Help - Simply scripting for connections
pjmartins
Hi there,
Great product! I'm looking for some simple connection scripts.. Literally to simply run a shortcut that will connect the user to a server direct. This simply runs the application with the hostname and port defined. Then the user simply enter username and password...
Is this possible as i've tried a few without any luck!
pjmartins
Re: Help - Simply scripting for connections
Do I understand right that the script should just initiate connection to specific host, nothing more?
