-05-27 11:53:06.886 Type: SSH_FXP_STATUS, Size: 24, Number: 17924
< 2010-05-27 11:53:06.886 Status code: 0
. 2010-05-27 11:53:06.886 Read 4 bytes (24 pending)
. 2010-05-27 11:53:06.886 Read 24 bytes (0 pending)
< 2010-05-27 11:53:06.886 Type: SSH_FXP_STATUS, Size: 24, Number: 17417
. 2010-05-27 11:53:06.886 Session upkeep
. 2010-05-27 11:53:06.886 Copying 1 files/directories to remote directory "/p8_shared/P8SharedFolders/Inbound/Brokers/InComing/05262010/"
. 2010-05-27 11:53:06.886 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: Yes (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-05-27 11:53:06.886 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-05-27 11:53:06.886 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-05-27 11:53:06.886 File: "D:\Brokers\Incoming\05262010\Copy (98) of 18917"
. 2010-05-27 11:53:06.886 Trying to open directory "/p8_shared/P8SharedFolders/Inbound/Brokers/InComing/05262010/Copy (98) of 18917/".
> 2010-05-27 11:53:06.886 Type: SSH_FXP_LSTAT, Size: 89, Number: 18183
. 2010-05-27 11:53:06.886 Sent 93 bytes
. 2010-05-27 11:53:06.886 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:06.886 Waiting for another 4 bytes
. 2010-05-27 11:53:06.932 Detected network event
. 2010-05-27 11:53:06.932 Received 41 bytes (0)
. 2010-05-27 11:53:06.932 Read 4 bytes (37 pending)
. 2010-05-27 11:53:06.932 Read 37 bytes (0 pending)
< 2010-05-27 11:53:06.932 Type: SSH_FXP_ATTRS, Size: 37, Number: 18183
. 2010-05-27 11:53:06.932 File: "D:\Brokers\Incoming\05262010\Copy (98) of 18917\18917.XML"
. 2010-05-27 11:53:06.932 Copying "D:\Brokers\Incoming\05262010\Copy (98) of 18917\18917.XML" to remote directory started.
. 2010-05-27 11:53:06.932 Ascii transfer mode selected.
. 2010-05-27 11:53:06.932 Opening remote file.
> 2010-05-27 11:53:06.932 Type: SSH_FXP_OPEN, Size: 114, Number: 18435
. 2010-05-27 11:53:06.932 Sent 118 bytes
. 2010-05-27 11:53:06.932 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:06.932 Waiting for another 4 bytes
. 2010-05-27 11:53:06.979 Detected network event
. 2010-05-27 11:53:06.979 Received 17 bytes (0)
. 2010-05-27 11:53:06.979 Read 4 bytes (13 pending)
. 2010-05-27 11:53:06.979 Read 13 bytes (0 pending)
< 2010-05-27 11:53:06.979 Type: SSH_FXP_HANDLE, Size: 13, Number: 18435
. 2010-05-27 11:53:06.979 Write request offset: 0, len: 3871
> 2010-05-27 11:53:06.979 Type: SSH_FXP_WRITE, Size: 3896, Number: 18950
. 2010-05-27 11:53:06.979 Sent 3900 bytes
. 2010-05-27 11:53:06.979 There are 0 bytes remaining in the send buffer
> 2010-05-27 11:53:06.979 Type: SSH_FXP_CLOSE, Size: 13, Number: 19204
. 2010-05-27 11:53:06.979 Sent 17 bytes
> 2010-05-27 11:53:06.979 Type: SSH_FXP_SETSTAT, Size: 114, Number: 18697
. 2010-05-27 11:53:06.979 Sent 118 bytes
. 2010-05-27 11:53:06.979 Waiting for another 4 bytes
. 2010-05-27 11:53:07.073 Detected network event
. 2010-05-27 11:53:07.073 Received 28 bytes (0)
