Winscp freezing problem
bladesownage
Basically i can ssh into my ipod fine into /root but when i try to go up a folder it simply freezes. I can go into any of the folders in /root but none in any parent folders. This basically means that SSHing for me is useless does anyone have any ideas please?
Re: Winscp freezing problem
