File Name Corruption on transfer to windows
mikewill34
Leicester, UK
Using WinSCP Version 4.2.7 build 758
When the "Transfer" "Filename modification" Option Replace \:*?'... is checked some uppercase letters "A", "F", "R" & "S" are wrongly escaped to %XX. See examples below.
Unix FileName(s)
A B C D E F G H I J K L M.txt
N O P Q R S T U V W X Y Z.txt
are wrongly converted to :-
%41 B C D E %46 G H I J K L M.txt
N O P Q %52 %53 T U V W X Y Z.txt
i.e.
A --> %41
F --> %46
R --> %52
S --> %53
This occurs when transfering from a Unix host to windows.
Regards
Mike
mikewill34
Leicester, UK
Hi Martin,
Problem still exists in debug version.
I have emailed you a link to get the log files and screen shots
Regards
Mike
mikewill34
Leicester, UK
Problem Solved
Hi Martin,
Thanks for your help, my .ini file had several corrupted areas as follows:-
L = New .ini file
R = Corrupted ini file
L26  PuttySession=WinSCP%20temporary%20session
     PuttyPath=%25PROGRAMFILES%25%5CPuTTY%5Cputty.exe
R36  PuttySession=WinSCPR0temporaryR0session
     PuttyPath="C:%5CProgram%20Files%5CPuTTY%5Cputty.exe"
L52  SelectMask=%2A.%2A
R62  SelectMask=RA.RA
L97  Masks=%2A.%2Ahtml;%20%2A.htm;%20%2A.txt;%20%2A.php;%20%2A.php3;%20%2A.cgi;%20%2A.c;%20%2A.cpp;%20%2A.h;%20%2A.pas;%20%2A.bas;%20%2A.tex;%20%2A.pl;%20.htaccess;%20%2A.xtml;%20%2A.css;%20%2A.cfg;%20%2A.ini;%20%2A.sh;%20%2A.xml
R107 Masks=RA.RAhtml;R0RA.htm;R0RA.txt;R0RA.php;R0RA.php3;R0RA.cgi;R0RA.c;R0RA.cpp;R0RA.h;R0RA.pas;R0RA.bas;R0RA.tex;R0RA.pl;%20.htaccess;R0RA.xtml;R0RA.css;R0RA.cfg;R0RA.ini;R0RA.sh;R0RA.xml
L107 LocalInvalidChars=/%5C:%2A%3F"<>|
R117 LocalInvalidChars=/%5C:RASF"<>|
L179 LastLocalTargetDirectory=C:%5CUsers%5COwner%5CDocuments
R235 LastLocalTargetDirectory=C:UCUsersE5COwnerUCDocuments
L220 FileMask=%2A.%2A
R276 FileMask=RA.RA
L228 FileMask=%2A.%2A
R284 FileMask=RA.RA
I deleted the old ini file and let WinScp create a new one.
Regards
Mike
nerg
Same Problem on 5.9.4
Hey Guys,
i have the same Problem, but deleting the old .ini and let winscp create a new one does not solve anything.
Any Ideas?
Greetings
Daniel
Re: Same Problem on 5.9.4
Please start a new thread and post some screenshots and log.
Hi, I want to know which software to capture and edit it. Thank you.