. 2010-05-27 11:53:07.073 Read 4 bytes (24 pending)
. 2010-05-27 11:53:07.073 Read 24 bytes (0 pending)
< 2010-05-27 11:53:07.073 Type: SSH_FXP_STATUS, Size: 24, Number: 18950
. 2010-05-27 11:53:07.073 Waiting for another 4 bytes
. 2010-05-27 11:53:07.307 Detected network event
. 2010-05-27 11:53:07.307 Received 28 bytes (0)
. 2010-05-27 11:53:07.307 Read 4 bytes (52 pending)
. 2010-05-27 11:53:07.307 Read 24 bytes (28 pending)
< 2010-05-27 11:53:07.307 Type: SSH_FXP_STATUS, Size: 24, Number: 19204
< 2010-05-27 11:53:07.307 Status code: 0
. 2010-05-27 11:53:07.307 Read 4 bytes (24 pending)
. 2010-05-27 11:53:07.307 Read 24 bytes (0 pending)
< 2010-05-27 11:53:07.307 Type: SSH_FXP_STATUS, Size: 24, Number: 18697
. 2010-05-27 11:53:07.307 File: "D:\Brokers\Incoming\05262010\Copy (98) of 18917\incoming.touch"
. 2010-05-27 11:53:07.307 Copying "D:\Brokers\Incoming\05262010\Copy (98) of 18917\incoming.touch" to remote directory started.
. 2010-05-27 11:53:07.307 Binary transfer mode selected.
. 2010-05-27 11:53:07.307 Opening remote file.
> 2010-05-27 11:53:07.307 Type: SSH_FXP_OPEN, Size: 119, Number: 19459
. 2010-05-27 11:53:07.307 Sent 123 bytes
. 2010-05-27 11:53:07.307 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:07.307 Waiting for another 4 bytes
. 2010-05-27 11:53:07.370 Detected network event
. 2010-05-27 11:53:07.370 Received 17 bytes (0)
. 2010-05-27 11:53:07.370 Read 4 bytes (13 pending)
. 2010-05-27 11:53:07.370 Read 13 bytes (0 pending)
< 2010-05-27 11:53:07.370 Type: SSH_FXP_HANDLE, Size: 13, Number: 19459
> 2010-05-27 11:53:07.370 Type: SSH_FXP_CLOSE, Size: 13, Number: 19972
. 2010-05-27 11:53:07.370 Sent 17 bytes
. 2010-05-27 11:53:07.370 There are 0 bytes remaining in the send buffer
> 2010-05-27 11:53:07.370 Type: SSH_FXP_SETSTAT, Size: 119, Number: 19721
. 2010-05-27 11:53:07.370 Sent 123 bytes
. 2010-05-27 11:53:07.370 Waiting for another 4 bytes
. 2010-05-27 11:53:07.417 Detected network event
. 2010-05-27 11:53:07.417 Received 28 bytes (0)
. 2010-05-27 11:53:07.417 Read 4 bytes (24 pending)
. 2010-05-27 11:53:07.417 Read 24 bytes (0 pending)
< 2010-05-27 11:53:07.417 Type: SSH_FXP_STATUS, Size: 24, Number: 19972
< 2010-05-27 11:53:07.417 Status code: 0
. 2010-05-27 11:53:07.417 Waiting for another 4 bytes
. 2010-05-27 11:53:07.464 Detected network event
. 2010-05-27 11:53:07.464 Received 28 bytes (0)
. 2010-05-27 11:53:07.464 Read 4 bytes (24 pending)
. 2010-05-27 11:53:07.464 Read 24 bytes (0 pending)
< 2010-05-27 11:53:07.464 Type: SSH_FXP_STATUS, Size: 24, Number: 19721
< 2010-05-27 11:53:07.464 Status code: 0
. 2010-05-27 11:53:07.464 File: "D:\Brokers\Incoming\05262010\Copy (98) of 18917\Thumbs.db"
. 2010-05-27 11:53:07.464 Copying "D:\Brokers\Incoming\05262010\Copy (98) of 18917\Thumbs.db" to remote directory started.
. 2010-05-27 11:53:07.464 Binary transfer mode selected.
. 2010-05-27 11:53:07.464 Opening remote file.
> 2010-05-27 11:53:07.464 Type: SSH_FXP_OPEN, Size: 114, Number: 20227
. 2010-05-27 11:53:07.464 Sent 118 bytes
. 2010-05-27 11:53:07.464 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:07.464 Waiting for another 4 bytes
. 2010-05-27 11:53:07.510 Detected network event
. 2010-05-27 11:53:07.510 Received 17 bytes (0)
. 2010-05-27 11:53:07.510 Read 4 bytes (13 pending)
. 2010-05-27 11:53:07.510 Read 13 bytes (0 pending)
< 2010-05-27 11:53:07.510 Type: SSH_FXP_HANDLE, Size: 13, Number: 20227
. 2010-05-27 11:53:07.510 Write request offset: 0, len: 4096
> 2010-05-27 11:53:07.510 Type: SSH_FXP_WRITE, Size: 4121, Number: 20742
. 2010-05-27 11:53:07.510 Sent 4125 bytes
. 2010-05-27 11:53:07.510 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:07.510 Write request offset: 4096, len: 7699
> 2010-05-27 11:53:07.510 Type: SSH_FXP_WRITE, Size: 7724, Number: 20998
. 2010-05-27 11:53:07.510 Sent 7728 bytes
. 2010-05-27 11:53:07.510 Write request offset: 11795, len: 6637
> 2010-05-27 11:53:07.510 Type: SSH_FXP_WRITE, Size: 6662, Number: 21254
. 2010-05-27 11:53:07.510 Sent 6666 bytes
> 2010-05-27 11:53:07.510 Type: SSH_FXP_CLOSE, Size: 13, Number: 21508
. 2010-05-27 11:53:07.510 Sent 17 bytes
> 2010-05-27 11:53:07.510 Type: SSH_FXP_SETSTAT, Size: 114, Number: 20489
. 2010-05-27 11:53:07.510 Sent 118 bytes
. 2010-05-27 11:53:07.510 Waiting for another 4 bytes
. 2010-05-27 11:53:07.557 Detected network event
. 2010-05-27 11:53:07.557 Waiting for another 4 bytes
. 2010-05-27 11:53:07.745 Detected network event
. 2010-05-27 11:53:07.745 Received 28 bytes (0)
. 2010-05-27 11:53:07.745 Read 4 bytes (136 pending)
. 2010-05-27 11:53:07.745 Read 24 bytes (112 pending)
< 2010-05-27 11:53:07.745 Type: SSH_FXP_STATUS, Size: 24, Number: 20742
. 2010-05-27 11:53:07.760 Read 4 bytes (108 pending)
. 2010-05-27 11:53:07.760 Read 24 bytes (84 pending)
< 2010-05-27 11:53:07.760 Type: SSH_FXP_STATUS, Size: 24, Number: 20998
. 2010-05-27 11:53:07.760 Read 4 bytes (80 pending)
. 2010-05-27 11:53:07.760 Read 24 bytes (56 pending)
< 2010-05-27 11:53:07.760 Type: SSH_FXP_STATUS, Size: 24, Number: 21254
. 2010-05-27 11:53:07.760 Read 4 bytes (52 pending)
. 2010-05-27 11:53:07.760 Read 24 bytes (28 pending)
< 2010-05-27 11:53:07.760 Type: SSH_FXP_STATUS, Size: 24, Number: 21508
< 2010-05-27 11:53:07.760 Status code: 0
. 2010-05-27 11:53:07.760 Read 4 bytes (24 pending)
. 2010-05-27 11:53:07.760 Read 24 bytes (0 pending)
< 2010-05-27 11:53:07.760 Type: SSH_FXP_STATUS, Size: 24, Number: 20489
. 2010-05-27 11:53:07.760 File: "D:\Brokers\Incoming\05262010\Copy (98) of 18917\{105C4D26-03E5-421E-BAD5-3ABC2D9740B3}.tif"
. 2010-05-27 11:53:07.760 Copying "D:\Brokers\Incoming\05262010\Copy (98) of 18917\{105C4D26-03E5-421E-BAD5-3ABC2D9740B3}.tif" to remote directory started.
. 2010-05-27 11:53:07.760 Binary transfer mode selected.
. 2010-05-27 11:53:07.760 Opening remote file.
> 2010-05-27 11:53:07.760 Type: SSH_FXP_OPEN, Size: 147, Number: 21763
. 2010-05-27 11:53:07.760 Sent 151 bytes
. 2010-05-27 11:53:07.760 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:07.760 Waiting for another 4 bytes
. 2010-05-27 11:53:07.807 Detected network event
. 2010-05-27 11:53:07.807 Received 17 bytes (0)
. 2010-05-27 11:53:07.807 Read 4 bytes (13 pending)
. 2010-05-27 11:53:07.807 Read 13 bytes (0 pending)
< 2010-05-27 11:53:07.807 Type: SSH_FXP_HANDLE, Size: 13, Number: 21763
. 2010-05-27 11:53:07.807 Write request offset: 0, len: 6818
> 2010-05-27 11:53:07.807 Type: SSH_FXP_WRITE, Size: 6843, Number: 22278
. 2010-05-27 11:53:07.807 Sent 6847 bytes
. 2010-05-27 11:53:07.807 There are 0 bytes remaining in the send buffer
> 2010-05-27 11:53:07.807 Type: SSH_FXP_CLOSE, Size: 13, Number: 22532
. 2010-05-27 11:53:07.807 Sent 17 bytes
> 2010-05-27 11:53:07.807 Type: SSH_FXP_SETSTAT, Size: 147, Number: 22025
. 2010-05-27 11:53:07.807 Sent 151 bytes
. 2010-05-27 11:53:07.807 Waiting for another 4 bytes
. 2010-05-27 11:53:07.901 Detected network event
. 2010-05-27 11:53:07.901 Received 28 bytes (0)
. 2010-05-27 11:53:07.901 Read 4 bytes (24 pending)
. 2010-05-27 11:53:07.901 Read 24 bytes (0 pending)
< 2010-05-27 11:53:07.901 Type: SSH_FXP_STATUS, Size: 24, Number: 22278
. 2010-05-27 11:53:07.901 Waiting for another 4 bytes
. 2010-05-27 11:53:08.073 Detected network event
. 2010-05-27 11:53:08.073 Received 28 bytes (0)
. 2010-05-27 11:53:08.073 Read 4 bytes (52 pending)
. 2010-05-27 11:53:08.073 Read 24 bytes (28 pending)
< 2010-05-27 11:53:08.073 Type: SSH_FXP_STATUS, Size: 24, Number: 22532
< 2010-05-27 11:53:08.073 Status code: 0
. 2010-05-27 11:53:08.073 Read 4 bytes (24 pending)
. 2010-05-27 11:53:08.073 Read 24 bytes (0 pending)
< 2010-05-27 11:53:08.073 Type: SSH_FXP_STATUS, Size: 24, Number: 22025
. 2010-05-27 11:53:08.089 File: "D:\Brokers\Incoming\05262010\Copy (98) of 18917\{49110D47-1D97-469D-8A4E-1E14489241D9}.tif"
. 2010-05-27 11:53:08.089 Copying "D:\Brokers\Incoming\05262010\Copy (98) of 18917\{49110D47-1D97-469D-8A4E-1E14489241D9}.tif" to remote directory started.
. 2010-05-27 11:53:08.089 Binary transfer mode selected.
. 2010-05-27 11:53:08.089 Opening remote file.
> 2010-05-27 11:53:08.089 Type: SSH_FXP_OPEN, Size: 147, Number: 22787
. 2010-05-27 11:53:08.089 Sent 151 bytes
. 2010-05-27 11:53:08.089 There are 0 bytes remaining in the send buffer
. 2010-05-27 11:53:08.089 Waiting for another 4 bytes
. 2010-0
